SOURCE: I have a 1997 Mercedes E320 and the instrument cluster guages
hello,good day,maybe your cluster nearly damage,send to your dealer,they have a testing procedure(simulation all the gauges), to determine if your cluster is defective,ty
SOURCE: Electrical Instrument cluster does not function
I had the same problem with a car i owned and found out it was a short in the wireing in the dash, you will have too have it re-wired, but too be certain you should have it checked out by a mechanic in your city.........
remove the cluster(should be able to insert Small flat head screwdrivers into slots on plastic trim of cluster. Lower your steering wheel down and remove key. wait approx 30 seconds until cluster is off( means that the interior c.a.n. has went to sleep) unplug cluster and see if the bulbs you wish to replace are accessible from the rear cover. if not remove retaining screws and un clip rear cover from housing. You should have access to the back lighting bulbs
SPEEDOMETER TROUBLESHOOTING
Can
be loose speedo wiring connectors under instrument panel or its issue with
speed sensor on transmission.
I
suggest you to go through help links mentioned below with appropriate solutions
to confirm the problem :------
How to trouble shoot speedometer?
http://schematicsdiagram.blogspot.com/2011/06/speedometer-not-working.html
1996 fiat bravo speedometer not working?
http://technoanswers.blogspot.com/2012/01/1996-fiat-bravo-speedometer-not-working.html
Speedometer works but odometer not working?
http://technoanswers.blogspot.in/2012/01/speedometer-works-but-odometer-not.html
Speedometer runs backward?
http://technoanswers.blogspot.com/2012/01/speedometer-runs-backward.html
Warning lights on and speedometer died?
http://howtobyme.blogspot.com/2011/08/warning-lights-on-and-speedometer-died.ht
Speedometer not working on 1993 Ford F350?
http://repairhelpcenter.blogspot.in/2012/02/speedometer-not-working-on-1993-ford.html
ABS & Brake lights warning indicator steady on dash and
speedometer not working for Dodge Ram?
http://howtobyme.blogspot.com/2011/11/abs-brake-lights-warning-indicator.html
Vehicles Cluster panel Not reading Miles?
http://schematicsdiagram.blogspot.com/2011/12/vehicles-cluster-panel-not-reading.html
Odometer works properly but speedometer works
intermittently?
http://technoanswers.blogspot.com/2012/01/odometer-works-properly-but-speedometer.html
These
will help.
Thanks.
How to trouble shoot speedometer? http://repairhelpcenter.blogspot.in/2012/02/speedometer-not-working-on-1993-ford.html -------- These will help. Thanks.
-------Speedometer works but odometer not working?
--------Speedometer not working on 1993?
For
speedometer related issues, the help links are provided below. Click the link
below to go through its details: ----
why speedometer not working?
speedometer died?
http://howtobyme.blogspot.com/2011/08/warning-lights-on-and-speedometer-died.html
ABS & Brake lights
warning indicator steady on dash and speedometer not working?
reading Miles?
intermittently?
How odometer works in cars?
http://technoanswers.blogspot.com/2011/11/how-odometer-works-in-cars.html
Speedometer not working on Ford?
This will help.
Thanks
