Question about Amana ARS2661B Side by Side Refrigerator
ARS2665AC - Every 3 minutes noise
Every 3 minutes I hear a noise, buzzing sound, come from underneath the bottom right of the refrig. It is consistently on a 3 minute cycle and lasts for about 5 seconds. The light in the refrigerator dims slightly when this happens.This is a 7 year old side by side and appears to be working properly, other then the buzzing sound. Any ideas?
  • 363 Answers
Unless this is somthing to with the ice maker, it is likely to be the refrigeration pump cycling on and off. It is possible that the pump is being stalled upon start up. Another possibility is that the pump vibrates more as the pressure is being built up and perhaps one of the rubber mountings has worn or perished. As long as the fridge is still working properly as you say then this should not be a cause for concern unless it becomes annoying. Regards
Posted on Oct 02, 2007
FMV152KWA microwave buzzes when not running
Missy Uhland Bauman,
I understand that you are hearing a buzzing noise from your microwave, even though the door is shut and and it is not running. I would suggest to give the appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for 3-5 minutes. After the 3-5 minutes, bring power back. If you are still hearing a buzzing sound, I suggest either contacting the manufacturer or your local authorized technician.
-Best Regards-
Jan 10, 2014 | Frigidaire FMT118E1B Microwave Oven
Have a kemore elite. Keeps making a buzzing noise every 4 minutes. The bottom feezor is cold but not cold enough to make ice, even with thermostate on high. The refrig top is fine no problems....
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 03, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
Humming sound about every 3 minutes for the last few weeks. Today the temperature is 30dg. in freezer and 39 in refrig section. This refrig was bought in June, 2005 and after 1-1/2 year had to have the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Sep 09, 2010 | Amana AFD2535DES French Door Refrigerator
The freezer has stopped working and now the fridge is warming up! Seems to be coming from the bottom of the unit - it makes a buzzing noise followed by a click, as if it is trying to fill something...
Is the compressor (underneath the refrigerator) not running?
If so, the buzzing sounds like the compressor is trying to come on, and it won't for some reason. That's major repairs.
Oct 15, 2009 | Refrigerators
Freezer not working
That is the compressor overload. I recommend you disconnect the refrigerator now to prevent damage to the compressor. It could be the start relay or the start capacitor is defective. Let me know when you are ready to test the compressor. This is serious that you disconnect asap to prevent damage to the internal overload. What you hear now is the external overload and the compressor will be too hot to touch. Sea Breeze
Jul 21, 2009 | Refrigerators
Buzzing sound clicks on and off from underneath fridge
that would be your relay going bad it will stop the fridge all together change it to a 3 and 1 relay
Apr 15, 2009 | Admiral 26 cu. ft. Side-By-Side...
THERE IS A BUZZING SOUND THAT COMES AND GOES
the noise is most probably compressor tubing vibrating while the unit is running. when you press against the doors your changing the position of the tubing causing it to quiet down. what you can do to fix it is pull refrig from wall remove unit cover on the bottom and move the tubing around alittle bit then put it back together and see what happens. in some cases unless it makes the noise while your working on it, it may take 2 or 3 attempts to finally get it to stop. additionally if you have copper tubing for the icemaker water line be sure it is isolated as well to help quiet it down.
DO BE CAREFUL when moving the tubing not to cause it to leak refrigerant by bending or moving too much. the noise is an annoyance and not a sign the refrig is about to break down. Thanks Peyton
Mar 16, 2009 | Kenmore Refrigerators
A loud intermitant buzzing coming from the back of the fridge
either the noise is coming form he ice maker fill valve( but if its of and still aking noise i doubt it. it also possible that the noise is coming from the compressor itself, overheating nad trying to restart in which case would give a slight "buzz" noise for 5secs or so then "click" off, and wait maybe 3 min to restart again. look for melted ice andperhaps your ice dream ont as hard as it should be???
Feb 19, 2009 | Amana DRB1901C Bottom Freezer Refrigerator
Buzzing and low temps
sound like a compresser relay/overload ,uplug the refigerator remove back cover, remove relay that is on the compressor and check it by shaking it , it should not rattle. if it does replace it..
Aug 10, 2008 | Frigidaire FRS26R4A Side by Side...
Amana ARS2661B Side by Side Refrigerator Logo
223 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
