Sorry you are having issues and I hope this information helps. Personally I would replace the entire ice maker not just part to correct and issue. But, the fuse (must test first) is a temperature blow fuse to protect the freezer from over heating issue during harvest, with this being said, it is located in the red wire that connects to the ice maker directly. I have seen this blow before but is way from a faulty ice maker. If you elect to change this make sure you replace it with the same one, DO NOT BY-PASS. Your issues will be likely in the control to the ice maker itself, this unit controls water flow, heater function, temperature control (both ice and heat) and harvest.
I hope this answered your questions, remember 110v is present at all time to that harness, be safe and unplug unit first.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
SOURCE: Ice maker not working
It's possible that the tube that supplies water to the ice maker is blocked with ice (freezer temp. too cold) and not allowing water to get to the Ice tray.
You can squeeze the tube to see if it's iced, and if so you can melt the ice with a blow dryer and adjust your freezer temp. to the manufacturer's suggested setting and work from there.
I have seen this happen, but there are other problems such as just a broken ice maker too.
Good luck.
SOURCE: whirlpool icemaker not making ice
There are instructions available to repair this problem at www.AnyoneCanFixIt.com. They also sell the part needed to make the repair. Common problem on these refrigerators that were made in about 2005 or later and have the ice bin bucket on the door.
