Question about GE 17.2 cu. ft. Top Freezer Refrigerator with Factory-Installed Ice Maker
GE Icemaker flap door won't open causes ice jam in chute
I have a GE Profile ice maker (1994) TPH22 series. Ice make works fine and sends ice down the chute. The flap door doesn't open and causes ice to jam up in the chute. Any ideas? The flap dood is on a spring assembly...I cleaned the door and checked for blockage, sticking and could not see anything. Thanks Paul
  • 8 more comments
  • Anonymous Oct 02, 2007
    Any particular trick to taking dispenser off from the front? Looks like it snaps in?
    Paul
    Thanks Atugot...I've ordered a solenoid from GE for $38.. I can see the solenoid but cant test it. Is the control module, the sensor that turns on the dispenser? The selector switch works, the sensor works...everything but the flap door. At any rate I really appreciate your help and figure for $38 its worth a try!
    Paul
  • Anonymous Oct 04, 2007
    Super. Thanks alot Watugot! I'll try and keep me shorts dry!
  • Anonymous Oct 06, 2007
    Hi Watugot
    I replaced the solenoid with a new one and the door still doesn't open (no power??)The lights and switches on the module still work. Is it possible that the old solenoid fried the part of the module that operates the solenoid?
    Will the new solenoid that I just installed be damaged by the module (control board?) if the board is toast?
    Thanks Again
    Paul
    LOL...Your the best Watugot!
    You're right tho I'm getting real good at re&re this sucker! I've already told her that this is much cheaper than calling the repairman. I told her I have saved hundreds.... phewwwwww!!
    Looks like that solenoid was real bad!!
    I'll keep ya posted...found a module for $40 on the net.
    Cheers
    Paul aka "The Fixer"
  • Anonymous Oct 23, 2007
    Mike
    replaced the module and viola!!! Works like new!!!
    Paul
  • Anonymous Oct 24, 2007
    Thanks again Mike... if u need any help on the PC... drop me a line
    paul
  • Anonymous Mar 27, 2014
    the flap on the ice make in the door keeps opening and closing, fridge not cooling
    need part number for flap door to icemaker- model # GL429570
  • Anonymous Mar 30, 2014
    icemaker on ge tfx25jr does not make ice
Thanks again Watugot
I’m just waiting for my module…..I love the fishing line solution! Hmmmm maybe theres an application for duct tape?????
Posted on Oct 13, 2007
  • 290 Answers
There is an electric solenoid that opens the door. If you look up inside the dispenser you can see the solenoid. Either the solenoid is bad or the dispenser module that puts power to it is out. You will need to remove dispenser front and check for voltage to solenoid. If you have power from module, replace solenoid, if no power, replace both parts. It is common for solenoid to short out and damage the module so that both must be replaced. If solenoid is shorted and you replace module, new part will fry.
Posted on Oct 02, 2007
  • 3 more comments
  • Anonymous Oct 03, 2007
    What I call the module is the control board. The switch is part of it. You will see how it works when you replace solenoid. If memory serves, the front snaps off and there are 4 screws holding control assy. The button cover that you press to actuate dispenser will pop off also. I usually work on these with the door open, this turns off power to dispenser. You can also unplug the wires to it, either under hinge cover at top of door or behind kick plate at bottom of door. I suggest you unplug it, there's not much worse than accidently hitting switch and getting cold water sprayed down your pants.
    Yes, I expect the board is shot. The new solenoid will be fine. You will be an expert by the time you get this fixed, but you can replace both parts cheaper than paying a tech to come out and replace one. Look inside the old solenoid and see if there is a slight swelling in the plastic. If so it is shot anyway. If there isn't, tell your wife there is anyway and act like you know exactly what your doing.
  • Anonymous Oct 12, 2007
    Just had to let you know that if module does't solve your problem I found another solution.
    I went on a service call today that had the same problem. The lady said it had not worked in over a year. Instead of repairing it, her husband had drilled a small hole at top of dispenser, tied a fishing line to the door and put it through the hole with a plastic ring on the outside. When you wanted ice, you pulled the string and put your glass against the button. It worked great but his wife said she was tired of being embarrased when company came so she wanted it fixed.
    I wish I could have met the man but he was gone to work. Anybody that could think of that, AND get his wife to go along with it for a year is my hero. Wish I could get his autograph.
  • Anonymous Oct 18, 2007
    Paul,
     just checking to see if you got fridge fixed.
    Thanks/Mike
    Great! You are the hero now.
    Thanks for the advice about Windows ME. I have run in to that before. It isn't on my computer, we have XP on ours. I was trying to salvage one for a family member. I was able to go into the harddrive and salvage the documents and pictures and she is getting a newer computer. I have a copy of windows 2000 PRO I am going to load on it and give it to a kid that doesn't have one. This will be the third one I have done that way. I am sure microsoft doesn't like it, but they are the ones that sold the sorry ME system so it doesn't bother my conscience a bit.
    Take care and good luck.
SOURCE:
Ice sticing in ice dispenser chute
only use ice from the ice maker, some frost is normal, but , lower temp in freezer
May 19, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Our GE Profile Arctica will not make ice cubes.
You have 2 problems .
1 . the water valve is not letting enough water in . Pt # WR57X10032 . This is located on the back of the refrig , where the wall water line connects to , on the refrig .
2 . The dispensor flap door , is not closing completely , to seal off the warm outside air , thereby , causing frost on the inside dispensor area , and , on the bottom of the ice dispensor bucket . The usual cause , is the door flap solenoid , pt # WR62X10055 . The plunger , which comes with the solenoid , usually rusts , causing the flap not to close completely .
Dec 15, 2009 | GE Profile PSW26P Stainless Steel Side by...
Will not release ice and makes crushed ice, even when on cubed.
I believe in your case the ice maker part number WR30X10093 being electronic with the control board in the front is the problem. I think the control board behind the front cover of the ice maker may have corrosion and causing the ice maker to malfunction. You can try disconnecting the set of wires to the coil on the water control valve and see if the water stops or turn off the ice maker first and try disconnecting the coil wires later. It has to be the control board or the water control valve part number WR57X10032
Oct 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
My GE profile refrigerator's ice maker is frosting over at the exit point for the ice leaving the ice bin. I have cleaned it repeatedly and have no clue as to the cause.
The flap door that opens to let ice drop out of the door has a bad seal or the plastic mounting arm is cracked or broken,this is allowing moisture to enter and turn to frost.This will continue to happen until the flap door is repaired,and sealing correctly.
Sep 22, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice maker chute becomes jammed with snow and cubes are being crushed even if the cube option is selected
You need to remove the ice bin , remove ( save ) the ice , and defrost the bin opening with hot water . It sounds like a piece of ice got caught behind the bin flap , keeping the flap from opening fully , so cubes will go thru . When cubes cannot go thru , the crusher will crush anything that tries . Now this is the ice container only .
Sep 09, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE profile Artica side by side. I am getting a frost build up
Sounds like the dispensor flap is not closing completely , pulling outside air in . Using a flashlight on the outside of the flap , look inside to see if any light is visible . If so , then the ice flap plunger and solenoid will have to be replaced . Also , excessive crushed ice can also cause frosting .
Jul 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker flap stay open
the solenoid is bad,next time send the full model number it says it's a ge so this should help you out,for now you can get a ball of paper towels and stick it into the shout where the ice comes out to stop the warm air from getting into your freezer
https://www.youtube.com/watch?v=jpXo0svta9s
Feb 07, 2018 | GE Profile Arctica Stainless Steel Top...
Ge profile refrigerator ice maker
I have a GE Profile PSW26P Stainless Steel Side by Side refrigerator that makes plenty of ice but will not dipense when the lever is pushed. The dispenser makes not sound when engaged. What do you think the problem is.
Sep 28, 2008 | GE Profile PSW26P Stainless Steel Side by...
Ice dispenser flap/door will not close properly
I have a similar problem. The repair guy took a look at it and stated everything is working and did not order any solenoid or any other parts. After he left the problem returned where ice comes down the chute it tends to lodge and keep the door open. I am disagreement with the repair guy and am leaning toward the idea that the spring has lost tension and is just too weak to close with any authority. There is a video on how to replace the spring on youtube. This is what I will be doing next weekend and will try to return to post results.
Jun 10, 2008 | GE Monogram® ZISS420DMSS Side by Side...
Refrigerators Logo
2,425 people viewed this question
Top Refrigerators Experts
Brad Goodale
Peter Taylor
Tmik
Tmik
Level 1 Expert
