Question about Konica Minolta magicolor 2430 DL Laser Printer
Media Jam- Fuser
My printer won't print. The display says 'media jam - fuser' What can I do?
Thx m8. Media jam: Fuser i had...
new there was no paper jam so looked about for the sensor and found that the little arm thing that gets liffted up as the paper pass was not falling back down so it thought the paper had jamed. i just took the back panal off and put a small bit of soft foam under it so it always got pushed back up.
works a treat now.
thx again
Posted on Jan 10, 2008
    Champion:
  • 214 Answers
Check that there is no paper stuck in fusing unit, check that solenoid/sensor is moving ok
Posted on Dec 07, 2007
Media jam fuser
replace the fuser unit
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 04, 2014 | Konica Minolta Magicolor 2530 DL Laser...
Media jam fuser
replace the fuser unit. and replace the transfer roller and belt,
Jan 30, 2014 | Konica Minolta Magicolor 2530 DL Laser...
Media jam fuser
Jan 29, 2014 | Konica Minolta magicolor 2430 DL Laser...
Sir my printer problem is on printer menu write a clearing paper path what is this massage and give me solution.
Thank you contacting FixYa for your printer inquiry.
This error is associated with either a sheet of paper blocking the paper path or a partial piece of paper that blocks path or trips a sensor. The printer will usually throw up a error code 13.XX on the display and the XX is a number that will indicate where in the paper path this error most probably occurred. Just follow the steps for your error on the below chart.
This link will take you to the user guide which will be helpfull identifying components and providing guidelines for most of the helpful hints and things you will need to know about this printer.
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00218691/c00218691.pdf
Locate your error on the matrix below and follow the steps. Comment back if you need more help. Thank you again for contacting FixYa.
TF
HP Laserjet Error Codes 0 - 19 Message on printer Display Panel What it means. What to do. 13.XX PAPER JAM [LOCATION] Media is jammed at the specified location (and possibly at other locations). If the message persists after all jams have been cleared, a sensor or sensor lever might be stuck or broken. For all jam messages, do the following: 1. Remove jammed print media from the specified location. Check the entire paper path for other pieces of media in the path. 2. Open and close the top cover to clear the message. 3. Check sensors and flags in the paper path for proper operation. 3.0 PAPER JAM [LOCATION] A non-specific paper jam occurred. 1. Remove jammed media from the specified location. 2. Verify the paper tray is fully closed. 3. Inspect and/or replace the feed and separation rollers. 4. Ensure there is no obstruction in the path, such as a torn piece of paper. 5. Open and close the top cover to clear the message. 6. Check sensors and flags for proper operation. 13.1 PAPER JAM OPEN INPUT TRAYS Paper-delay jam at paperfeed area. 1. Ensure that paper trays are loaded and adjusted properly so media can feed from the tray. It might be necessary to reduce the stack height of media in the tray. 2. Check the input area for obstructions such as media in the path. Also check to see if the registration assembly damaged or unseated. 3. Replace any defective sensors or flags. 4. Verify the media meets the specifications. 5. Check the pickup feed and separation rollers for unusual wear. Replace as needed. 6. Rotate the media in the input tray by 180° and/or turn it over On NX engines this is most likely the fuser flag or the ACPM. The ACPM has a photosensor hard-wired to the back of it. 13.10 PAPER JAM CHECK DUPLEXER Jam at duplexer. 1. Check the duplexer and the rear area of the printer for obstructions or damage. 2. Check the duplexer for proper operation. Replace the duplexer if a sensor is defective. On a 5si, 8000, or 8100 series laserjet a Duplex Jam can be caused by a tray 2 and 3 feed assembly failure. 13.14 For Laserjet 5si. This error is caused by a defective paper control PCA Replace paper control PCA. 13.2 PAPER JAM OPEN INPUT TRAYS Paper-stopped jam at paper-feed area. 1. Check the input area for obstructions such as paper in the path. Also check to see if the registration assembly is damaged or if the transfer roller is out of place. 2. Replace any defective sensors or flags. 3. Ensure the media does not exceed the maximum length. 4. If multiple sheets are feeding, it might be necessary to fan the media and reduce the stack height. Also, replace separation pad. 5. Verify that the fuser is properly installed. On NX engines this is an input jam. 13.20 PAPER JAM CHECK REAR DOOR Media stopped in the paper path during power on or when the top door was closed. 1. Remove all media in the paper path, and then open and close the top cover. 2. If the message persists after all media is removed: Check if media is jammed in the prefeed area. Replace any defective sensors or flags 13.21 DOOR OPEN JAM The top cover was open while printing. 1. Clear the jam and close the top door. 2. If the message persists, check the top door switch for proper operation. 13.5 PAPER JAM CHECK REAR DOOR Paper-delay jam at fuser. 1. Check the transfer roller and small media belt to ensure they are operating and can feed print media. 2. Check the paper path for obstructions at the transfer roller, toner cartridge, paper feed assembly, and fuser. 3. Replace any defective sensors or flags. 4. Turn the media stack over and/ or rotate it by 180° in the input tray. If still persists - replace fuser, then DC controller. 13.6 PAPER JAM CHECK REAR DOOR Paper-stopped jam at fuser. 1. Check the paper path for obstructions at the fuser and output/delivery area. 3. Replace any defective sensors or flags. 13.99 PAPER JAM [LOCATION] A non-specific paper jam occurred. 1. Remove jammed media from the specified location. 2. Verify the paper tray is fully closed. 3. Inspect and/or replace the feed and separation rollers. 4. Ensure there is no obstruction in the path, such as a torn piece of paper. 5. Open and close the top cover to clear the message. 6. Check sensors and flags for proper operation
Jun 09, 2011 | HP LaserJet 4350 Printer
Media jam fuser
I turned the printer off, took the power cable out, and turned the printer on. After 60 seconds I turned the printer off, put the power cable back in and turned the printer again on. This is a solution in order to loose all the voltage/current build up in the printer. Whether this is the solution or just coincidental, I don't know. The printer worked well after that.
Mar 02, 2009 | Konica Minolta magicolor 2300DL Laser...
What is media jam fuser error
It means there is a paper jam in the fuser (the hot part that fixes the toner to the paper).
Check if there is any sheet jammed inside your printer or if any sensor is in the wrong position.
If everything seems to be ok, you may need to replace the fuser.
Nov 27, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Paper jam
Probably one of the sensors on the fuser is not working correctly. There are two sensors on the back of the fuser that move when the paper exits the fuser. Remove the back of the printer when the printer says there is a jam and move the sensors to see if the error goes away. If so you may have to replace the fuser unless you can just replace the defective sensor.
Roger
Jun 03, 2008 | Lexmark T644 Laser Printer
LJ3700 page tops half- way through fuser. Bob
13.01.00 (HP 3500) 13.20.00 (HP 3700) Description A media delay jam has occurred in the registration area. Action Check for media stopped or jammed in the area of Tray 1 pick-up, Tray 2 pick-up/feed, and Tray 3 pick-up area (if Tray 3 is installed). Remove any media and continue printing. 13.02.00 (HP 3500) 13.20.00 (HP 3700) Description A media delay jam has occurred in the registration area. Action Check for media stopped or jammed in the area of Tray 1 pick-up, Tray 2 pick-up/feed, and Tray 3 pick-up area (if Tray 3 is installed). Remove any media and continue printing. these are areas that you mentioned and fixes to them http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c00047478#A3 this is the link to all error codes for your printer you might want to print these out and keep safe
May 07, 2008 | HP Color LaserJet 3500 Printer
Phaser 7300N paper jam
Problem:
    The Printer's Front Panel Displays Jam At Top Cover; Open Top Cover To Clear (A7)
Cause:
Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. TRY FIRST (Solutions without parts):
1. Unsupported media. - Load supported media and set the media type correctly. 2. Dirty exit rollers. - clean the exit rollers. Paper catching on the duplex guide assembly. - Remove and reinstall the duplex guide assembly. Fuser not fully seated. - Reseat fuser
REPAIR/INSPECT/PREVENT PROCEDURE:
1. Clean feed rollers and exit rollers only when dust or
debris is visible.
2. Clean the LED assemblies.
3. Check version of print engine and image processor
firmware; as appropriate.
4. Check cleanliness of interior and exterior of printer,
including fans; if necessary, clean (dust or vacuum) these
areas.
5. Review proper operation of printer using a customer
file, if possible.
6. Review with customer all work that was performed; also
discuss how to properly care for their printer.
Rev DT: 01 22 2003
Jan 23, 2008 | Xerox Phaser 7300DN Laser Printer
Media jam transfer roller
We have a Xerox 6120 which is mechanically identical to the 2430. It was reporting media jams. We determined after removal and careful inspection that the fuser roller and fuser pressure roller had been damaged by what looked like someone attempting to clear a jam with a sharp object. I cannot speak re: the 2430, but the fuser in the 6120 is not a FRU. The construction of the fuser doesn't tolerate any flaws on either surface. There was more paper jammed in the fuser where we couldn't see it until we had the fuser out of the printer. We are shopping for a new printer as the repairs will cost more than we paid for the printer.
Dec 10, 2007 | Konica Minolta magicolor 2430 DL Laser...
Konica Minolta magicolor 2430 DL Laser Printer Logo
2,401 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
George Mclaughlin
Clive
Clive
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
