I have a trekstore moviestation and I have been ripping my dvds with Majicripper and the picture quality is not good...also when the dvd rips there are two files instead of one which means the movie stops before the end and I have to switch two the other file to finish watching it...any help with this stuff?
Nidesoft DVD to Decrypter is designed to copy and backup DVD content to your PC or Rip DVD to other Video and Audio format files. It could decrypt the CSS of DVD and convert DVD to VOB, MP4, AVI, MPEG-1, MPEG-2, etc.. and popular audio music format such as DVD to MP3, WAV, OGG,etc. So you could easily convert your DVD movie to put into your movie players including iPod, iPhone, Pocket PC, XBox, etc.. http://www.nidesoft.com/dvd-decrypter.html
This is a two part process...
You'll need DVD Decryptor (freeware) and AutoGK (also freeware).
In DVD Decryptor you'll be ripping the DVD movie to an IFO file.
Once that is complete load AutoGK, select the IFO file you just created (it will automatically get the .vob's you just created) select a destination defualt an audio track (usually movies have more than one audio track) and file size and let it go. Depending on the movie it should take approximately 45 minutes to an hour to complete.
The other program you can use after DVD Decryptor is Any Video Converter (also freeware). Instead of selecting the ifo file, select all the .vob files and then right click on the files and select "merge" (make sure they are in the correct order).
This program is a lot faster than autoGK BUT if your DVD has multiple audio tracks, it may not get the right one during conversion.
how to make a toshiba model number ph3100u-1exb compatible with my xbox 360
Other harddrives...
(More)
Other harddrives normaly work but the toshiba is new. By the way it's a terabyte external harddrive.
Drive will not power up, tried another working power supply, still no good, scsi termination light...
(More)
Drive will not power up, tried another working power supply, still no good, scsi termination light lights up when termination set to ''I'', but power and activity led's do not light up. If you insert a disk, nothing happens and you have to manually remove the disk
I don't know how to use my Simpletech External Hard Drive. I have the CD and know how to plug it in....
(More)
I don't know how to use my Simpletech External Hard Drive. I have the CD and know how to plug it in. But then what do I do? It is a 500GB., blue with an oval on the top which I guess I am supposed to push. SimpleTech, a Fabrix company, Hi-Speed USB 2.0 & Fire Wire.
I cant get my trekstor movie station to come on at all. It seems as though it is stuck in a standby...
(More)
I cant get my trekstor movie station to come on at all. It seems as though it is stuck in a standby mode or the power supply is not providing enough power to turn it on.
i am trying to connect the trekstor moviestation (1 TB) to my sony bravia HD TV. Have picture but no...
(More)
i am trying to connect the trekstor moviestation (1 TB) to my sony bravia HD TV. Have picture but no sound?
