Turn off / Disable wifi in the laptopTo Enable WPA Security in the wireless network
- - Hardwire the computer and router
- - Open the router setup page ( http://192.168.2.1 )
- - Click wi fi Protected setup on the left side
- - Scroll down a little and you can find the router PIN
- - This is the number that you need to enter in the device
WPA is an upgrade to the WEP (Wired Equivalent Privacy) standard
for securing your wireless network. If you would like to secure your
wireless network using WPA, you will need the following:
WPA enabled on your Dell TrueMobile 2300 Wireless Broadband
Router
WPA support for your wireless clients. If you are using a Dell
TrueMobile wireless client, you can check for the availability of WPA enabled
software update for your wireless client at
http://support.dell.com.
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE: To learn how to access the web-based setup page on a Mac computer, click here.
Step 2:
Click Setup > Basic Setup.
Step 3:
Make sure that the DHCP Server option is Enabled. Click the DHCP Reservation button if you want to assign a fixed local IP address to a MAC address.
Step 4:
When you click on DHCP Reservation, a new web browser window will pop-up. Click the Select checkbox to reserve a client's IP address. Click the Add Clients button afterwards.
Step 5:
If you want to manually assign an IP address, enter the client's host name in the Enter Client Name field. You can do this as well in the IP Address and MAC address fields.
Step 6:
Click the Add button.
Step 7:
A list of DHCP clients and their fixed local IP
addresses will be displayed at the bottom of the screen. If you want to
remove a client from this list, click the Remove button.
On this window, you can do any of the following:
• Click the button to save your changes.
• Click the button to cancel your changes.
• To view the most up-to-date information, click the button.
• To exit this screen, click the button
If you need more help come back.Post / thumbs / testimonial are welcome!.
Step 1:
Step 2:
Step 3:
Step 4:
Step 5:
Step 6:
Step 7:
• To exit this screen, click the button.
