There is a problem with a radio of my 2007 Jeep Grand Cherokee. Namely, the radio does not produce the sound and when i am trying to increase a volume, text "MUTE" appears on the screen. Pushing the mute button does not solve the problem. It happend after I heard from the speakers voice of lector speaking something in Italian (I bought my Jeep Italy). I do not know Italian but i cought a few words like "telefonica" - which means something with phone and "interrumpi" - just interrupt. Do you know how to help with this problem?
SOURCE: 2005 jeep grand cherokee radio
It's in the engine compartment IOD#2. It's a black module with two fuses in it. Take that module off and replace the 20 AMP one.
SOURCE: Radio speakers seem to be muted. I pushed INFO button, did this cause something to mute ??
Some radios have phone buttons that mute the speakers so you can talk on the phone. If you have Onstar and no active subscription it can also mute the radio thinking you are trying to talk to Onstar.
SOURCE: Radio: replacing radio,not stock,have adapter
YOU WILL HAVE TO TRACE THE WIRES OUT, DO U HAVE A SEPERATE AMPLFIER? MANY OF THESE VANS DO, IF SO THAT IS THE PROBLEM.
HERE IS THE WIRING COLOR DIAGRAM FOR YOUR VAN
1998 Dodge Caravan Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Pink
Car Radio Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Black/Yellow
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Blue/Orange
Right Rear Speaker Negative Wire (-): Blue/White
SOURCE: speakers for 1994 jeep grand cherokee
6.5" in all the doors dash is wierd. 2.75" but i have been able to squeez in a 3.5"
Testimonial: "thank you so much, that helps me out as lot"
SOURCE: 2007 JEEP GRAND CHEROKEE WON'T
I have found the solution to this problem. I have replaced a total of 3 starter motors and has gone away for various periods of time. Further diagnosed when concern happened again starter
would work again after starter ignition feed wire wiggled. I found corrosion build up in connector at ignition feed wire. I replaced connector on wire to starter solenoid and concern has not returned.
