Question about Epson LQ-2180 Dot Matrix Printer
PAPERS PRBLEMS ASSOCIATED WITH LQ2180
WHEN YOU PUT PAPERS THE PRINTER IS REFUSING TO ACCEPT THE PAPER.AT THE BACK OF THE PRINTER,THE LIGHT NEAR PAPER OUT IS BLINKING
Paper jam
Posted on May 20, 2008
Check paper feed machanism and paper in sensor open your printer and clean the sencer
Posted on Oct 02, 2007
SOURCE:
Have a paper jam in my pixma ip4500 and cant see the paper anywher to take it out?
Paper jam I suppose is the commonest of all printer problems as it can occur due to strayed, stuck bits of papers in pathway of paper tray, outlet, roller etc. I would recommend cleaning the paper inlet, outlet, and other possible areas to avoid a paper jam situation.
Follow the given steps to clear paper jam
>Clear any loose paper from the paper tray. This will help you locate the jam. You will find it either in front, near the paper tray, or in the rear.
->To clear a paper jam near the paper tray, grip the paper and pull it firmly but gently from the printer. If you find a stack of papers jammed, grab from the middle of the stack and pull.
->For a rear jam, remove the back of the printer. When you find a free edge on the paper, grip it firmly and pull it out.
->Replace the back cover. Press the "Resume" button or turn off the printer, and then turn it back on. Your settings should reset.
->Try printing another document
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Mar 15, 2013 | Office Equipment & Supplies
False paper jam on hp laserjet 4345
Feb 06, 2013 | Office Equipment & Supplies
Past service life message on Epson C88+ message appears and will not accept new cartridges or try to feed paper at all. Since this printer is just for home printing and it doesn't need to print...
Check if there are any objects blocking the way of the printhead or if there are objects down the paper feed area.
Is your printer placed on a stable, flat surface?
Does it happen to all the papers that you are using? Are the papers in good condition?
Try loading only 10 to 20 sheets of regular paper.
do a printer check to isolate the issue. Turn the printer off. Unplug the usb cable from the printer. Hold down the paper button while you turn the printer on. Keep on holding down the paper button only. Let go of the paper button when the power light starts blinking. If it does the same, there is an issue already on the gear of your printer.
If your unit is out of warranty, log on to support.epson.com. Click on help me find a service center to the left of the page to contact the epson local servicers near your area. If your unit is under warranty, call epson.
Oct 03, 2011 | Office Equipment & Supplies
Put new roll in printer and paper feeds through then goes back out again
The printer should accept print paper ready for feed commands when computer sends jobs with clicks. A paper feeder tray may be clogged, attempt to open compartments to ascertain for misaligned or adjusted entrapment areas. Paper feeder adjustments that are tightened least allows feeder processing while loosened paper feeder clips allows several print papers at a time. Select the appropriate adjustment for the papers. Second, printers that run out of ink display sensitive malfunctions either as inability to feed paper when available. Ascertain that printer ink is available.
Jan 28, 2011 | HP PhotoSmart 130 InkJet Printer
Related t my Lexmark E232, I'm using a compatible toner but it put excess of ink in the papers. Then I bough a new original Lexmark toner, and when I put in the printer on two lights, from top the second...
Inspect the overall paper path for signs of spilled toner.Gently clean the contaminated areas with a soft cloth or compressed air.
If you need further assistance please contact Lexmark Technical Support Center.
Jan 24, 2011 | Lexmark E232 Laser Printer
Hello, My daughter was printing off her university notes perfectly tonight and all of a sudden my Samsung SCK - 1400 printer stopped printing and said [No Paper] Add Paper. So I added the paper and i...
there is a paper sensor in a paper tray where you put papers just near the pick up roller kindly check it out that it actuates when you put papers in it
Jan 20, 2011 | Office Equipment & Supplies
Paper jammed - how do I get it out?
  • Follow the below steps to clear the paper jam
  • To clear a paper jam near the paper tray, grip the paper and pull it firmly but gently from the printer. If you find a stack of papers jammed, grab from the middle of the stack and pull.
  • For a rear jam, remove the back of the printer. When you find a free edge on the paper, grip it firmly and pull it out.
  • Replace the back cover. Press the "Resume" button or turn off the printer, and then turn it back on. Your settings should reset.
  • Try printing another document.
  • Nov 05, 2010 | Epson Stylus Multifunction Inkjet Printer/...
    The printer will not load the papers
    Hi you may try:
    1) paper input sensor dirty, clean paper input sensor usually near the tray input roler area there is a micro switch or a led light sensor with two wires.
    2) paper input sensor fail or disconnect between sensor and socket on the board, you have to open the cover to check.
    Dec 22, 2008 | Kyocera Mita FS 1000+N Laser Printer
    My HP OJ 7310 all-in-one did not pick up papers.
    the first ting I would do is clean the paper feed rollers with a cotton pad and alcohol. The rollers may have a build up of paper dust that are makind the rollers slip.
    I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
    Sep 27, 2008 | HP OfficeJet 7310 All-In-One InkJet...
    Paper jam
    At the back of the printer... open the feeder door and slowly remove the jammed papers.... put it back and put some paper in the tray and press resume button... this will continue printing the remaining print jobs.
    good luck... happy FIXYA...
    Aug 20, 2008 | HP DeskJet F380 All-In-One Printer
    Epson LQ-2180 Dot Matrix Printer Logo
    414 people viewed this question
    Top Epson Office Equipment & Supplies Experts
    Inky Fingers
    Inky Fingers
    Clive
    Clive
    Alun Cox
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
