Question about SanDisk Sansa e250 MP3 Player
Sansa media player 4gb
I turned on my player and its says switch to recovery mode...this happened to my friends before and i remember downloading something off the internet to fix it but i cant remember what it was...
  • 626 Answers
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted. http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe You need to put the device into "recovery mode" before you run the tool. - Turn the device off (hold power for 20 seconds) - Slide the hold switch into "hold" position. - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer. Then run the recovery tool. Select format when prompted. Best of Luck.
Posted on Oct 02, 2007
SOURCE:
I have a red sansa 4GB. It was working perfectly until yesterday when i was listening to itit suddenly stopped working and i haven't been able to turn it back on. Any ideas?
Recovery Mode: download the update software and install then lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer Start the update software if it doesn't start automatic goto /start /all programs /Sandisk/sansa updater/ sansa updater and start it up manually... follow instructions on the updater and the sansa. http://www.youtube.com/watch?v=_95hLqZxCHc&feature=related here is a link to a kid showing you how to goto recovery mode.
Update software from this link..
(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe)
and install the software before you recover
Jun 27, 2010 | SanDisk Sansa e250 MP3 Player
Empty sansa 4gb mp3, no software on device
How to use the Sansa Recovery Tool for Sans Connect:
http://kb.sandisk.com/app/answers/detail/a_id/863/kw/RECOVERY/r_id/101834
Check
2 things to check before starting the Recovery Mode and to use the Recovery Tool:
- First, charge the Sansa Connect for at least 20 minutes using the AC charger to ensure this is not a battery depletion problem.
- Second, hold the power button for 8-10 seconds to ensure the device is turned OFF.
After these steps, you can put the Sansa Connect into Recovery Mode and use the Recovery Tool.
direct to the download Sansa Recovery Tool [66 MB]
direct to the download How To pdf file [420 kB]
Sep 22, 2009 | SanDisk Sansa Connect MP3 Player
My sansa e260 dosent read in the computer
well if you are trying to use itunes, then it won't show up. Only ipods or iphones do.
Nov 17, 2008 | SanDisk Sansa e260 MP3 Player
Sansa 260 4GB
Will Windows read it as a flash drive?
If so, find a file recovery program like undelete or something, use it to restore your files, then turn on the sansa, then select format( if it is a view) and it will delete all your songs
Oct 25, 2008 | SanDisk Sansa e260 MP3 Player
Load main image failed switch to recovery mode
follow the above steps but turn on the power button if nothing is happening. It's the only way I got my e280 to recovery mode
Sep 23, 2008 | SanDisk Sansa E280 MP3 Player
Help me
this happened to me before, but u follow what it tells u to do on the screen. if u do all it tells u to, and it returns to the recovery mode screen, it means that ur missing a file from the "systems" folder. u can copy it from another sansa and put it on ur sansa, or download it online .
Sep 16, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e260
Download the Sansa Recovery Tool from sandisk's website
Jul 06, 2008 | SanDisk Sansa e260 MP3 Player
Problems with Sansa e250 + Rockbox
Go to Sandisk's website and download the Sansa Recovery Tool
Jul 04, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e250 mp3 player
remove ur batery and replace it or download the file archieve.exe and install audible folder.then u can switch on it.
Jul 03, 2008 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
54 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
