Question about Philips 150S4FB 15" LCD Monitor
150s4 q7102 r 3118 r3117 r3119 3106 burning
  • 150s4 Oct 06, 2007
    the value off r3106-r3107 /r3117-3118-3119
    thank you
    An expert who has answered 500 questions.
  • 556 Answers
All resistors & transistor are the parts of power supply connected to switching ckt. so there is a possibility of switching transistor or associated components failure. please check it. if you are in need of schematic it is available at
Posted on Oct 06, 2007
  • manahar modern Oct 07, 2007
    hopr this will help
Why does fire burn u
Because its hot. Not only will fire burn you but any material or object that is hot can burn you or cause scorching or smoke. An electrical charge can burn you. Leaning against a hot car in the heat of the sun can burn you. Very hot water can burn you. A iron left on can burn you. A stove top burner or oven can burn you. If it's hot, IT BURNS! !
Mar 25, 2015 | Cars & Trucks
Nero Serial code key for registration
You can obtain a free nero burning rom 9 download and a serial key emailed to your email from ahead software / nero by signing up to the free trial - this will let you use the software legally as a trial for around 15 days, during this time you can burn dvd, cd and other media for free.
After the trial is over, you must purchase the program, if you can't afford the program and if you want to get it cheaper than what they are asking for it, buy a new CD/DVD burner that has nero software included those generally cost around 20 to 30 $ from
if you can't afford that either, then there are free alternatives to nero. For example cdburnerxp is a great program that will get the job done, it will burn your cd and dvds for free. Download -
Thank you for reading
Please write feedback, comments, suggestions etc below.
dvd burning software review dvd burning software free download free dvd burning free dvd burn how to burn a dvd dvd burning programs how to burn dvd software to burn dvd burner software burn to dvd free dvd burning software burning download cd burning software burn cd dvd burn cd incd software cd dvd burning software dvd burn software dvd burning software reviews cd burn software best dvd burning software free burning software burning cd dvd free cd dvd burning software burn dvd dvd burning software burning software burning dvds cd burning dvd burning
on Mar 11, 2010 | Ahead Software Nero 9 Full Version for PC
Internal dvd/cd-rom
Looks like the answer is yes. Call to be sure. For prices and availability of parts and upgrades for this system, call 1-800-357-3355. Give them the service tag number and they will be able to tell you for sure.
Assembly 24X CD-RW/DVD Combo Drive Usually Ships 3-4 DaysManufacturer Part# R3117 Dell Part# R3117
Starting Price spacer.gif $109.95
Apr 14, 2010 | Dell LATITUDE D400 D500 D505 D600 D800...
Philips 150S4 does not switch on every time the PC is switched on - suspect it is powersupply problem. Thanks Louis
You check the cable that's used to connect the cpu and that monitor, and the cable that's connected to the power supply. You unplug and plug it. You may have a loose connection on plugs. It works for me. Hope this helps.
Nov 08, 2009 | Philips 150S4FG (White) 15" LCD Monitor
How to unlock main menu
I have just sorted this problem on my Philips 150s4 monitor by pressing OK button for about 15 seconds.
Bartek - Webmax
Oct 06, 2009 | Philips 190B6CB/27 19" LCD
Cracking and sparking coming from inside of 150s4 monitor case wiggle power cord monitor comes on will re soldering the power socket to the board fix this problem
Yes, but you are dealing with potentially high voltages inside the case. The crackling and sparking are an open short that is being arced but the voltage.
This is one of those things that can be dangerous, so make sure everything is disconnected and that you leave the monitor unplugged for at least an hour so that all of the capacitors can "leak" discharge themselves.
Jan 05, 2009 | Computers & Internet
Philips 150S4 15" LCD Monitor Problem
If it just fails to turn on, the main power supply is probably at fault and without some technical background and a couple of test instruments, you will not likely be able to do the repair yourself.
Modern power supplies are designed to shut down if the current drawn exceeds the design level, which indicates that something the supply services or the supply itself has died.
If you are adventurous, you might pull the plug on the set, allow the set to sit overnight, gain access to the innards, and with good light, inspect any boards inside.
If you see one that has few ICs but many more larger discrete parts, this will be the power supply.
Again, before touching anything inside, especially on that board, allow at least several hours to be safe since the larger capacitors can hold a painful voltage charge for some hours.
You are looking for components called electrolytic capacitors that are almost always cylindrical and mostly installed upright at 90 degrees to the board with leads passing through to the solder side.
This same type of component in smaller dimensions is still used in a horizontal package with leads bent down and passing though holes to the solder side.
The latter are becoming more rare since they don't lend themselves well to robot assembly.
Many failed caps (not all) will show signs of pregnancy when they fail, bulging unnaturally at the top when compared with others. Now and then, there may be traces of a crystalline deposit around the end where the seal failed from internal pressure.
These will have values listed on them in uFd & VDC and sometimes, a plus/minus number lying about the precision.
Some also have a date code (rarer) that will look like four digits:
2403 = 24th week of 2003
Most electronics suppliers have a stock of the various values but if they have a date code at all, try to get only those made before 2002 or after 2006.
The larger caps will probably be OK since the failure is likely related to functions other than brute-force filtering. A pretty good 'rule of thumb' is to replace any caps you see bulging of any value but especially those that are 100 uFd or less.
If you see signs of overheating such as discoloration of the board material, it may not be repairable but if you can find a part number on the board, you might be able to buy the power supply and install it yourself.
If there are no signs of heat damage to the board, there may be companies offering to repair it as a subassembly instead of repairing the whole set which could be much more expensive.
If you choose to replace it or have it done, the power supply still may not be at fault since most are capable of switching on and off if a downstream problem is causing an overload.
If you choose to replace failed caps yourself, you will need a quality soldering iron with a small, preferably iron-plated tip, rosin core solder and a sponge which when wetted is used to frequently wipe oxidized solder from the tip this should be kept bright and clean and fresh tinning will keep it that way.
You should also buy some solder 'wick' with the iron; this is used to place on the solder you wish to remove and then heated with the iron. Properly used, the wick will absorb nearly all of the solder from the lands from which you wish to remove a component.
Oct 12, 2008 | Philips 150S4FB 15" LCD Monitor
Burning and playing the product
see the burning rights that nero has set in your windows... it might be due to unupdated burning rights... try updating your nero using nero productsetup tool...
Feb 18, 2008 | Fujitsu Siemens AMILO Pro V2010 Notebook
Philips 150S4FB 15" LCD Monitor Logo
169 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
