Question about HP OfficeJet 7410 All-In-One InkJet Printer
Copy problems When I make copy through the feeder they come out with black lines all over them.
    Scholar:
  • 21 Answers
Hi , This is a genral problem while copying from Feeder as the feeder might be dirty so cleaning the feeder will resolve the problem.. You can go through the below document with the instructions and graphical representation of cleaning the Feeder.. http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00846928&cc=us&lc=en&dlc=en&product=391194&dlc=en&lang=en Just click on the link to open the webpage and follow the steps.. Try to clean the fedder twice or thrice if the issue still presists.. Wish u success... Regards, Barret.
Posted on Oct 02, 2007
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
Black stripes on copies using a Canon D1120
Do you use the Doc. feeder? Try to make a copy off the copy board glass. Is the line there? Now make a copy with the adf. Is the line there? If so, you need to clean the small glass under the doc feeder. It looks like a glass ****, about a 1/2 inch wide. Clean it with windex and that should solve your line problem...
May 11, 2010 | Canon CLC 1140 Copier
Thin black line appears on all copies ONLY from form feeder
Hi sounds like you have a particle on the window in the feeder. What hapens is when the light scans the paper your copying the particle of dirt shows up as a line. Simply clean it with a soft cloth and mild window cleaner. . Thank you for using Fixya.com
Feb 09, 2010 | HP Laserjet M2727nf Multifunction Printer
HP OfficeJet J5780 Vertical Black Line Prints when copying or scaning only. Cleaned rollers and changed black ink cartrigde. Still problem.
Have you tried cleaning the document feeders Scan Glass? (small glass under doc feeder ~ 1" by 9") Most times there is dirt spot on this glass, causing a shadow on scans and copies.
Try copying from the large glass by lifting doc feeder / platen cover and manually placing original. If no line copying or scanning manually from large glass, then small scan glass is deffenitely the culprit. Hope this helps.
Sep 07, 2009 | HP Officejet 5780 Printer
Copies have black lines on them after i replaced the toner
does the lines come when doing copies in the doc feeder only? or on the glass also?
if only in the doc feeder lift up doc feeder and clean the small strip of glass
Oct 30, 2008 | Sharp AL 1631 Copier
Single black line down center of newly copied page when using Auto feeder to copy
I had this same problem but after while it went away - so my solution would be to just keep using it, and perhaps it will solve itself.
Jun 03, 2008 | HP Photosmart C6180 All-In-One InkJet...
Black line on copies
If your copier has an automatic feeder and your line is present when using the feeder but not when you copy from the glass,just clean the small glass at the point where the line appears.
Feb 28, 2008 | Canon ImageClass D880 Copier
Problem while copying
O.K. guys,
the problem is with the smaller glass on the left.
Lift the top and look at the small glass on the left, is there a dot, whiteout, dirt etc... on there? that is what's making your lines. clean with alcohol or mild cleanser.
Nov 07, 2007 | Kyocera RI-3530 Black and White Copier
HP OfficeJet 7410 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
