Tv trouble shooting
It stopped to turn on. i found the 102, 1kv and the 2.7 ohm fusable resistor blown. i replaced them and the str with new once. but it still doesn't start to turn on. now i have input but no output voltage at the str. i'm confused. can u please help me find the possible defected compenet?
  • 10 more comments
  • Lope Dec 07, 2007
    Tv lill not turn on, light keep flashing next to power button
  • dcgs70 Dec 12, 2007
    no picture flashing stand by light
  • Neecie Feb 02, 2008
    The tv won't turn on, but the red light is still flashing. I've tried unplugging it for a while and that didn't work either. Please help!
  • Justin Yoko Feb 26, 2008
    I have a problem with my tv shutting off or going in like a stand by mode the red power button flashes. It only does in when i am watching cable tv if i put the tv in video and watch a movie it will be fine no problem at all. I am not sure but i found in page 57 of the manual that there is an auto power off feature that kind of expains whats going on but it doesnt tell how to fix it. i was wondering if u would know the problem and be able to help?
  • MelMcC Apr 06, 2008
    I am having the same problem. TV will not power on, but red light flashes by the power button. I have not fix.
  • Anonymous Apr 26, 2008
    red light keeps flashing and will not go to green light.
  • rafaellugomd Sep 02, 2008
    what is the cost to fix this problem.  IT does the same thing that this man described.  The TV makes a noise and then the stand by light flashes and nothing happens.  Sometimes it goes off as soon as I turn it on.  Ne picture at all and no response to any other commands
  • Edgex700 Sep 26, 2008
    Tv just wont turn on. any help?
  • dederice Oct 08, 2008
    TV will not turn on...any solutions on what the problem is????
  • mariom73 Jan 14, 2009
    I also have the same problem stand bye lights blinks on and off but tv does not turn on
  • klienschatz Feb 09, 2009
    I have the same problem. my t.v. is in the garage,so I thought it was the weather that effected it.still does not work.
  • Anonymous Feb 18, 2009
    My TV had the same problem. I just turn it off and back on right away, it retured to normal. Now it failed to turned on at all.
Tv wont come on code flash 2
Posted on Oct 19, 2008
In my unit, near flyback transformer resistor blown and i found out in the power transistor w/ no. d2102 shorted.
Posted on Mar 04, 2008
What the fuck. speak english
Posted on Feb 03, 2008
    An expert who has answered 500 questions.
  • 556 Answers
Whenever any fusible resistance fails means there is a short ckt in tv. failure is mainly due to main filter cap or rectifire diode os switching ckt failure(here as you cleared str.) remember while servicing power supply isolate hor. section for safety purpose.& connect it only after power supply output is ok &after checking parts in hor. ouyput section. if this seems to be ok then go for hor.output ckt failure like hor output,flyback transformer & cap& diodes connected with it.
Posted on Oct 02, 2007
  • manahar modern Oct 05, 2007
    what you asked was answered.
    your set has short ckt problem &that has been answered.
    but still you are telling not helpful means you your self do not know what you have asked.
    is it true?
Convergence Resistors keep burning up
Some simple advice---if resistors are smoking one of the chips is shorted----The set has two voltages that go to them--one a positive voltage and one a negative voltage.
If either chip is shorted you can replace the resistors all year and not get anything. The resistors are protection in case one or both chips short----
Remove all old heat grease and install two new chips and replace the resistors at the same time.
Note that the set may have pico fuses on the power board also.
Jun 09, 2012 | Sony Televison & Video
What is the first step in troubleshooting color television? dead set..blown fuse..
You haven't specified anything about your Sony Tv. No model number or anything to compare. Although I hereby giving you a general trouble shooting method, first adopted by technicians like me. You have stated that the fude has blown out. Fuse will not burn out without any reason. it is a protective device used in every telivisions,as if any internal components inside it gets shorted, especially in power supply section, the fuse will get burned and protect the other components from further distruction. Therefore you have to trace the reason for the failure of fuse first.
You must beging it from power supply regulator section itself. Chech the resistance accross the main filter capacitor first. Set the multimeter in Ohms range, and the resistance must be above 250Ohms in one direction, and upto infinite in the other direction. If both readings comes below 20Ohms or so, suspect the power regulator Ic; usually sony sets udes STR type regulated power supply, and this STR will get shorted. As you haven't specified your sets model, I can't make sure whether it is circuted with STR or a switching transistor. As both cases, this regulator has a chance to get shorted. Desolder it out and check for short. if it finds shorted, check the rlated components also, such as zener diodes and resistors, for open and short,as they also will get damaged due to this main switching transistor, or STR; whatever may be.
Check the degaussing posistor for short. Check the rectifier stack for short. Check the mains filter capacitor for short. Check each and every diode for short. you must measure the forward reisistance of diodes with multimeter set in 100KOhms range. There shouldn't be any slight leak with this test. If it shows a slight leak, replace it. You just do these and inform me the result through Fixya. I'm ready to assist you furthermore. When you reply to me; please include the model number of your Sony Tv. Ok.
Dec 12, 2010 | Sony Televison & Video
I have 55" akai rear
You are going to have to look for open PICO fuses along with bad bias resistors close to the ic's. You should have close to +27 and -27 volts of B+ on the chips to start with. That will ensure the fuses are good. Then trouble shoot the convergence circuit from there.
Nov 26, 2010 | Akai PT5598HD 55" Rear Projection...
Color seperation but still have a picture
Problem with tv is convergence-unit is made by samsung.You can eithor replace the convergence board or trouble-shoot it yourself.
gonna need to replace both ics STK392-040-then check all the 3.9 ohm resistors
Sep 10, 2009 | Akai PT5598HD 55" Rear Projection...
TV will not turn on
Replace shorted Q431,can use a 2sc3998, open r448 .47ohm resistor. after you get set on beware of convergence ic's may have been shorted causing all the problems.Check r859 &r858 .47 ohm 1 wtt that supply - &+ 20 volts to convergence packs, if open replace packs & check low ohm resistors on convergence ,I found r2144 &r2145 open replaced & all systems go "good luck"
Dec 26, 2008 | Akai PT5598HD 55" Rear Projection...
this is because R001 is not 5.6 ohms, it's 560K ohms
Nov 10, 2008 | Akai PDP4225M 42 in. Plasma Television
I have a resistor problem in sanyo ST-21G1
it's very difficult to give the exact value of that resistor.,but i can give some tips to find the value of the said resistor .( find how the resistor works, it is a dropping or fusable? if fusable used .47 or 1 ohm resistor if it is a dropping resistor you should make a trial and error .from 100k,10k or 1k.
Oct 29, 2008 | Televison & Video
Panasonic dmr-e55 dvd player
Sounds like a faulty diode on the power supply. If you know a bit about electronics then investigate, if not find a competant technician. Good luck.
Sep 25, 2008 | Panasonic DMR-E55 DVD Recorder
Samsung HCN4226 Convergence.
Did you remove one side of the resistors from circuit to check them? If you leave them in circuit a blown resistor will test good as it will read the resistance from the surrounding resistors. Usually its the 3.9 ohm resistors identified bu the bands orange,white ,gold and red. and also the 150 ohm identified by the bands brown, green, brown and gold
Jun 23, 2008 | Televison & Video
Tv repairing
You still have something open in power supply. Look for a fuse resistor or bad relay.
Sep 23, 2007 | Sony KV-27S22 27" TV
Televison & Video Logo
1,684 people viewed this question
Top Televison & Video Experts
