Saporo iron has no steam, on light isn't coming on but it did get hot, can anyone suggest any possible reasons or solutions to this problem, please??
If you have been using tap water in your iron, and your water has lime or calcium in it, then the iron is probably clogged up. You might try using a product like "Lime Away". Read the warnings on the bottle first. Don't get it on your skin or in your eyes. Don't breathe the mist or steam. The bottle I looked at also had warnings about how it would mess up some counter tops or sinks.But if the iron doesn't work anyway, carefully pour some into your iron maybe about one fourth full, then carefully shake the iron to get the stuff all over the insides of the iron holding the iron like you would if you were ironing. Let the iron sit for a bit, then shake it again, maybe a couple more times like that. pour it out into an old bowl that it wont ruin, and see if there are a lot of minerals in the liquid. If there are, that may have cleaned it enough to start working again. Pour enough water in the iron until it is half full, plug it in and turn the temperature up to where it will produce steam, but don't iron any clothes yet because there is still cleaner in the iron. turn the iron so it is like you are ironing, but don't let it touch anything. Hold it over something like some old rags. If steam comes out, don't breathe it, but let it come out for a little while. Pour out that water and refill with fresh water and let it steam over the rags again. Pour that water out and all the chemicals should be flushed out of the iron. Carefully wipe the hot plate off to get any chemicals off the plate. Good Luck
SOURCE: Brown spots coming from steam iron
you can mix 50% water with 50% vinager let it set in the iron overnight then turn it on and let the steam run out.What happens is the inside of the iron where the water is had corroded or rusted or has lime deposits.the vinager will break this loose overnight.also after you let the iron steam out all the mixture,flush the iron 4 to 5 times and start using fresh water from a store bought gallon.your tap water is probably full of iron.
SOURCE: Rowenta DA75 - Won't Steam
Can you remove the steam button if you can fill with water heat to maximum and holding over sink remove steam button rod this will clean the steam traks but be careful this gets very hot.
Thanks J
SOURCE: No steam
It appears that your rocker switch is broken, I am attempting to find a source for the switch and the screw driver that removes the screws holding the unit together
SOURCE: Hinari steam vapor iron Model HIN001
More complete answer...
If you are having steam problems then the cartridge needs changing.
I phoned them (0161 652 1211) and they do sell the cartridge for £5.99 including delivery but are out of stock for a couple of weeks. You have to send them a cheque or postal orders. Good luck.
Send Cheque for £5.99 for each cartridge with note of model etc.
Pulse Home Products Ltd.
Middleton Road
Royton
Oldham
OL2 5LN
SOURCE: Iron not heating up...
I had the same problem. There is a thermal cut-off switch mounted to the top-side of the base-plate. Unfortunately, you have to completely disassemble the iron to get to it. It is an easy replace, just make sure you take good notes on how it's all wired and put together. To disassemble the iron, I did this:
- Mount it in the cord base and move the switch to the "wireless" setting to remove the cord assembly from the iron.
- There are 2 small while nubs on the bottom of the blue plate in back. These are plugs. Pull them out to expose 2 screws.
- Remove these two screws plus the one in the center of the back blue plate.
- Pull the blue plate from the back of the iron and MARK all wires so you know where they go, then remove them.
- You will see 2 screws into the blue plastic base-plate at the back. Remove these.
- Open the door at the front of the iron where you pour the water in.
- Pry the spray nozzle at the bottom out (pry it forward). This will expose a third screw into the blue part of the base-pate. Remove this screw.
- Pull the white plastic and blue reservior away from the blue plastic base-plate. This will expose three screws into the metal bottom plate. Remove these three screws (on in front, 2 in back).
- Pull the blue plate away from the bottom metal plate. This will expose the thermal cut-off. There is a screw with a small metal clip holding it down. This is the part you will need to replace.
I bought my replacement part from a local electronics store. On mine, it was a 240 degree C cut-off. The part I used was from NTE. Part number is NTE8242. It cost me $1.40.
I suspect the reason this blew on my iron is because Oreck engineers didn't expect it to be plugged in all the time (my wife did not like the 'wireless' mode as it did not stay hot long enough so she uses it in 'corded' mode). If you use the iron on it's hottest setting in this mode, it appears that perhaps the plate gets hotter than 204C. That, or Oreck just got a lot of bad thermal cut-off parts and they are cutting off at a temperature lower than 240C.
