I need printable instructions on removing and replacing the alternator in a 2004 ford Taurus with a 3.0l v6 engine
SOURCE: how to remove 2002 ford taurus radiator
Remove the rad support cover, remove the electric cooling fan and shroud, disconnect the tranny cooler lines, drain the cooling system, remove the upper and lower hoses, remove the rad brackets on top of the rad (one on each side), have someone hold the AC core out of the way and carefully slide the radiator up and out
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
SOURCE: 2002 ford taurus wtaer pump
Removal & Installation
3.0L (2V)
To Remove:
To Install:
Water pump bolt torque sequence (3.0L (2V) engine)
SOURCE: replaced the battery and the alternator in 2006 ford taurus
check the alternator fuse and grounding
