Samsung 1000W 5.1-Ch. Home Theater System with Upconvert DVD Player Logo
Posted on Aug 21, 2017
Ht-q70 shut itself off and posted the phrase 'protection' It is a 5 dvd player with built-in amplifier and the rep said that a fan was not working and it shut itself off to protect from overheating. It will not turn itself back on for any length of time and there are still cds/dvds inside of it. Is it worth getting it repaired, can I order a fan? Samsung says 160 dollars to repair it.
  • msaromatics6 May 11, 2010
    my dvd player has been saying "Protect for 2weeks now and it still will not work. I think there needs to be a recall on the samsung dvd home theater system.Obviously there is something wrong with this whole scenerio knowing that the samsung has too many malfuction issues.
5 Related Answers
A
Anonymous
  • Posted on Jun 13, 2007
SOURCE: Samsung HT-DB600
i think you hold down the stop button on the player for like 8 seconds or something while the player is off. that is suppossed to reset it.
Anonymous
  • 70 Answers
  • Posted on Jul 03, 2009
SOURCE: samsung ht-wx70 shutting off for protection
The word PROTECTION means that the cooling fan is defective. it needs to be replaced.
Call 1-800-7267864 (SAMSUNG) and they can repair it for you.
Hope this helps!
Anonymous
  • 113 Answers
  • Posted on Jul 22, 2009
SOURCE: how do i connect/play my turntable?
Hi sorry to say cant go direct.
What you can do if really want it running is get a RIAA pre amp with power supply (search google local shops). The turn table plugs into that, then that plugs into one of the analogue inputs of the Q70. That will work great if prepared for the effort!
Best of luck
Anonymous
  • Posted on Jan 15, 2010
SOURCE: Samsung Home cinema HT-TXQ120 system won't read CDs and DVDs.
Hi.
I have had the same problem.
Just unplug the systme and plug it back in.
Anonymous
  • Posted on Apr 06, 2010
SOURCE: ht-tz215 dvd player not playing dvds or cds
try Resetting the system turn power off then press and hold stop button on front panel, power light will flash, hopefully this will sort it for you
I have a samsung ht -tx 22 dvd home cinema system and for sometime now, the screen shows PROTECTION and it reverts to standby mode by itself.. Need help badly as sometimes it plays for 1 to 5 minutes and...
Check all your cables, connections and speakers. If they are all good, then either there is a fault on the protection circuit or the power amp has a fault on it. If the unit has a fan built into it check that is working. Sometimes the fan can get blocked up.
Our Samsung HT-C6900W Theater System shut off yesterday and then said it was in protect mode, now we cant get it turn on. This system is only 3 months old. Can you help?
The problem is with the amplifier overheating so the system shuts down to protect itself.
Make sure the ventilation fan is not block or obstructed.
If this is OK then contact your supplier with the equipments warranty.
Everytime I turn my on samsung ht-q70 the display screen says protection and the system shuts off. what can i do to get the protection off
The amplifier has a bad channel, or is bad itself. It is trying to either output too much current or is not putting out enough. If you have multiple speakers wired to one channel, you will either have to change the wiring to series(unit positive to first speaker red, first red to second BLACK, second red to unit negative) or remove on speaker. (If this is the case, then you might want to look at this. It is a tip/rick to place and properly/successfully run three subwoofers, but the main concept can be used on all channels.) If all channels are wired to he correct speaker, then the amp is in fact at fault.
Samsung ht-wx70 shutting off for protection
Hope this helps!
5helpful
2answers
My dvd home theatre system ht tx75 keeps shutting down
protection error message means that your unit's fan is not working
it is a feature to keep your unit from overheating
check if there is anything blocking the fan of your unit from rotating
if problem still persist replace the fan
5helpful
2answers
"Protect" error - HTZ110
Home Theater System Is Displaying "Protection" spacer.gif As soon as the unit is turned on, the word "PROTECTION" will flash on the front panel of the unit and SHUT OFF. This error message usually indicates that the fan in the back of the unit is not on.
The PROTECTION feature automatically shuts down the unit to avoid further damage. The unit will need service if this error message is displayed.
Please use our ASC Locator to find your nearest Authorized Service Center
from samsung's web
http://www.samsung.com/au/support/faqs/supportFaqList.do?group=&type=hometheatre&subtype=hometheatresystems&model_nm=HT-Z110&dType=D&mType=UM&vType=R&prd_ia_cd=03030100&acc_ia_fl=&disp_nm=HT-Z110&menu=faqs
2answers
My Samsung HT-40 home theater system throws itself into protection mode and shuts down. I put a new fan motor in but it insists on shutting down anywhere from 10 to 60 minutes of operation. No dust...
The fan is going bad and if you have replaced it try to open the case and remove the cover over all the capaciters and what not and replace that fan in the back then cut a hole in the top of the metal case directly about the cap's that warm up and install a aditional fan to act as a chimney a little noisy but i did this and the player had been runing in aux and radio mode for a few days stright now no problems at all it's alot of work and skill but for 2 5-15 dolar fans sure beats the 160 for repair or buying a new recever! make sure u turn on the recever for 10 min if the fan is not turning by then its still not good
2answers
Problem with SAMSUNG HT-X20!!
The fan is going bad and when u play dvd's the spining of the cd is acting as a fan witch is why they play longer then any other mode i had the same problem 2 times the second time samsung wanted 160$!!! thats bull because it keeps going out so what u do is open the case and remove the cover over all the capaciters and whatnot and replace that fan in the back then cut a hole in the top of the metal case directly about the cap's that warm up and install a aditional fan to act as a chimney a little noisy but i did this and the player had been runing in aux and radio mode for a few days stright now no problems at all it's alot of work and skill but for 2 5-15 dolar fans sure beats the 160 for repair or buying a new recever!
We are trying to watch a movie on our new ht-tx72 dvd home theatre system...but it keeps shutting itself off and saying protection goodbye....what can we do to fix this?...it is getting frustrating now
Your ICs audio amplifiers are in short circuit thats why that legend are coming for protect your theatre of more damage you got to replace the ICs.Good luck
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
