Question about Kenmore 43142 Front Load Washer
Pump won't stop
I had a outlet problem which I cleared by cleaning out the trap. After this washer worked fine for about a week. Now it gives me the same "outlet problem" code but there is nothing in the trap or in the large black hose between the drum and the pump. The drain line is empty (at least at the pump). When washer is turned on, it does not do its "sensing" spin and the pump turns on - it never gets past this. Pump sounds a little strange but that could just be because it is running without any watter. Any ideas?? Anything that would save me a weeks wait for repair...
    Problem Solver:
  • 11 Answers
Does your washer door lock and drain pump run.  No water coming in to machine and code F21 appears (or lights start flashing after a few mins.?)  Try disconnecting the pressure switch at back top right inside machine.  If the machine now fills and starts agitating, stop the machine and replace pressure switch (contacts stuck inside switch).  Do not start replacing expensive control boards before trying this solution.    Randy
Posted on Oct 19, 2007
Ur controler most probabley gone
Posted on Oct 02, 2007
SOURCE:
Why does it quit randomly during cycle?
If you cleared the drain pump trap of obstructions, and the pump still runs fine(without rattling from a loose or damaged impeller) then most likely you have fixed the problem. The washer will not spin if it can't drain--and if the water is draining too slowly, it will time out and give an error code for "slow drain". For any items such as bras, underwear, socks, baby socks, stockings, pantyhose, etc, use a netted clothing bag with a zipper to prevent those types of things from getting pulled in-between the basket and tub and then making it to the drain pump trap. These things are notorious for clogging pumps on front load and top load HE washers!!
Aug 02, 2015 | GE Washing Machines
Where is the coin catcher on a Kenmore Elite H3 washer
it is most likely the pump. you can remove the pump and debris trap easily, separate the pump from the debris trap by depressing a tab and turning the pump clockwise from the debris trap. the pump is a mag drive unit and is easily dis-assembled. ours had debris inside the pump, once taken apart there was some black colored fine sand inside that once cleaned out the pump returned to normal function. we bought a new pump but the old one still works since it was cleaned out, the rubber o ring had leaked letting the debris inside the impeller assembly. hope this helps out. it worked for ours
Dec 03, 2017 | Kenmore Washing Machines
My indesit iwc6105 washing machine is not draining at all.
see this causes: and fix it. God bless you
Belt, Water Pump If the washer won't drain the pump belt might have broken or might have worn out. Check the belt and replace if it shows signs of excessive wear.
Drain Pump If the washer won't drain water the drain pump might be defective. It's also common for a small sock or other article of clothing to get caught in the drain pump or in the drain hose. Check both for an obstruction before replacing the pump.
Clogged Pump or Hose If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed.
Drive Belt If the washer won't drain, should check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't drain properly, if at all.
Lid Switch Assembly If the washer won't drain the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't drain the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Drain Hose If the washer won't drain water check the drain hose. Be sure the hose did not get kinked behind the washer. Also, remove the hose from the pump and check it for obstructions.
Coin Trap If the washer won't drain the coin trap may be clogged. This washer is equipped with a device near the water pump called a coin trap. The purpose of this device is to trap any foreign materials that make their way down the drain. Normally, the coin trap can be accessed through an access panel. It is designed with the homeowner in mind and is normally easy to clean out
Oct 11, 2012 | Washing Machines
CHANGE DRAIN PUMP WASHER
see this causes and fix it. God bless you
Coin Trap If the washer won't drain the coin trap may be clogged. This washer is equipped with a device near the water pump called a coin trap. The purpose of this device is to trap any foreign materials that make their way down the drain. Normally, the coin trap can be accessed through an access panel. It is designed with the homeowner in mind and is normally easy to clean out.
Oct 02, 2012 | Whirlpool GHW9300 Duet Washer
Washer won't drain!
Sounds as the pump has gone wrong, if it's turning & doing the usual cycle except for draining the motor is fine, check the pump filter trap to be sure there is no obstructions as a simple penny can stop the pump motor turning preventing the machine from draining, I hope this helps.
Jan 24, 2018 | GE Spacemaker WSLP1100D Top Load Washer
Hi We have a Kenmore HE2 plus front load washer. Its not too old but it came with the house. Recently we have been getting error messages 5D, F21, and F23. I pulled off the front panel and cleaned out...
Hello & Welcome to FixYa
F21 error is displayed when the washer is unable to drain, press PAUSE/CANCEL button twice to clear the display. After this please check the drain hose and drain pump filter for any blockages and make sure it is not clogged with foreign particles. You can also check the drain pump to verify that its working. Please get back to me if you have any other questions.
Kevin
Sep 06, 2011 | Kenmore HE2 Plus Front Load Washer
Front loading washer, kenmore 417.42052100 won't completely drain and leaves a tub full of water. Has been getting worse over the last week and now won't drain at all. Took off front panel to try...
The drain filter/coin trap is blocked or the pump is no longer working. The filter/trap is located inside the big black hose that runs from the bottom of the tub to the pump and hence the name tub-to-pump hose. Clean the filter and inspect the pump impeller for damage or restriction.
Disconnect power then remove the screws attaching the bottom front panel to the cabinet then pull the panel down and off. Once the panel is off, you can now loosen the clamps securing the tub-to-pump hose to the bottom of the tub and the pump's inlet then take the hose out and clean the filter/trap.
You should find foreign objects such as coins, toothpicks, hairpins and the likes blocking the filter. Clear the filter from the foreign objects and inspect the pump impeller by turning it with your finger. The impeller may be restricted or damaged resulting in the water not being pumped out properly or none at all. Replace the pump if the impeller is broken or restricted and doesn't turn freely or if the pump is no longer operational. You can tell the pump is no longer operational if all are clean and the impeller is in good shape and turning freely. Reassemble the machine by following the steps above in reverse order.
When installing the filter in the coin trap, the top ring of the filter MUST be seated in the 3rd convolution from the bottom.
Jun 20, 2011 | Washing Machines
My washer spins but doesnt spin on the final spin and leaves the clothes all soaked. it stops at 6 minutes on the final spin
is the machine draining correctly?
the machine will oftin stop if not doing so.
you can try cleaning out the coin trap/drain pump hose.
Jan 12, 2010 | Frigidaire Affinity ATF7000E Front Load...
Indesit IDL 50 Dishwasher
Had a similar problem (flashing lights 1 and 2). Drained the machine by diconnecting the outlet hose and using a shallow bowl on the floor. Removed and cleaned filters. Forced clean water through by using a garden hose pipe(you can only do this one way, you cannot force water down the outlet pipe). Removed and cleaned the pump (you have to do this from under the machine but easy enough). Finally ensuring the waste trap under the sink was clear. Bingo!! No parts, no expensive engineer.
Jun 04, 2008 | Indesit 24 in. DE73 Evolution...
Kenmore 43142 Front Load Washer Logo
101 people viewed this question
fordexpert
Kristen Denison
Kristen Denison
Level 1 Expert
Gordon Richard...
