Question about Sansui DTV2760 27" TV
Sansui SV2918 has no picture and audio only a blue screen
When you switch on the television, you only get a blue screen. No audio and no picture. I have tried to surch for channels but there is none. It is not brand new and has the channels already programmed onto it but recently lost the picture. Please inform me on what could be wrong.
  • nestled Oct 02, 2007
    when you auto search it passes through all the frequencies and does not pick up a channel
  • 790 Answers
Try to auto search!
Posted on Oct 02, 2007
  • carlos fernandez Jr.
    carlos fernandez Jr. Oct 03, 2007
    you make sure your antenna cable is in good attached in to your TV and to elements of the antenna!
    Genius:
  • 1,694 Answers
Have you tried the a / v inputs?? If they work,might be a bad tuner.If they don't work,then your symptom is no video-no audio=
power supply problem? Check all voltages....T.
Posted on Oct 25, 2007
SOURCE:
My SANSUI tv model SV2918 pictures are waving right to left or left to right. Kindly let me know the fault I will fix it. I love Sansui. S. Muyambango, Zambia
Glad someone loves SANSUI...cause I don't, In my opinion they're a poorly engineered TV with lots of issues. What your describing sounds like a pincushion issue, if you have the service manual check various voltages in that circuit, without seeing a picture of what its doing that is only a guess however..
Feb 23, 2018 | Sansui Televison & Video
No heater for tv model no.SV2918
Check the continuity of the CRT heater [pin 1~8]. If it is found open, no need to proceed. If it has continuity, check the AC voltage there when the LOT works. Should have about 6.2VAC. If not, check all the solder terminals and series resisotr. connected to this bus. Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Jun 10, 2016 | Sansui Televison & Video
Sansui sv2918 has no picture only audio nd blank tv
Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Feb 09, 2016 | Sansui Televison & Video
Sansui sv2918
it might be the audio amp acting up when cold they have caps in the audio supply that dont have the correct value till it warms up. that is located on the main board
Oct 15, 2013 | Televison & Video
I have a sansui tv model sv2918,it doesn't play
The TV has some firmware defect. Seek tech support.
Unplug it from AC mains wall socket, and plug it again after 5 minutes. This must make it a hard reset.
May 31, 2012 | Samsung Televison & Video
Tv not switching on Sansui SV2918, replaced faulty PTC and trans D2449 for lopty switching
all the transistors ,& capacitors i.e 47mfd 63v or100mfd 63v must be changed before u on the tv. if 300v is not coming to middle pin of d2449 then 4.7ohm resistor(fusible) may be gone
Mar 24, 2010 | Televison & Video
SANSUI SV2918 switches on after 30 minutes
Failing power supply. It takes 30 minutes to recuperate, then fails again.
Feb 07, 2018 | Televison & Video
Hi I live in Kempton Park South Africa and my Sansui TV Model SV2918 does not swith on. The product is very good and I would like it to b repaired. Do you have suggested maintenance people that I coul
Hi, I need assistance re tuning my TV for the VCR. I am not able able to get the two solid test lines. My TV is a Sansui SV2790NICAM and the VCR an Orion.
Please help!!
Mike, C.T.
May 25, 2009 | Televison & Video
Sansui tv sv2918
replace vert IC301, C432, ( D431 & R431 should also be blown)
Jun 18, 2008 | SansuiM1315 TV
TV Will not fire up.
try this,hang the collector pin of the HOT then try to switch on check the voltage its 115v dc,and check also the oscillation drive at the base of HOT take your VOM at 10v ac,ther must be a flactuate at the pointer.if the two procedure are good.plyback is deffective.but if u dont have any measured voltage at the collector of HOT ur problem is in the power supply. mc44608 is use at all old model philips tv.email me for wat happend
Dec 03, 2007 | SansuiM1315 TV
Sansui DTV2760 27" TV Logo
726 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
