My zenith tv is stuck on aux
My tv is stuck on aux, the volume works and i can get to a few menus, but can't change channels or do the auto-setup for channels
  • 5 more comments
  • coatrack Nov 27, 2007
    My screen is frozen. the word aux appears and nothing works, no sound or picture. I have tried to reprogram, and cant even get the menu, nothing. The set is completely frozen, the screen is black. I have turned it on and off. I have the orion 1934 19" set.
  • Anonymous Dec 07, 2007
    my sanyo tv is stuck on AUX. No sound, just a blank screen with AUX. The remote will not work. I can get to menu maunally but nothing happens.
  • Anonymous Dec 10, 2007
    Our sony tv is stuck on aux. it says aux at the top, and the channel button goes up but there is no picture or sound. we cannot pull up the menu button either
  • Kelly Broadus
    Kelly Broadus Apr 04, 2009
    my zenith tv is stuck on aux, the dvd plays movies on this channel , but it will not change channels ..no remote response ... the remote is working with other stuff and only blinks when i press the manual channel bottons ......
  • Jacqui Savattere
    Jacqui Savattere Oct 12, 2013
    my zenith model# TVBR1914Z is stuck on AUX and can't find remote ho do i fix this
  • Anonymous Mar 18, 2014
    auto setup of channels not working
    after we do auto channel setup
Try pressing the input button on your remote
Posted on Apr 21, 2008
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
Please check remote if it is ok try from front panel if that also does not work then check system control ckt& its associated ckt & also check for loose contct also.
Posted on Oct 06, 2007
SOURCE:
How do I switch from catv to antenna on model mwc13d6
First make sure that the TV/DVD player is on TV by pressing the Channel Up. (The channel up/down will rotate through AUX and any programmed channels.) You'll need the original remote or an universal remote that matches the Set-up function. Then press Set-up on the remote; it's to the left of Mute above Play.
Use the Up/Down arrows to navigate to Channel Setup. Press Enter to access the Channel Setup menu. Use the Up and Down arrows to select Auto Ch Programming and press Enter. Wait for the TV to scan all available channels. Afterwards, you can go back to the Channel Setup menu and choose Add/Delete channels. Press Set-Up again to exit the On-screen menu system.
Unless you have a set-top Digital-to-Analog converter attached to the TV, you will only get one of the few remaining low power analog stations, if you are close to the transmitter. This set only has an NTSC tuner. Most set-top boxes can be attached to the Antenna input and be set to Channel 3 or 4 or connected to the Aux input.
The Magnavox MWC13D6 was manufactured by Funai and the manual is available here: http://www.funai-corp.com/support/manuals.aspx . The direct link to the manual is MWC13D6 is http://www.funai-corp.com/support/om/MWC13D6.pdf .
I hope this helps.
Mar 24, 2015 | Televison & Video
My Philips LCD TV (26PF7321) is stuck in DTV mode, cannot access most menus, please help?
I would contact Phillips customer service by phone and see if this a issue common to this set and if there is a way to either do a hard reset or a software upgrade to resolve this problem.
Mar 19, 2012 | Televison & Video
Sylvania tv/vcr/dvd keeps going from channel 3 to AUX
Hi my name is Mike Houston of DISH Network, with the TVswitching between channel 3 and AUX there are some things to check to resolvethe issue. You will want to make sure all connections are hand tight from thereceiver to the TV and to the wall. After all connections are hand tight checkto see if the channels are still going back and fourth. If it still persiststry changing the remote address, I will send a link that better explains thissetup; http://www.dishnetwork.com/SupportSection/remote-setup
Nov 26, 2011 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
Tv aux channel issues
youll have to use the original remote to be able to do that still. always keep the original tv remote because of those issues.
Jun 02, 2010 | Symphonic ST420FF 20" TV
My admiral tv 32 inc goj12390 dont have the remote control and i cant see the dvd on tv scren beacause is only on chanel 3, 4 and i can put it on aux or imput
This worked for my Admiral TV model GRD15272:
Using the buttons on the TV, go to the setup menu, and scroll to "editchannels" by pressing "setup" button until "edit channels" ishighlighted. Then, using the channel up/down buttons, go to channel 91and press + volume. This should add the video input2_bing.gif to your channels. 92 is S-video. It is helpful to have what ever device (dvd player or game console) hooked up and powered on, so you know when you are on the right channel, but it should be 91.
Mar 08, 2010 | Televison & Video
Tv is stuck on aux
Push the "menu"button on the front of the unit. That will get you into the menus to adjust any setting, like caption, language (but that one is tricky if yours happenend to be set to a language you couldn't understand :P), brightness settings and the such are there too. The one you are looking for is "input", change THAT setting. with either volume up/down +/-, or channel up/down (+) (-). In the menu, change the "input" selection to cable or whatever you are trying to watch on the tv.
Hope this helped some, if so, please rate, thank you!
Channel setup
V-Chip Setup
Caption
ect.
Using the Volume + and - along with the Channel up (+) and down(- ) key's, will give you all the adjustments you may need without a remote control.key's, will give you all the adjustments you may need without a remote control.
Feb 02, 2010 | Durabrand DWT1905 TV
Tv code
Setup Instructions
  • Set the "Mode Switch" to TV.
  • Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
  • Enter the 5 digit Code above.
  • Try the volume and power button to tset the code
  • 2 possible codes for Element TV, 10835 and 10178.
    If that doesn't work, you can try searching through all the codes stored in the remote. Here's how you do it:
    • Set the "Mode Switch" to the desired mode such as TV for a Television.
    • Enter the code "991" followed by the "device number"
      1. for Televisions
      2. for "AUX 1" devices - VCRs or DVDs
      3. for "AUX 2" devices - Audio
    • You can step through the setup codes for this mode by pressing the "Channel Up" key to go forward through the codes or pressing the "Channel Down" key to go back to the previous codes.
    • You can try out each code by pressing one or more function keys such as power, volume or digit keys.
    • When you've found the setup code that works for your device, press the "Select" key.
    May 28, 2009 | Televison & Video
    Lost orig remote/ fpa lock on
    I have a 20f511t RCA Tru Flat with FPA lock on, using an universal GE remote press setup, then menu, channel down to preferences, press enter, channel down to FPA LOCK, volume up to change to on or off, press menu to remove, all shoud work now
    Nov 23, 2008 | RCA 20F420T 20" TV
    Viewing vcr
    Aux is used for a buncha reasons, video, dvd, etc.... How is your video connected to your TV? Many TVs have a remote control button to change input, or TV/VCR button, try tapping that if you've got it. need the model of the TV if not applicable
    Jan 08, 2008 | Sylvania SST4322 32" TV
    Remote control problems
    Feed cable signal directly to tv(no BOX) activate auto-program for channel memory.
    Oct 02, 2007 | Toshiba 20AF44 20" TV
    Televison & Video Logo
    1,360 people viewed this question
    Top Televison & Video Experts
    Ekse
