Question about Microsoft Windows 98 for PC
Unidentified When i switch on my PC i can see a command box after all the proper loading. SPYGUARD.DLL FILE IS LINKED TO MISSING TO .... what is the problem Should i contact a program vendor or any service man
  • Anonymous Mar 23, 2008
    spyguard.dll,is missing
A want connected for may pc/ NEC
Posted on Jul 08, 2008
  • 363 Answers
- Could you post again with the full error message? -
Posted on Oct 02, 2007
    President:
  • 2,961 Answers
This is a spyware programme, where the programme can no longer run because the link has been removed, do a search for the SPYGUARD and delete anything to do with it or install ccleaner which will clean the registry for you. http://filehippo.com/download_ccleaner/
When i am opening it, it is showing the program cannot start because loader.dll is missing from your computer try reinstalling it
Microsoft is constantly updating and improving Windows system files that could be associated with Loader.dll, sometimes resolving your DLL problems may be as simple as updating Windows with the latest Service Pack or other patch that Microsoft releases on an daily basis.
To help you install Windows update, please follow the steps given below:
- Steps used in (Windows XP, Vista, 7, 8, and 10).
- Click the Start button.
- Type 'Windows Update' into the search box and select it.
- The Windows Update dialog box will appear, if updates are available, click on 'Install Updates' button.
- After installing Windows Update, it is recommended to restart your computer once and then try using the computer.
If issue persists, you can use a built-in utility called 'Microsoft Register Server' (regsvr32.exe) to re-register your Loader.dll file.
In some cases your DLL file may not register properly and so you may get the error. To help you register Loder.dll file, please follow the steps given below:
- Type 'command' in the search box... DO NOT hit ENTER yet!
- While holding 'CTRL + Shift' on your keyboard, hit ENTER.
- You will be prompted with a permission dialog box and click Yes.
- Type the following command: regsvr32 /u Loader.dll and hit ENTER, this will UN-REGISTER your file.
- Now type the following command: regsvr32 /i Loader.dll and hit ENTER, this will RE-REGISTER your file.
- Close the command prompt window and restart the computer once again to check if the problem is fixed.
GuruAid.com
May 13, 2016 | Computers & Internet
Cant sign on to computer
    • 1 Download the missing comctl32.dll file. Locate a website that offers the comctl32.dll file. You can also use the link in the Resources section.
    • 2 Unzip the download file if it is a .zip-type file. Right-click on the file and choose "extract" to make the file available in a .dll format.
    • 3 Install the missing comctl32.dll file in the proper folder on the computer. If the operating system is 64-bit Windows, copy comctl32.dll to the "C:\Windows\SysWOW64" folder. If the operating system is 32-bit Windows, copy comctl32.dll to the "C:\Windows\System32" folder.
    • 4 Restart the computer by clicking on the "Start" button and selecting the "Restart Computer" option.
    • 5 Open the computer program that previously displayed the error message stating that the file comctl32.dll was missing. This will verify the program now works properly.
Nov 21, 2011 | Dell Latitude D 600/610
HOW DO YOU REINSTALL DLL MISSING FILE AND PARENTLOGIC FILES
What you have to do is find the .dll online somehwere, then copy and paste that file into your system 32 file. (C:- > Windows > system32).
You do not ever want to edit any other files other than doing that. You should be able to do the same thing with the parent logic files.
Hope that helps!
May 11, 2011 | Dell Computers & Internet
Unable bootup & error prompt that HAL.dll file missing or corrupt
CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location. Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
Resolution
  1. Restart the PC. The hal.dll error could be a fluke.
  2. Check for proper boot order in BIOS. You might see the hal.dll error if the boot order in BIOS is first looking at a hard drive other than your main hard drive.
    Note: If you've recently changed your boot order or recently flashed your BIOS, this may be what's causing your problem.
  3. Run Windows XP System Restore from a command prompt. If this doesn't work or you're receiving the hal.dll error message before you're able to complete this process, move on to the next step.
  4. Repair or replace the boot.ini file. This will work if the cause of the problem is actually Windows XP's boot.ini file and not the hal.dll file, which is often times the case.
    Note: If repairing the boot.ini does correct the hal.dll issue but the problem reappears after a reboot and you've recently installed Internet Explorer 8 in Windows XP, uninstall IE8. In this specific situation, IE8 could be the root cause of your hal.dll problem.
Nov 09, 2010 | Acer Aspire 4720 Notebook
How to repair missing wininet.dll?
If you see an error related to the wininet.dll file being deleted or missing, copy this file from the c:\windows\system32 directory of a working Win XP Pro
or Win Vista computer onto a flashdrive, then use the following procedure to copy it onto the failing system.
  1. At the boot screen (the first thing to appear at power-up), hit the F8 function key.
  2. Select 'Safe Mode with Command Prompt' and continue.
  3. In the command prompt window, type the letter of your flash drive, either d: or e: until the drive appears as e:> in the prompt window.
  4. Type 'dir' to see the wininet.dll file on that flashdrive.
  5. Once you see that file, type 'copy wininet.dll c:\windows\system32'.
  6. Unplug the flashdrive and reboot the failing PC.
Once you succeed in reviving the failed computer, go to c:\windows\system32 and right click on the wininet.dll file then copy and paste it to a save name (recommended name: wininet-copy.dll). This allows direct copy of that file back into wininet.dll if the problem reoccurs.
If you suspect an anitvirus engine or some other application deleted this file - and if it occurs again, make note of what was being performed, immediately before the failure mode. This will lead you to the offending program needing attention.
Good luck, hope this helps.
Aug 07, 2010 | IBM NetVista PC Desktop
How to repair operating system
Hi, You have to save it in Windows\System32. You may have to register it if you have more recent version.
Re Registering Procedure for the .dll file:
  • Get the Command Windows.
  • Start -> Run -> Type in cmd and hit Enter.
  • If you use Vista or Windows 7, type Run in the search box to get it.
  • Then you need Regsvr32 to Re Register the Dll.
  • Type Regsvr32 /? in the command window and hit enter. If you get a Dialog Box that means its functioning.
  • If you do not have it however, you have to download it from here. Place the file in Windows/System32.
  • Now in the command Windows type this and hit Enter.
  • Regsvr32 C:\Windows\System32\msvcr71.dll
  • If you see a message box with a success message, you have done it correctly.
  • That's all!
  • Please be kind enough to Rate the answer! Thanks for using Fixya!
    Jul 11, 2010 | Microsoft Windows XP Home Edition
    Missing DLL files
    hi,
    http://www.fix-all-dll-errors.com/
    Just visit this site...this will help in case of missing or for downloading dll's or also if there is errors in dll's..!
    I also registered few dll's from this site...worked in my case :)
    Apr 08, 2010 | West Wood Studios Command and Conquer...
    Dll missing file corruption data missing cant open application help
    Search for the missing DLL file using search option in windows explorer. Copy the same to system32 folder and register the same using regsvr32 command.
    e.g.: type regsvr32 XXXX.dll in Run command.
    Revert back for more clarifications or assistance required.
    Dec 12, 2009 | Caere Lone Wolf TimeWolf Plus 3.0 Full...
    Tsbyuv.dll is missing in windows xp home edition
    http://www.fix-all-dll-errors.com/tsbyuv.dll/
    You can get find it here..follow the link. :)
    Oct 30, 2009 | Microsoft Windows Xp Home Edition Sp2...
    Install missing dll file
    Dear
    If u have missing .dll file (download from web)
    copy .dll file to c:\windows\system32
    go to run and type (if ur dll file is abc.dll)
    regsvr32 abc.dll
    and press enter n ok
    Oct 19, 2008 | Computers & Internet
    Microsoft Windows 98 for PC Logo
    Top Microsoft Computers & Internet Experts
    micky dee
    Piyal Perera
    Piyal Perera
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
