Question about Acer ALW 3016 Networking Switch
Home networking I have an internet connection on 1 PC using a one port ADSL DB102 modem (streamyx line). I wanted to access the internet from another PC at the same time. I have connected my 2 PCs as per the manual. I can see the PCs within the workgroup but am not able to access it. I can also see the LAN icon on both PCs. I still cannot go into the internet. I can only use 1 PC at one time to access the internet. Is there any configurationn that I need to set under the LAN properties - getway or DNS or anything of that sort. Pls advise.
TQ, for helpful. but after i do like your com my mozilla firefox 3.0.1 and my computer is hanggg, but for downloader is very2 good. why this setting effected to my computer to hangg?
Posted on Aug 20, 2008
    Brigadier General:
  • 6,966 Answers
Hi nurzailyn, If your DB102 modem is connected to one of your computers, say PC1, then the Ethernet/Lan port of PC1 is already being used. How is PC1 then connected to the second PC,say PC2? Do you have a second Ethernet/Lan port? Or are you using a hub where both PC1 & PC2 are connected as well as the DB102 modem? I would assume the latter since as per your post "...can see...PCs...also see...LAN..." Now your problem is only 1 PC can access the Internet at a given time, therefore I would assume that BOTH can access the Internet BUT not simultaneously. If this is the case, then there is NO need to change any of your "LAN properties - Gateway or DNS or anything of that sort" on either PCs. What you need to change is the setting of ADSL DB102 modem (streamyx line). To my knowledge this particular modem as provided by your ISP (TMNet?) will only allow one PC by default. You have to activate/enable its router features to enable any number of PCs to share the Internet connection. On one of your PCs, open a browser: 1. login to the modem by typing "192.168.1.1" and username : tmadmin; password : tmadmin; 2. Click on the Quick Configuration button (leftside); 3. In Encapsulation choose PPPoE LLC; 4. Default Route should be Enable (very important); 5. You may have to enter your Streamyx username and password; 6. You may also input DNS numbers: 202.188.0.133 202.188.1.5 Pls confirm this with your ISP or Status check one of your PCs (that is currently connected to the Internet) by right clicking on the Networking icon (bottom right side) and clicking on the Status. Click on the Support tab, click on Details button, log down the DNS Servers; 7. Hit the Submit button (bottom); 8. Click on Admin (page topmost); 9. Choose Commit (save changes), then Reboot (leftside) to cycle the modem. 10.Upon reboot, pls verify that the modem's WAN Interfaces indicates a green PPPoE Encapsulation. Hope this be of help/idea. Post back how things turned up or should you need additional information. Good luck and kind regards.
Posted on Oct 02, 2007
    President:
  • 2,961 Answers
You need to go to control panel>network set up wizard on the pc which has the internet connection and when you go through the wizard amongst prompts select, allow other computers to connect through this computer and then finish off the wizard. On the other computer you do the same but, on this one select this computer connects via another computer on the network and again finish off the wizard.
  • Yolly Convento Oct 25, 2011
    Then the computer connected with the internet must be always open if you want to access the internet thru the other computer
SOURCE:
What kinds of ADSL access way divided into?
ADSL access namely use parallel twisted-pair cable access user home, using M connected PC, whether it's special line, virtual, routing, all leave twisted-pair and MODEM.White said again is to run the business broadband signal through the circuit access user home, using computer dial-up MODEM connection.As for the access network equipment, PON, connection cable trunk, wiring, equal twisted-pair, client PC, router, such as TV all need to slowly in the actual operation experience.
Oct 30, 2015 | Computers & Internet
How can I obtain a user guide for Acatel optus one touch 250 P/N16513 corded phone?
Optus Network Approved modem and equipment list
If you are supplying your own DSL modem and/or telephone filters, you must ensure they meet the requirements
below before connecting them to the OptusNet DSL network. Connection of unapproved equipment is prohibited.
The modem list contains equipment that has been certified by manufacturers as having passed interoperability tests
r
equired for use on a DSL network. If your modem make and model isn't listed below,
call Optus Customer Service for further information on
1300 309 333.
F
ully supported by OptusNet DSL Broadband Customer Service, the OptusNet DSL Broadband Installation CD-ROM will automatically
c
onfigure this modem.
D-Link ADSL Modem 302G
The OptusNet DSL Broadband Installation CD-ROM provides detailed information to manually configure these modems, and OptusNet
DSL Broadband Customer Service will provide limited connection support for them.
(Equipment Certification date in brackets)
F
or modems and routers other than those above, OptusNet DSL Broadband provides only the network connection settings needed for
manual configuration. While this equipment can be used on the OptusNet DSL Network, no OptusNet DSL Broadband Customer Service
will be provided for connection configuration or equipment-related connection difficulties.
Alcatel SpeedTouch - 510 ADSL Modem (15.01.2003)
Alcatel SpeedTouch - 530 ADSL Modem (15.01.2003)
Alcatel SpeedTouch Pro - 4 port (10.09.2001)
Alcatel SpeedTouch Pro - Firewall (09.10.2001)
Alcatel SpeedTouch PCNIC (04.08.2000)
Alcatel SpeedTouch USB (04.08.2000)
Askey/Dynalink - ALE 070 (08.01.2001)
Askey/Dynalink - ALH 110 (21.03.2001)
Askey - RTA100 ADSL Modem (25.10.2002)
Billion Electric - BIPAC-711 CE ADSL Modem (25.10.2002)
Cisco WIC - 1ADSL-DG (30.06.2003)
Cisco 827 (19.02.2001)
Cisco 827H (11.07.2002)
Cisco 827-4V (19.02.2001)
Cisco 837 (01.04.2003)
Cisco SOHO77 (29.11.2001)
Cisco SOHO77H (11.07.2002)
Cisco SOHO97 (01.04.2003)
D-Link ADSL Modem - DSL 100D (08.08.2001)
D-Link ADSL Modem - DSL 500 (08.08.2001)
D-Link ADSL Modem - DSL 504 (08.08.2001)
Efficient Networks - C10 Communications - Speedstream 3060 (08.01.2001)
Efficient Networks - C10 Communications - Speedstream 4060 (08.01.2001)
Efficient Networks - C10 Communications - Speedstream 5260 (08.01.2001)
Efficient Networks - Siemens - Speedstream 5400 (07.04.2003)
Efficient Networks - C10 Communications - Speedstream 5660 (21.03.2001)
Efficient Networks - C10 Communications - Speedstream 5667 (10.09.2001)
Efficient Networks - C10 Communications - Speedstream 5861 (21.03.2001)
Juni NetAce - ADSL USB Modem (15.01.2003)
Juni NetElite 2000ES - ADSL 4 port Modem (15.01.2003)
Juni/Samsung SAM-215 USB Modem (18.07.2001)
Juni/Samsung SAM-335A Ethernet Modem (18.07.2001)
NetComm ADSL Modem - BusinessSmart (08.08.2001)
NetComm ADSL Modem - USB - NB1200 (27.08.2002)
NetComm ADSL Router Modem - NB1300 (20.11.2002)
Open 501r ADSL Router Modem (05.04.2002)
Alcatel - Central, Part No. 3AU 04804 AAAA
Alcatel - In-Line, Part No. 3AU 04805 ABAA
Askey/Dynalink - In-Line, DT60-002BA
C10 Communications - Dynamic - In-Line, C10290
C10 Communications - In-Line, C10611 & C10611T
C10 Communications - In-Line, C10645 & C10645T
C10 Communications - In-Line, C10610
Te
l
ephone Equipment - Central, TE-ACP20AUS01
C10 Communications - In-Line, C10211
C10 Communications - In-Line, C10111
C10 Communications - In-Line, C10145
C10 Communications - In-Line, C10245
D-Link - Central, DSL-10SP
D-Link - Central, DSL-10CF
D-Link - In-Line, DSL-10MF
Alcatel SpeedTouch Home
D-Link ADSL Modem - DSL 200
D-Link ADSL Modem - DSL 300
D-Link ADSL Modem - DSL 300+
D-Link ADSL Modem - DSL 302G
Optus supplied modem
Optus preferred modems
List of all other certified modems/routers
List of certified filters/splitters
Information correct as at 2 February 2004.
1270049 06/04
Nov 12, 2014 | Cell Phones
Telecom Issue, when a Netgear router (DG834G) linked to a small server unit, dissconnects the telephone line. The router works fine but no dial tone on the phone side of the micro filter. Any assistan
a POTs (plain old telephone) line should never be connected to a router. that adsl filter does not make a phone line share a data line.
ADSL is a type of internet service supplied over a phone line. think of it as raw (unusable) when its on the phone line. then you use your dsl filter/splitter to feed the raw internet into a special dsl modem and the other port can be used by a standard phone.
you will know a dsl modem when you see it because its uplink or internet port will only be big enough to fit a phone cord into, not an internet cord. these dsl modems then feed usable internet to your routers and all devices on your network. but, like i said before, at this point it is too late for your phone and internet to share the same wire.
OK, thats not entirely true
pin out of RJ45 internet
1=orange/white *
2=orange *
3=green/white *
4=blue
5=blue/white
6=green *
7=brown/white
8=brown
1,2,3+6 are used in a typical network
if your network is typical you can "get fancy" and use 4,5,7+8 for telephone or even put 2 data lines on the same wire (not recommended for long distances). however, this may involve cutting some wires and splicing them together or something.
Sep 14, 2012 | NetGear Computers & Internet
I cant connect to two computers at the same time
How to connect....
1- Two Computers:
# We are connect two computers together to share Internet, printer, scanner, files, and even programs
We can do it through either way:
1- Use A Crossover Cable And Two Network Cards.Two network cards are installed in two computers.Then use crossover cable to connect them.
2- Use a Phone Line and Two Special Adapters Sold as "Phone line network Kit". Two adapters are installed in two computers. Then use existing Phone line to connect them.
Connecting Two Computers Wirelessly:
1- Wi-Fi
2- Bluetooth
3- Infrared
Several types of fixtures exist for home networking:
1- Hubs
2- Switches
3- Routers
2- Computer with the internet
Before you can connect to the Internet and access the World Wide Web, you need to have certain equipment. In brief, you must have:
-A computer (preferably running an up-to-date operating system); -
-A modem and access to a telephone line or a local area network (LAN) that is in turn connected to the Internet; and connection software that will allow you to establish an account with a service provider and access the Internet
You Need:
Modem: This converts your digital computer information into analogue telephone signals. Phone Line: his may be your biggest expense after the equipment.
Internet Service Provider (ISP): ISP has a permanent connection to the Internet.
ADSL: a newly standardized transmission technology facilitating simultaneous use of normal telephone services, data transmission of 6 Mbit/s in the downstream and Basic-rate Access (BRA).
ADSL facilitates the simultaneous use of normal telephone services, ISDN, and high speed data transmission.
Another advantage of having an ADSL line is not missing calls while you're online, as both voice and data can be transferred at the same time.
Jun 19, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Haw I can connect tow adsl line in one modem ?
Your connection should be like this:
PC --> Port 1 on the router
Modem --> Internet or WAN port of the router
Dec 18, 2008 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Wanting wireless hookup
1)Prepare your modem. Unplug the modem's power cord and place the wireless router unit next to the modem. If the router has antennas, make sure they are raised to their full upright position.
2)Reassign your networking cable. Unplug the cable currently connected from your computer to your modem and plug it into the port located in the wireless router. This port is usually colored blue.
3)Connect the router and the modem. Use the networking cable that came with your wireless router to connect the modem and router unit. The router port is typically colored in green.
4)Start up your modem. Plug in the modem's power cord and wait 1-2 minutes while it configures its settings and prepares to connect to the Internet.5
5)Start up the wireless router. Plug the wireless router's power cord into an outlet and wait 1-2 minutes to get it started. The router is ready when the 'wired computers' and 'modem' icons light up. These logos or icons vary by make and model of your router so consult the owner's manual if needed.6
6)Insert your installation CD. Use the wizard or assistant to check the configurations of your computer settings and launch your wirelessnetwork clip_image001.gif
Things You’ll Need:
  • Wireless Router unit
  • Networking cable (comes with router unit)
  • Installation CD
  • Modem
  • Modem power cord
Dec 02, 2008 | D-Link DI 713p (DI-713P) Wireless Router
Netgear DG834PN ADSL ROUTER AND HUB - PC dial-up connection
so your trying to use a dsl router as just a router -dsl with dialup?
Aug 06, 2008 | NetGear Computers & Internet
Zoom router
Have you tried configuring the ADSL modem router for the internet connection?
Its possible that since you have changed the ADSL modem router, you may have to configure the ADSL modem router for it to work fine. The configuration depends on what Internet provider you have but you may try these steps for now:
1. Make sure the connections are correct. Connect the computer to the LAN port and the ADSL line to the port assigned for that behind the device.
2. Launch an Internet browser and access http://10.0.0.2 and press enter. If a dialog box appears, set the user name as admin and password as zoomadsl and press enter.
3. On the basic setup page of the ADSL router, set the appropriate encapsulation and other settings based on the settings of your provider. If you do not know the settings for your provider, there is a table specified on the user guide for the ADSL router. Here is the link: http://zoom.com/documentation/adsl/5590_UserGuide_EngD.pdf
Jul 19, 2008 | Zoom X6 (5590) DSL Modem (55900003)
Networking
You actually have a couple of issues here. Fix these in this order. 1.) Login to router and turn off wireless (if you're not wanting to use wireless) 2.) Connect the ADSL modem CAT5 port to the WAN port of the Belkin router. 3.) Login to router and turn on NAT and make sure DHCP is enabled. 4.) On your Windows machine turn on DHCP under the network settings. This should allow your connection to be setup automatically and stop wireless access on the Belkin router. Let me know if you need more help. JC
Jun 24, 2006 | Belkin Wireless (F5D7130) 802.11g/b...
Open Questions:
See all Acer ALW 3016 Networking Switch Questions
Acer ALW 3016 Networking Switch Logo
240 people viewed this question
Ekse
Alun Cox
