Question about Dryers
Noisy drier Hi my drier is making a really loud noise. It sounds like the bass in a car, but its just continuous. I heats up and spins it just makes a lot of noise. Can u help please Thank you
  • diy_girl08 Apr 07, 2008
    when i turn my dryer on it makes a very loud banging noise. i think that the seal in broken on the drum and that the rotator wheels on the inside are off balance. How can get it them to check?
I had the same problem with my dryer. The large cloths drum rides on two wheel bearing rollers that are mounted behind the drum. If one of those bearings to the rollers wears out, it will make a loud racket. If you want to repair it your self, purchase a repair manual for your model dryer. Then Disessemble the front of the dryer to expose the large drum. Remove the belt that goes around the drum. Then remove the drum. You will then be able to see the two rollers that the drum rides on. Go to your nearest parts store and replace both of them. Good luck.
Posted on Oct 02, 2007
The spin cycle is very noisy. What could be the problem?
hi robyn.
A washer making a loud noise during spin cycle can also be caused by a faulty drive pulley. The pulley is what the belt (if applicable to yourwasher) rides on to spin your washers tub. The pulley can be made of plastic or metal. It could be simply worn out or just loose.27 Jul 2015
How To Fix A Washing Machine Making Noise During The Spin Cycle ...
or try this link might help you.
washing machine spin cycle is very loud Google Search
Nov 18, 2017 | Washing Machines
Samsung front load washer, jerks and makes noise when it first starts spinningthen it smooths out, and works fine.
on many machines that is normal, the shaking continues until the load is distributed relative evenly around the spinning drum. It is also possible it is the main bearing but I am not sure. The noise I am talking about would have been there since new. These links may help. Washer has noise during spin cycle Whirlpool Maytag Sears GHW9100LW1 Washer is Making Loud Noise
How To Fix Washing Machine Making Noise During The Spin Cycle
May 28, 2016 | Samsung Platinum Front Load Washer -...
Cabrio washer wtw5500xw0 loud spin and grease on floor
FIXED Cabrio has loud noise during spin - ApplianceBlog
Aug 21, 2009 - 10 posts - ‎5 authors
Help Jake I have a Whirlpool Cabrio model WTW6600SW2 it is almost 2 ... a week just started making a very loud noise only during spin sounds like ... size washer (110.297) (loud whirring and grease splatter) and am trying to ...
How to tell if your bearings are bad on a Whirlpool Cabrio ...
? 1:01
Jan 19, 2012 - Uploaded by RenewAppliance ... My floor under the washer machine hasgrease/oil marks. ... and make the suspension bad when it spinsmine has been like this for about 2 months now ... Noisy WhirlpoolCabrio washer during spin - Duration: 0:54.
Jan 16, 2016 | Washing Machines
Loud squeaking.
To me, I think I am hearing a dry bearing.
However, an old worn out belt can make the same sound!
You could take off the belt and try spinning the pulleys to hear which is noisy, or you could use a mechanic's stethoscope to find out.
A mechanic's stethoscope is a really long screwdriver or metal rod about 2 or 3 feet long that they put on different parts (put the handle end to your ear) to hear the noise each part is making.
If your belt is good, try the alternator bearings.
There is also an idler pulley or maybe 2 that could be noisy.
Be blessed.
Feb 07, 2013 | Cars & Trucks
Kenmore Elite Oasis HT makes loud noises during spin cycle.
The tub may be unbalanced and wobbling. This may be due to washing heavy items such as rugs, towels, etc. If it is noisy with regular laundry loads, the mechanism that supports the tub may be loose or broken.
Sep 10, 2012 | Kenmore Oasis Agitator 4.5 cu. ft....
My computer is becoming really hot and noisy. After turning on the computer, everything is good (no noise). Once around 15 minutes passes by or I open up a lot of programs together, my computer starts...
Sounds like the fan is wearing out, as it heats up the fan needs to spin faster and if the bearings are wearing out it will start getting louder and it will also get hotter because the fan cannot keep up the heat being produced. You can replace the fan, most computer shops will carry replacements, also get a can of compressed air and give the inside of the computer a good cleaning. This will help keep things cooler as well. Also make sure that the air vents on the outside of the case are clear as well.
Jan 07, 2010 | Vantec Fan Vibration Dampener Noise...
Washer makes alot of noise
time to replace the belt , might need a tub bearing too / tentioner pully might have froze . remove the back panel with the washer unpluged look to see if the tentioner is at its fullest possition if so replace the belt .
Sep 06, 2009 | Maytag PAV2300 Top Load Washer
Frigidaire top-load washer Loud noise during spin
its either the upper spin bearing or lower spin bearing. the upper can be replaced by itself but the lower requires the transmission the be replaced
Nov 20, 2007 | Frigidaire FWS833A Top Load Washer
Dryers Logo
340 people viewed this question
Top Dryers Experts
