Question about Intel Motherboard
Need to find out where the on/off cables hook to a 277977-001 motherboard by compaq
I bought this board from a friend and didnt get the case to it. i need to find out where it I/0 cable hooks to so i can have a way to power it on and off. here is what i know so far it is a 277977-001 board and was removed from a Compaq Evo D500 Ultra-slim Desktop. tnx in advanced.
  • smallz Oct 03, 2007
    THATS NOT EVEN THE SAME BOARD AS WHAT I HAVE. I LOOKED AT IT. I NEED THE INFO ON EXACTLY WHICH 2 PINS R THE i/O SWITCH CONNECT. ON THE 277977-001 MOTHERBOARD MADE BY COMPAQ.
    Problem Solver:
  • 27 Answers
Fiend your solution direct from intel. Here is your solution....
need to find out where the on/off cables hook to a - d89218e.jpg
http://www.intel.com/motherboard/prob676ijt65/solution
apolpo-
27
Posted on Aug 29, 2009
  • 94 Answers
Try this link. This is Compaq's/Hp's download/driver support. You can find a manual there where you can see the motherboard in a Compaq Evo D500 Ultra slim Desktop and look for its motherboard diagram. Hope this helps. copy this link: http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64180&taskId=101&prodTypeId=12454&prodSeriesId=322601#5
Posted on Aug 01, 2009
    Novelist:
  • 231 Answers
Hi, If you use a torch and if necessary a magnifying glass and study your board. The row of pins nearest to the front of the case are where your case switch and LED light cables connect.
On all boards these are marked next to the pair of pins do what.
r/sw= reset switch: pwr= power on switch hdd equals Hard drive LED and so on. You can test this using a small screw driver and bridging out 2 pins at a time, this will not hurt your board as there is only very low voltage in this area. When you plug in the LED cables they have to be on the correct + or - pins, if they do not work just reverse the plug. you can not do any harm.
Regards mistyman.
Posted on Feb 19, 2008
2 Suggested Answers
SOURCE:
Psionics
  • 236 Answers
SOURCE: need to find out where the on/off cables hook to a 277977-001 motherboard by compaq
Generaly, the little connectors on the printed side will face the bottom of the case. Also, typically, Black is negative, and white/colour is positive (except on the power sw, it doesn't matter). On the motherboard, where the connectors go, there should be some kind of print saying where to plug them in. (IE, POWER SW, would go into PWR, and HDD LED would go into HDLED and POWER LED would go into PWRLED).
It may look different than this, but generally the same kind of layout, as you can see, it shows the positions, as well as positive and negative.
Unfortunetely, I can't seem to find a schematic for the Compaq 277977-001 motherboard. I will try and find one, but I hope this helps you out with what you are trying to do...
Posted on Sep 06, 2008
Need install manual for gl8e motherboard plz
have searched everywhere. I even entered a chat windows with Compaq & asked for a site to download the manual for Compaq Presario SR5015LA Desktop PC which has the motherboard MCP61PM-HM in it. (Nothing). This board was made by
ECS known as EliteGroup. Still nothing. Forms for the most part do not help, only with drivers. Drivers for the board can be found on Compaq's web site.
http://h10025.www1.hp.com/ewfrf/wc/prodinfoCategory?lc=en&cc=us&dlc=en&product=3411762
But the manual will not download. That's what is needed to hook up the front panel pins to you're case. I even looked for other possible boards who's layout was close to the MCP61PM-HM.
Nothing! I did find other Compaq PC's that also had the same board in it but after looking through the manuals, not one actuallys shows where to plug the front panel LED's on to the board. Why? Because Compaq does not support a user changing out their case for another. There is no money in that.
For the most part RobPu, system boards share some things in common. I am posting a picture for you. This pic is upside down for you so try & work with me here. Hook up you're LED's as shown. This should work for you. Pin 1 is you're starting point.
daa3370.jpg This is standard for ECS boards even if it's being sold by Compaq. Like I mentioned, for you it is posted unside down.
Try it, I'm sure it will work for you.
Aug 31, 2011 | Computers & Internet
Well a friend of mine bought a replacement motherboard an E310 for his computer and now the it turns on but isnt working. the powerlight is staying amber and not turning green
Make sure The P4 Power connector cable is Plugged into The motherboard (pictured)flooganbarg.jpg
If that is not your problem you should look to make sure there's stand offs holding the motherboard in the case and it's not just screwed in and touching the metal case, this would cause a short and prevent the motherboard from Posting.
You may also want to check if the power button is correctly hooked up to the motherboard.
Jul 22, 2011 | Dell Dimension E310 PC Desktop
Micro ATX motherboard ATX case?
Two possible causes - either you have installed it badly and it shorts to the case (take it out of the case and try it there) or not all the necessary cables were connected (check especially the power cables and the power button).
Jul 13, 2010 | Gigabyte GA-8I945GZME-RH Motherboard
I have new case,but can't connect audio,front usb,mic,5v,ground e.t.c cables from case to motherboard because they are not marked on it.Motherboard model HP compaq d530 xw3100
we see each casing have written cable knobe.as hdd/ reset/ power/ we join it on bord .there diagram on about this led/cable.2/ we give power to hdd/ cd room from smps3/ we join fan squire port on bord . fan port is written in bord. 4/we join data cablehdd/cdroom from on board.
Nov 04, 2009 | HP Compaq Motherboard
Conections
Hi peju90,
If you've gutted out the old dell computer, then your only talking about a empty case. Put all the right chips and cpu's that the Asus board requires, and you should have no problem with the CD rom or any other hardware. Except if you try and put the hard disk from the dell, it will not have the same configurations, and probably be a bit crazy. But, reformat the drive to it's new board, and your home free.
The power connections will be the same as it was on the old Presario, if you have the old power supply then nothing changes on that. You'll need to hook up the front connectors for USB and Hard drive lights, reset etc, but that would be the ugliest senario. Meaning the csse fit a special connector that the board doesn't carry. In that case you to option, either cut the special connectors and replace them with the ones from the old Presario case, or don't connect them, all but the power, you're gonna need that hooked up, one way or the other.
But, that's as tough as it gets my friend. A case is a case is a case.
Good Luck
Mark
Oct 17, 2009 | Computers & Internet
I am moving the motherboard to another case that ATX and AT motherboard compatible; but, I need to know how to hook-up the cases front light, sound, external USB, power switch and indicator light etc.,...
Hi there.
Get a strong flashlight and a magnifying glass (if you have one). On the motherboard look for the front panel, it should be marked PWR and coloured green, also the plug that connects to it should be marked PWR_SW. On some boards there are no colours but the markings are the same, so take a good close look.
Have a look at these pictures for an idea >>>>>>
USB header configuration >>>>
Good luck.
Jul 14, 2009 | HP Compaq d530 SFF PC Desktop
Sep 05, 2008 | Intel DG965RY Motherboard
Motherboard issues
Dear, friend
When connecting IDE devices in your computer, there are a few rules you need to know about.
First, Master and Slave devices are different for the 80-wire cables and the 40-wire cables.
Inside your computer, you generally have two (2) IDE hard drive controller connections. They look this this 99% of the time:
[ The smaller one on the very top is a floppy drive controller connection )
Jul 01, 2008 | Computers & Internet
HP MCP61PM-HM motherboard diagram
Hi RobPu,
I have searched everywhere. I even entered a chat windows with Compaq & asked for a site to download the manual for Compaq Presario SR5015LA Desktop PC which has the motherboard MCP61PM-HM in it. (Nothing). This board was made by
Enjoy!
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
May 22, 2008 | HP VECTRA VLI8 P3 Motherboard (KZM6120)
Compaq 252608-001 motherboard
hello sosumo,
see carefully on the board there might be some sign like:
  • HDD-LED
  • PWR SWTCH
  • SPKR
  • RSET
  • PWR LED
These are the points on your board where you have to connect frontpanel connections.
For more details goto HP website and search manual for your product using your board's model no.
Thanks
Iqbal
Apr 21, 2008 | Compaq (253219-002) Motherboard
Intel Motherboard Logo
243 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Ekse
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
