Question about Panasonic PVQ-2510 25 in. Combo
Picture suddenly went dark
While watching tv it suddenly went very dark and with strong red tones. No way adjust TV. Have DISH Network, other tvs are fine. Thanks much. Lynne Eliason
    Brigadier General:
  • 6,966 Answers
Hi, Apparently you have a possible component failure with your Panasonic PVQ-2510. This would involve the circuitry at the back/neck of the picture tube. Diagnosis would require familiarity with discreet components, use of a VOM, soldering and general component knowledge. In as much as it is possible that your red drive transistor (or an IC) would require replacement or resoldering, your best bet is to seek the services of a qualified professional. Should you venture to do a do-it-yourself, pls post back. Good luck and kind regards.
Posted on Oct 02, 2007
SOURCE:
How do I change one remote so It doesn't run both TVS
Dish Network TV 2 Duo tuner fix Dish 722 (877) 576-7100 ...
? 9:54
https://www.youtube.com/watch?v=e5154_wVkcc
Apr 7, 2014 - Uploaded by SilverStar Satellite Dish Network Retailer
On my tv 1 I keep changing it and it changes on TV 2 too so weboth watching .... My tv2 remote doesn't work for tv2 and whatever is being watched on ... To mirror tv 2 run a splitter offthe tv2 side of the diplexer as many as you ...
Jan 12, 2016 | Vizio Televison & Video
I have to TVS How do I change one remote so it doesn't run both TVS
Multiple Boxes, same room, remote changes ALL TVs - Comcast Help ...
forums.xfinity.com/t5/XfinityTV...remote-changes...TVs/td.../1441397
Oct 13, 2012 - I have 1 DVR box and 2 small boxes for a 3 TV setup in my living room. ... to have each remote only change channels for the box it's associated with? ... Nope,both the DTA's and the newer RNG & DCX boxes use the same IR codes. ..... Thatdoesn't help anyone who has multiple tvs in the same room and ...
? 9:54
On my tv 1 I keep changing it and it changes on TV 2 too so weboth watching .... My tv2 remote doesn't ...
FAQ's ' seiki
Jan 12, 2016 | Televison & Video
Today, while watching tv on the Dish, tv suddenly started powercycling. I unplugged it, waited, and then tried a DVD -- worked fine. Tried Dish again, power cycled again -- on off on off, 1/2 second of...
If you are using a powerstrip may not be supplying enough power to run the LG HDTV and your HD receiver. If you are using a powerstrip make sure the receiver is plugged directly into the wall. Otherwise this may be a grounding issue please reply if this doesn't work and we can look into some other possibilities.
Daniel Busa
DISH Network
Customer Service
May 16, 2011 | LG 47LD520 47 in. HD-Ready LCD TV
I have one receiver and two tvs. Regardless of which tv I'm watching or either remote I'm using, the tvs get the same channels. I would like to watch different channels on each tv. Any solution?
tjhuston41,
It sounds like the receiver may be in single mode which means both TV's will show the same picture. Pressing the mode button on the right side of the receiver will switch it to dual mode allowing both TV's to be used separately.
If the receiver doesn't have a mode button, then the issue could be the TV's are mirroring each other. Confirming the cable connections will tell you if that is the case.
Tommy Faust
DISH Network
Sep 04, 2010 | DISH Network IR Remote Control
Hitachi L32HO1UA HD TV blurred images very dark unwatchable scree
Hi Ellie!
Maybe in the manual you can find any information how to resolve this problem.
On this page of the manual there are shown most common receprion problems: http://manualsbrain.com/ru/manuals/979781/?page=72
Apr 26, 2017 | Hitachi 61SWX10B 61" Rear Projection...
Dish Network connection and surround sound
HI, connect audio output from tv to system,you may have to turn this on or turn up in tv menu for some sharp tvs,this should get sound for tv and dvd and anything else you hook up to tv.
Hope this helps.
CABLE GUY.
Mar 29, 2009 | Audio Players & Recorders
The Contrast and Brightness on tv appears to be dark.
If this is a CRT-based TV and it's been played most of the time, you may have a bad picture tube, especially if strong red colors bleed to the right. CRT's dim with use, unlike LCD or plasma. But it could also be trouble in the video circuits - none of this falls into the DIY category, unfortunately. High voltage involved, unless you're comfortable around it and want to try turning up the screen controls inside the TV. If you do, let me know - but "no response at all" from the external adjustments points to a more serious problem.
Dec 10, 2008 | Toshiba 36AF41 36" TV
Toshiba 51h85c rear projection screen is red!!
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 14, 2008 | Toshiba 51H84 51" Rear Projection...
Flesh tones and red colors
any hue adjustments usally relly cheap tv u got also hard to get good colers from it the lg one is nice i like samsung and sharp
go throw azll colers cheak dvd cables
Jan 06, 2008 | Insignia IS-LCDTV32 32 in. Television
Televison & Video Logo
99 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
