Question about Macromedia Flash MX
Images sir i want to know how to import any single image of any thing for example i want to import a plane image in macromedia flash which is saved in jpeg, or bitmap format in any of file or drive and i don't want the background of that planes image in my flash work space just want the plane so tha i can animate it. please answer my question. and also how to genrate any camera view to show any of image from each side in flash
    Problem Solver:
  • 18 Answers
If you want to import any image, it has to be saved with a transparent background, like a (.gif or .png) image.. for example if you have an image i.e plane.jpeg you need to open it in an image editing software like adobe photoshop and delete the background save the image as plane.png and import the plane.png to flash. You can edit the picture in flash also to remove the background.. but the process is not easy and its time consuming. so try that workaround like i said before let us know if it worked.
Posted on Oct 03, 2007
Inserting images into a flash website template
first make sure that your pics are the same file extension
(jpg,bmp,png ext)
if the original pic in the flv was named top1.jpg make sure that the pic you import is named top1.jpg
Aug 03, 2009 | Adobe Flash Pro CS4 for PC
Unable to transfer images from sony handycam to pc
my suggestion would be, try uninstalling the device first from your computer then, try downloading macromedia flash player of the internet. Then re-install the device if you need any help please pm me...=]
May 23, 2009 | Sony Handycam DCR-HC20 Mini DV Digital...
Yes... It is very easy...
Open Flash and import the image which you want to be like button.
then go to modify > convert in to symbol.
Double Click on newly converted symbol.
Add the view which you want to be when the cursor clicks the button, when it goes over and when it hits.
Thats it... Go back and do it...
Apr 20, 2009 | Macromedia Computers & Internet
How to define variables in flash action script for every movie that i want
Using variables in a project
When you build animations or applications with Flash, there are very few situations in which you don't need to use any kind of variable in your project. For example, if you build a login system, you might need variables to determine whether the user name and password are valid, or whether they are filled in at all.
You can find more information on loading variables (such as name/value pairs) in Working with External Data.
In the following example, you use variables to store the path of an image you are loading with the Loader class, a variable for the instance of the Loader class, and a couple of functions that are called depending on whether the file is successfully loaded or not.
To use variables in a project:
1. Create a new Flash document, and save it as imgloader.fla.
2. Select Frame 1 of the Timeline, and add the following ActionScript to the Actions panel:
/* Specify default image in case there wasn't a value passed using FlashVars. */
var imgUrl:String = "";
if (_level0.imgURL != undefined) {
// If image was specified, overwrite default value.
imgUrl = _level0.imgURL;
Apr 15, 2009 | Macromedia Flash Professional 8.0 Full...
Image will not wrap correctly in vanishing point
Hi again,
Ok, I finally got it licked and why you're having the problems and it's fairly simple. It's all based on 2 things but most of all, the order in which you create your planes or grids.
Because the main part of the image is on the front face that is what you want as your Parent face so get that as accurate as you can to start off with. Hold the 'x' key to temp zoom in and get the position as correct as you can.
Once you've created you're primary ctrl-click(cmd-click on mac) the mid top point and pull it out then the same for the mid left point.
Now if it still has the problem when you paste in the image and drag it onto the primary face then undo the paste. We need to adjust the secondary planes. Select the top plane and in the angle parameter (which should show 270°) change it to 269°. Then change the left planes angle to 89°. Try it now and it should work fine. Then put it back to 270° and 90° again.
Let me know how you get on.
All the best
Dec 28, 2008 | Adobe Computers & Internet
Macromedia flash 8.0
Use the instruction shown in image.
Jul 19, 2008 | Macromedia Flash MX
How to animate a flash character
set four corners image when bosewr is holf image size same
Jul 01, 2008 | Macromedia Flash MX
Serial number
FLW500-03143-77238-80660 OR FLW500-06846-68238-49748
Jun 25, 2008 | Macromedia Flash 5.0
Flush command buttons how to download it?
Hi Bhavin, You search for software like button maker from free software download sites. Now if you r using VB or any other frond end application then save the above made buttons in *.gif format. Then you put that image in your button's image. If you r using java then put that gif image in to your button image. And if you want some animation in it then follow this link.. Generate any flash text u want. and use it in your project.
Sep 21, 2007 | Macromedia Flash MX
Macromedia Flash MX Logo
759 people viewed this question
Top Macromedia Computers & Internet Experts
Folusho Adeyanju
Folusho Adeyanju
Are you a Macromedia Computer and Internet Expert? Answer questions, earn points and help others
