Question about SanDisk Sansa e250 MP3 Player
Recovery mode where i get a "main image file" from, that works? I keep getting load main image failed switch to recovery. Everything i've tried has failed. Including all that is said on forums. Please help, cause im fresh out of ideas. Cheers, Trogg
  • 626 Answers
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted. http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe You need to put the device into "recovery mode" before you run the tool. - Turn the device off (hold power for 20 seconds) - Slide the hold switch into "hold" position. - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer. Then run the recovery tool. Select format when prompted. Best of Luck.
Posted on Oct 02, 2007
Sansa e280 Main Image Wont Load Problem, Plus firmware updater doesn't work
Do not worry! I had the same problem as you before and got it fixed perfectly! Go to this thread and read the instructions carefully.
http://www.anythingbutipod.com/forum/showthread.php?t=11233
Note that doing this will delete all files in your player, so I recommend you to save your files somewhere before doing this.
Dec 28, 2008 | SanDisk Sansa e250 MP3 Player
Load main image failed switch to recovery mode
follow the above steps but turn on the power button if nothing is happening. It's the only way I got my e280 to recovery mode
Sep 23, 2008 | SanDisk Sansa E280 MP3 Player
Sansa e200 load main image failed
i'm thinking that it has too much info on it, so it ets stuck when you turn it on.
Jul 31, 2008 | SanDisk Sansa e260 MP3 Player
Load main image filed switch to recovery mode
you need to update the firmware on it..i had the same problem but then it started working again once i added the firmware to it
Apr 16, 2008 | SanDisk Sansa e260 MP3 Player
Load main image failed, Switch to recovery mode"
If it still plugs in and works properly, you can try to format it or try to update its firmware with the firmware updater that you can download from sandisk.com and then click on download.
Jan 23, 2008 | SanDisk Sansa e250 MP3 Player
"Load main image failed
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Dec 30, 2007 | SanDisk Sansa e200 MP3 Player
Loading image failed
Try this;
http://rapidshare.com/files/67740173/e200fw01.00.12.exe____
Best of Luck.
Please RATE my solution at the bottom.
Nov 27, 2007 | SanDisk Sansa e260 MP3 Player
I get - 'Load main image failed. Switch to Recovery mode'
Oct 08, 2007 | SanDisk Sansa e250 MP3 Player
Load main image failed switch to recovery mode is on my screen and it is black I cant get it to do anything how do you reset it or switch to recovery mode?
(( Switch your Sansa E260 to its Recovery Mode: 1. Make sure the player is powered off 2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface 3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button. 4. keep your fingers pressed on these 2 buttons until the E260 LCD screen displays "Welcome to Recovery Mode" 5. Connect your E260 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above) 6. Double-click on "My Computer" and you would see your Sansa E260 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6. Next, Apply the firmware for the E260 (your player should be connected to your PC at this time): Step 1: Use this link to download the firmware for your Sansa E260 (for better results, please save this file on your "Desktop": http://www.sandisk.com/Assets/File/Downl... Step 2: Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred. )) When i get to step two, and did what it told me, i get this ( Application failed to read the version details ) What should i do?!?!?!?!
Aug 05, 2007 | SanDisk Sansa e260 MP3 Player
go to sandisk and go to support there you can find support the recovery software. hope it helps
Jun 16, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
55 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
