Question about D-Link DCS-5300G Network Camera
Dlink internet camera- transition protocol changes to http- in vista
We have cameras located in 5 remote places.All the five cameras are working perfectly in xp but only four cameras are working in vista. when i am trying to view the odd one i am getting the error message..I am getting this error message in xp as well but when i click ok its working but in vista it keeps on saying connecting.. pls help..
  • Anonymous Dec 16, 2007
    I've the same problem with the dcs 5300W camera. It keeps trying to connect but never succeeds...
  • dfr1954 Mar 18, 2009
    I can view my DCS-5300G on the Internet as long as it is Windows XP and Explorer 7. The camera cannot be viewed on Vista machines on Explorer 8.0.
Firmware ver 2.05
2nd DNS set as 61.31.233.1
Posted on Apr 14, 2009
SOURCE:
What is a computer IP address?
An Internet Protocol address (IP address) is a numerical label assigned to each device (e.g., computer, printer) participating in a computer network that uses the Internet Protocol for communication.[1] An IP address serves two principal functions: host or network interface identification and location addressing. Its role has been characterized as follows: "A name indicates what we seek. An address indicates where it is. http://en.wikipedia.org/wiki/IP_address
May 04, 2014 | Nikon Coolpix S9100 12.1mp Digital Camera...
I have a sentient cctv dvr from Maplin I can view it on my phone at home which is fine I wanted to know if I can view camera footage when I'm not at home etc. at work
Yes you can definitely view your CCTV footage on your mobile phone at your work via internet. Sentient CCTV DVR basically is a night vision camera. You must know the IP of the camera and IP Video server. Connecting your phone to CCTV camera via the protocol you can view the CCTV footage's in your phone. Night vision cameras are used for surveillance purpose. I would prefer cctv camera with ir illuminator for good image quality in the night time that will clear footage quality in my phone.
Recently many new applications have also being launched by security cameras with a view to solve problem you mentioned.
Jul 05, 2013 | Home Security
I hope a simple queston , will a D Link Wireless Camera DCS 2120 work on a vista 64 bit OS regards Gordon Henderson
Hello!
Here is the review:
http://www.dlink.com/products/?pid=500
Check specifications (minimum requirements described, so it should work).
Just to be sure, I advise you to contact producer.
Regards!
Jun 20, 2011 | D-Link DCS2120 Network Camera
Explain how to go about using a static or dynamic link to access a remote computer that has an ethernet PTZ camera from d-link install so that the camera can be viewed remotly.
you need to do some port forwarding and possibly use a static address assigned to your camera.
remotely is this context means being able to access the camera feed when the camera is behind a router. in essence what you are trying to do is this:
camera ------ (private) router (public) ---------- internet ------- remote user.
the private side or your router is the one that you control, the private side is what is known as being "behind the router"
your router requires to be able to forward traffic from the public side for this you need to do some port forwarding.
a practical example that you can follow can be found in this website if you look into the Support Resources>FAQ section under the title "How do I remotely view DCS-6620 or DCS-6620G series cameras that are behind a router or gateway?"
the article from dlink goes like this:
For each camera that resides behind a router or gateway, three ports must be forwarded by the router to obtain both audio and video. If audio is not desired, only the HTTP port will need to be forwarded. The three default ports are as follows:
  • 80 (TCP) HTTP Port (allows access to web-configuration and transmits video if other ports are not forwarded)
  • 5002 (TCP/UDP) Audio Channel Port (transmits synchronized audio)
  • 5003 (TCP/UDP) Video Channel Port (transmits synchronized video)
These port numbers will need to be changed in the camera configuration on each additional camera that is added behind the router. Port numbers can be changed from the Advanced > Network screen.
please look in to the section described within the link to see how camera and router need to be configured.
I hope this helps!
Apr 07, 2010 | Computers & Internet
Need softwear to load pictures from camera to computer
http://www.fujifilmusa.com/shared/bin/PTPDRV%205.5.zip
this is the protocol that fujifilm use for his model ...Im not sure if its vista compatible ..but it will work perfect in XP...good luck and dont forget to rate me ...
Oct 25, 2009 | Photography
How to connect to remote camera
To create new Camera Window
  • Click New Camera from the File menu.
  • Camera Setting dialog box appears.
Camera Setting dialog box helps you control selected video source. To open the Camera Settings dialog box, select Camera Settings from the File menu.
Set a preview rate in the Preview Frame Rate box. It indicates the number of frames per second in the camera window. The default value is 10 frames per second. This value doesn't interfere with broadcast or record frame rate.
Remote Cameras
Remote camera is another Active WebCam program with enabled Remote Access launched on remote computer. Both programs use UDP protocol to communicate each other. If connection with Remote camera goes through firewall, make sure that the IP address of your computer, local and remote ports are opened on the firewall, and the UDP protocol is enabled.
To connect to Remote Camera
In the Device tab click to select Remote Camera.
Specify the computer address in the IP address box. Don't place the protocol prefix (like http://) in the address, just four digits of IP address delimited by dots, like: 192.168.1.101. You can find out the remote computer IP address by clicking Get Computer IP Address from the Tools menu on the remote computer.
Type port, which is opened on remote computer for remote access in the Remote Port box. This value is specified in the Port box in the Broadcasting | Remote Access properties on the remote computer.
Specify port, which will be used to receive data from remote camera, in the Local Port box. If your network uses firewall, make sure that Local Port and computer's IP address are opened in the firewall. Use the Check the Port Availability button to make sure that this port is not used by another program.
If the remote computer requires authorization, enter user name and password in the appropriate boxes. The authorization could be set in the Broadcasting tab in the Camera Settings window in the Remote Access Additional Settings window on the remote computer.
If the Remember Password check box is checked, the user name and password will be saved among the session parameters.
Cycle through cameras
If you have multiple cameras you can set up a cycler to have the program to change cameras automatically.
To configure the Camera Cycler:
  • Click Camera Settings from the File menu.
  • Select Cycle through cameras to activate cycler.
  • Type cycler interval in seconds.
Select cameras to cycle.
Jul 13, 2009 | HP USB Web Camera
LG Split system (ceiling cassette)
Check your remote control by using your camera or cellphone camera as your eyes. Point the remote control to the camera and "on" the remote control. If no lights emits in the remote control means that your remote control is defective If lights emits then the remote control is ok. Try also to locate the reset or rst button on the remote control if available and reset it, then try. If it wont work may be the receiver board in the unit is defective.
Jan 14, 2009 | LG LSC121PMA Split System Air Conditioner
I have a Power Shot S230 but my new system (Vista) does not recognize the driver for the above camera. I do a lot of pic work and need desperately Bill O'Brien [email protected]
In order for Windows XP or Windows Vista to communicate directly with a digital camera, the camera must be PTP (picture transfer protocol) capable. This protocol was developed after the PowerShot S230 came out six years ago. Your best bet would be to get a CF card reader (only about $15 - $20) with a USB connector and use it to read the photos from the CF card.
Sep 02, 2008 | Canon Cameras
Dlink wireless router
make sure the Internet Protocol (TCP/IP) of your system is set to "Obtain an IP address automatically". to check, follow this steps:
On your desktop you have the icon "My Network Places", right click it then select Properties, then on "Local Area Netwok" right click again then select Properties, Then select the "Internet Protocol" then clcik "Properties" then select "Obtain an IP address automatically".
pls make sure also that the IP Address of your DSL Modem is not the same with the IP Address of your router. If in case they have the same IP Address, change first the IP address of your Router before connecting to your DSL Modem.
Dec 09, 2007 | Computers & Internet
Unable to upload photo to computer.
as far as i think VISTA is not compailant with the CANON software. since vista s a latest version CANON will have to release a new version of its software for VISTA.
so this must be requested with CANON.
Nov 14, 2007 | Canon PowerShot A550 Digital Camera
D-Link DCS-5300G Network Camera Logo
328 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
