Question about HP vs15 15"LCD Flat Panel Monitor
HP 15 inch lcd monitor
My lcd worked well for about 6 months. But now sometimes I see ghost images specially icons means a small light line near original line. If I remove power cord and again put it back, it gets solved. But after it can happen again after some time. I have same kind of problem with another set of hp lcd also.
    Problem Solver:
  • 13 Answers
This sounds like you have a problem in your power supply. The capacitors in the power supply "clean" up the voltage and provide you with a steady power source. When the capacitors go bad you can be left with either a power deficit of a power surplus which could cause the problems that you are experiencing. Capacitors are pretty hard working devices that are much like batteries but charge and discharge really fast. Capacitors work really hard in a power supply and its not uncommon when they fail. Unfortunately the only thing you can do here is either purchase a new power board or if you feel brave, look at the caps on your power board and swap them out with new ones. They're pretty cheap and you might learn something.
Posted on Oct 03, 2007
THE LCD IN MY LAPTOP IS NO LIGHT..
If you mean the monitor it could be a couple of things. 1. There is a tiny switch that turns the monitor backlight on and off it's located near a hinge. When you close the lid it switches off the backlight, when you open it switches the monitor on. Sometimes the switch will stick due to dust, dirt, etc. and the backlight will not come on. Do you see a "ghost Image" on the monitor in a very bright light? Your statement is a bit vague"THE LCD IN MY LAPTOP IS NO LIGHT..", not sure what you are trying to say? Anyway 2. The ribbon cable may have been jarred loose in a drop, bang...etc.3. The CCFL backlight may be out altogether. Without more info it's difficult to say for certain.
Nov 17, 2012 | Computers & Internet
Double image on screen
Usualy in these cases I check the VGA cable. If you can buy new one, but not cheap one will solve the problem. Just to be sure that this is your problem hold the small vga cable cylinders with your hands for 5-6 seconds. When you release them you shouldn't see the ghost image on your screen. It sounds weird but it works. By holding these cylinders you remove the static electricity of the cable. Try to understand what device around your monitor causes the problem. The cause also may be lot of power cables or power sources near the VGA cable.
Dec 18, 2011 | HP 2009M Monitor
HP w2408 ghost bands to the right of dark images on the monitor outside of open windows
Connect the lcd to another computer to verify the problem is the display. I have seen a bad video card cause this problem.
Jun 24, 2009 | HP vs15 15"LCD Flat Panel Monitor
HOW DO I TURN DOWN THE VOLUME? I DOTN SEE THE VOLUME BUTTON
This monitor has no volume. The volume is controlled by the computer connected to the monitor, and not controlling the monitor itself.
To regulate volume on computer, click on the small audio icon near to the clock, or locate the audio settings icon in control panel.
Jun 04, 2009 | HP Pavilion F1523 15" LCD Monitor
Ghosting of images and buzzing when on mostly white screen X2gen 19" monitor (HP/Vista )
Please bring the unit to an authorized service center as there's an internal electronic part/s of your monitor that is cold soldered / defective. regards
May 27, 2009 | X2Gen MG19VT 19" LCD Monitor
Westinghouse LCM-22W2 has "ghosting"
Usually, LCD monitor ghosting appears when the cable isn't tight, the cable is faulty, or low quality. The cable should be less than 8-10 feet long. Try using a different monitor cable (they're mostly interchangable) and see if the problem goes away. I'd put my money on the cable or a loose cable connection.
May 13, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
Flickering, jittery image, white horizontal flashing lines
this is real old right
no photo off i messing up, how can we guess, what you see?
amazing....
my guess power pack shot.
i guess you cant barrow a monitor and try that?
2nd guess blind, the back light failing
or is damage if it was hit, the LCD will have damage
gently flex the frame goes nuts, bingo.
Mar 02, 2017 | HP Pavilion F1703 17" LCD Monitor
Ghost Image
mark165,
Are they both about the same age? Also have you recently added a device that is sitting near the monitors such a an external hard drive, printer, new speakers or power cord or cable next to or against the monitor cable? I sounds like EMI to me, shield the cable or plug of the offending devices into another outlet away from the monitors to test that theory, or having them on a separate surge protector should eliminate the noise you are reporting. Some go as far as adding UPS with line filtering (or conditioning) for the devices - you see it with home theater setups when the TV, computer, games and stereo are all plugged in the same outlets on the same home circuit.
randy320sgi
Jan 12, 2009 | Computers & Internet
Phillips 50 inch Plasma
Philips 50 inch plasma tv no video but has sound
Sep 28, 2008 | Philips 50PFP5332D 50 in. Plasma...
Ghosting
Does the monitor do this on all resolutions?
Try changing the refresh rate on the monitor's properties page and see if the effect changes at all.
Feb 12, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
HP vs15 15"LCD Flat Panel Monitor Logo
184 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
