Question about JVC AV-A21M3U 21" TV
Tv trouble shooting
It is JVC AV-21FMG3B. the power led keeps blinking. but it doesn't turn on. please help me find the problem.
  • delane krause May 17, 2008
    My TV keeps jumping into timer out and can´t get it to stay on
    Genius:
  • 1,694 Answers
1)Check secondary fuse devices. 2)Check horiz output xistor=shorted? 3)replace w/equiv.or better part. 4)Check solder connects in horiz drive circuit. Replace small electrolytic filter cap in base circuit of horiz o/p==horiz drive xformer and xistor area,typically 1mf/160v,C531? 2b)not shorted==do step 4 anyway 5)still blinking?==check vert o/p,audio o/p and regulated o/p's
Posted on Oct 02, 2007
Jvc- 36f702. Powers up then shuts down right away and the red led blinks on the front panel?
Dec 03, 2009 | JVC AV-36F702 36" TV
RED BLINKING TIMER TV WONT TURN ON
Page 40 on the PDF link below may help - Ask me if you need further assistance.
Thanks
Len
http://resources.jvc.com/Resources/00/00/99/51798Cien.pdf
Feb 28, 2009 | JVC AV-32230 32" TV
JVC TV AV-32870 will not turn on. blinking timer light
Worth taking it in since it is hard to find a new TV for less than $300. I have a 32 inch JVC iart that for about 2 years would turn itself off and the timer light would blink. Only thing that worked would be to disconnect and turn back on. Eventually, the tv "popped" I could smell something that burned out and within 3 weeks tv went "dead" Took it to a tv repair place and replaced power unit for $150. I had similar problem with a 19 inch Philips and that tv has been going strong for 4 years since repair.
Good Luck
Oct 17, 2008 | JVC AV-32820 32" TV
Philips 42pf7321d/37 blinking power board question
The probleis with one of the maina boards and trouble shooting would have to be done to see which board is bad.
Aug 17, 2008 | Philips 42PF9630A 42 in. Plasma Television
JVC AV-35750 TV
I changed capacitor C926 (1000Uf 16V) on main board. It solved the problem. I went with 1000uF 63V as it was readily available...it's okay to go with higher voltage. It was hard to fit it on because of the larger size but it worked.
Jul 28, 2008 | JVC AV-35750 35" TV
JVC AV32260G COLOR TV
try resoldering vertical ic pins
Apr 19, 2008 | JVC AV-32260 32" TV
JVC TV
How old is this TV?
As Tv's age, the high-voltage suffers and they get darker. You can turn up the screen adjustment on the flyback transformer and buy some time but:
My experiance is to not put money into a TV that is over ten years old. TVs stress out their electronic components worse than almost any other electronic product. After 10 years, there are so many parts that are ready to fail that your are probably wasting your money trying to get any more life out of it.
Another option is to wholesale replace the main board from an outfit like Module Exchange at 972-298-1212
Be careful on buying a new one though. Often times, these new technology ones are much worse. Always Google the model number of the set you intend to buy and add the word 'repair' or 'complaint' to see if it is one of the many models that are customer service nightmares being produced by even the most reputable companies today.
Hope ya fix it!
Jan 30, 2008 | JVC AV-21meu 21" TV
Wont power up, red blinking light (on timer)
Refer to the trouble-shooting section of your manual. Usually, with this technology, the lights (Lamp/Temp) on these sets are also used at diagnosis/fault indicators... so, your manual should tell you what a flashing TIMER light represents. If the manual, doesn't provide this information, then ring JVC and ask one of their technicians.
Jun 26, 2007 | JVC AV-36F702 36" TV
JVC AV-27020 TV Blinking LED, Static Electricity on tube but no sound and image
Sounds like a bad main regulator IC.. Try putting a 100 watt light bulb across the main AC fuse, turn on the set and see if it will stay on longer. If it does, replace the main regulator iC. If it does not, then it could be almost anything in the sweep section of the set, and or in the regulation circuit of the power supply. Look for slightly swollen capacitors in the set. good Luck please do not forget to rate this thread.
Dec 10, 2006 | JVC AV-27020 TV
JVC AV-A21M3U 21" TV Logo
179 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
