Tuning an Akai Television
I own a 29" Akai television (CTV29TA) which recently 'spat the dummy' and had to be re-tuned to receive the free-to-air TV stations. At one stage we had them tuned but a blue screen flashed up saying something along the lines of "Hi Sense has been turned off". We're now stuck with only 2 TV stations. Any idea how we tune our TV to receive the others?
  • 790 Answers
Go to settings! then select auto search!
Posted on Oct 02, 2007
SOURCE:
My LG Television does not recognize local over-the-air stations.
somewhere in the main menu it asks for input . that needs to be set to antenna or air .once you find that and put in the right kind of input then do the autoscan.
Jan 24, 2015 | LG Televison & Video
My 14 inch Akai tv got tuning child locked..i removed the child lock by holding lock button. for ten sec.. but the child lock for tuning option wont go... help mee
Download the user manual to your tV from net, and refer it about how you can make a factory reset to this TV. Do it. It will make all things right.
May 12, 2012 | Akai CF2791 27" TV
TELEVISION
Samsung tellys top level menus should have a choice of four or five sub-menus.
The one you want is that represented by a picture of a satelite dish / antenna. Dont worry if you dont get your TV via satelite, this is just the symbol they use to denote the tuning options.
Down arrow to the satelite dish sub-option and select enter. This should then give you several more options, one of which is Tuning, Select this and then select Auto Tune, then press enter and the set will completely retune itself.
If youre asking this as a result of yesterday's Freeview retune, then you may well end up with some "dummy" channels - i.e. they either have nothing at all displayed or a message telling you the channel has moved - or some of the channels have an incorrect name. I'm hoping that now the retune has happened, in the near future these dummys or errors will be fixed.
Some Samsung TV's dont have a "tuning" sub-menu but "Channel(s)". Selecting this will then give the Auto Tune option.
Oct 01, 2009 | Televison & Video
How do I go from anolog to digital???
Sounds like it's not tuned in. Try pressing digital, then menu and tuning in.
Jun 12, 2009 | Akai LCT3285TA 32 in. LCD Television
Early 2000's AKAI ATV 140 (Tv / Video Combo)
I recently bought a used LCT2060 that had no remote. I figured my comcast cable remote would work without a problem but it didn't. So 3 universal remotes later I found my solution...a radio shack2_bing.gif universal gamer remote. It controls up to 5 components plus your xbox360, playstation and pc. The price on sale was a mere 12.97, not bad if you ask me. Hope this helped. The code that worked for the Akai2_bing.gif was 11676. Take care...
Mar 31, 2009 | Akai LCT2701AD Television
Can't tune tv for ish netwrok
Ok based on the little info you gave you may need to place the cable from the dish box into the ant 2 connection on the tv, that is the analog cable connection, ant 1 is for digital tv only, also if you have rca jacks you need to change the source on the tv to av or svideo.
hope this helps.
let me know
Mar 25, 2009 | Akai LCT2715 27 in. LCD Television
PT5598HDI Wiring Problem
the red wire will go somewhere to the right side near the High Voltage section. The green wire is probably antenna. DO NOT get them crossed...
Question. what connector if any is attached? The board will usually have a pin sticking up that is marked...
Jul 13, 2008 | Akai PT5598HD 55" Rear Projection...
LCT3201AD tv mode stereo only?
AKAI told me that I needed to get a cable tuning box to fix this.
No other way would work
Nov 04, 2007 | Akai LCT3201TD 32 in. LCD Television
Tuning in Akai Video
Please explain what you mean by "tuning in."  Are you referring to hooking up to your Television, or to a cable/satellite box?  Or can you not see video when you play a VCR.
Check your hookup cabling.  With a cable or satellite system, the VCR normally is hooked between the cable/sat receiver box and the TV.  Cable box RF output to VCR RF input, VCR RF output to TV RF input.
There are other possibilities when your TV has video or line inputs.
Oct 30, 2007 | JVC BR-S622DXU VHS / S-VHS playback VCR
Akai ct29x4av television
Hi you sound as if you know what you are doing,so looks like service manual needed,try Donberg electronics at www.Donberg Electronics .ie Good luck
May 11, 2007 | Akai CTS2550 25" TV
Televison & Video Logo
502 people viewed this question
Top Televison & Video Experts
Ekse
