Cars & Trucks Logo
Posted on Apr 29, 2009
99 dodge 2500 5.9 cummins fuel pressure at 3psi
Fuel pressure is at 3psi, the transfer pump is running. changed air and fuel filter. the truck is starting fine. just lost of power. what could be the problem. thank Dan
  • Anonymous Mar 28, 2014
    truck will not start off key but will pull start and run fine until shut off
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 10, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1233
Points
8
The 3 psi is caused by a failed transfer pump. The problem the loss of could be the VP44 injection pump. This pump should be run at min 7psi. I had the same fuel pressure problem. I replaced my stock transfer pump with a FASS DDRP from www.usdieselparts.com. The stock pump is over $200 to replace and will fail again, sometimes right out of the box. The DDRP will supply about 15psi to the pump and is simple to install. I hope this helps.
99 Dodge ram 2500 with cummins diesel stalled and won't restart. Changed fuel filter, and determined that there is fuel going to injector pump.
loosen one fuel line to one of the injectors, try to start the truck and look for the fuel to spray out of the line. it should spray rather hard if the injector pump is working right. if it just dribbles or trickles out you have a weak pump.
What would cause me to keep losing power to the electric fuel pump on a 99 dodge 2500 24 valve cummins
the cause of your problem would be dirty injectors,and or dirty fuel filters on truck. check the filters and replace the fuel filters. also check your air filter . if it's dirty replace it as well. hope this will help!!!
06 cummins wont start
COULD BE GLOW PLUGS NOT OPERATING.CHECK GLOW PLUGS FUSE AND RELAY.THE FUEL TRANSFER LIFT PUMP NOT WORKING CHECK ITS FUSE AND RELAY.OTHER POSSIBLE CAUSES.STOP UP PRIMARY FUEL FILTER.AIR IS GETTING IN FUEL SUPPLY LINE.FAULTY INJECTION PUMP.OR FAULTY PCM.
2answers
2000 Dodge Ram won't start
try eather spray it in the air filter box then try and start if it starts then your not getting enough foule.
1999 dodge diesel 2500 seems to have a fuel related problem.
Please clarify the "loosing power" does it lose power and shut down or does it loose power but will idle? Your Cummins is electronically controlled so oil condition is important, fuel leaks, oil leaks, leaks in the air ducting between the turbo and the intake, sensors, water in the fuel. Do you get an engine light when this trouble happens? Dodge uses a lift pump to carry fuel to the the injection pump, is it working?
37helpful
5answers
Dodge cummins won't start, fuel reaching injector pump but no fuel coming out of injector pump.
You said you have fuel flowing from the inlet line of the injection pump? But not at the injector lines?
2answers
Dodge diesel, While pulling upon accellerating, truck gets jumpy
IT SOUNDS LIKE THE LIFT PUMP OR POSSABLE FUEL RESTRICTION CHANGE THE FUEL FILTER ALSO CHANGE THE AIR FILTER IF THAT DOSENT FIX IT YOU WILL NEED TO CHECK THE FUEL PRESSURE OUT OF THE LIFT PUMP BEFORE YOU WASTE THE INJECTION PUMP
6helpful
4answers
2004 dodge ram 2500 5.9 diesel hard to start
The lift pump is bad Check the fuel pressure with a test gauge.
2003 Dodge Ram 2500 Cummins Diesel
there is a technical service bulletin to relocate the fuel pump on this vehicle when the transfer pump needs replaced. there is the possibility the transfer pump is going bad on the 2003 now...its not good to run them low or out of fuel
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
