Question about Dell F3534 Touchpad
Sensitive touch pad
The pad on my Dell Inspiron 1100 is too sensitive. Sometimes i touch it with the pad of my palm and the curser jumps around. How do i change the sensitivity. This just started recently...and i have had this computer for a couple of years. Thank you
  • 2 more comments
  • Anonymous Jan 18, 2008
    Same problem. Curser jumps back to origin repeatedly while typing. Downloaded new driver, but still have no touchpad tabs anywhere, only mouse options. I have no option thru control panel to switch off doubletap, and Dell's mouse driver only references PS2 port, but not "touchpad."
    This problem is slowly, surely, driving me mad.
  • auntemmy Aug 26, 2008
    I have a Dell Laptop XPS M140. Does anyone know how to disable the touch pad ?? Curser is jumping all over the place and I use a mouse. I am not very PC literate so please make it easy :-) I did already check the mouse area under control panel and there ws no option to adjust the touchpad.
    Thanks in advance !!!!
  • newfiern Feb 10, 2009
    dell inspron 1505 the mouse pad is too sensitive
  • athul007 May 02, 2009
    when i go near something it automatically clicks.how to stop this problem?
  • 59 Answers
Hi, click on start and control panel. go to mouse properties. Try to look for a tab that says either touch or touchpad. you can change the sensitivity settings there. however if this doesnt work, this could only mean that this is a physical problem with the toucpad. try to apply pressure on the outer side of the touchpad. if it moves, you're gonna need a replacement palmrest.
Posted on Oct 02, 2007
My mouse section in controlpad has no touch item. I went to pointer on the mouse page and reduced the number lines to 1. This solved my problem.
Posted on Oct 06, 2010
  • carrt7 Jan 14, 2011
    "reduced the number lines to 1" - what do you mean?
    I too am desperate to solve the problem!
    carrt7
    www.godornot.org
Demmy,
as was pointed out, we have lost the touchpad tab in the Control Panel "mouse" section. First question is how do we get the touchpad back so that we can go in and adjust the sensitivity? (it is taking me ages to type this because the cursor is jumping all over). AND, I don't even have to touch the touch pad to make it move. Just coming close seems to trigger the problem (particularly with my right thumb.
Posted on Nov 20, 2009
I have the same problem the mouse clicks everything i move over!
dell xps 1710
what should i do
www.nottinghamtiling.co.uk
Posted on Oct 11, 2008
Go to the Dell website and download the touchpad drivers for your particular laptop.
Then when you go to Mouse settings in control panel, you can tweak the touchpad settings.
Posted on Oct 29, 2008
  • carrt7 Jan 20, 2011
    For 64bit Windows7 the Dell website provides drivers that do not work. The 64bit driver ignores the touchpad, and the 32bit driver will not install.
    The solution is to download the Synaptics touch-pad driver from their site. For my Dell Inspiron640m, running Win7 64bit, the driver is athttp://drivers.synaptics.com/Synaptics_v...
    Once you install the Synaptics driver, "touchpad" appears in DeviceManager instead of "mouse", and you can adjust its properties. In particular, you can turn off "Tap function", so that touching the touchpad does NOT perform a left-click and screw up your typing.
    carrt7, www.godornot.org
  • MGDarth Apr 19, 2011
    Ok radical solutions but it works.
    1, you tried all the other software hints and suggestions they dont work for you read on.
    2, Have a special table with monitor keyboard mouse and use netbook connectors so you have a real keyboard and monitor these can be bought fairly cheaply and look cool.
    3 Ok OK you want the REAL solution read on i will tell you, get a playing card the joker is a good one or any peice of card will do cut it to cover the square of the touchpad but leave a small empty square at the front so it looks like someone took a litlle bite out of the card.
    stick this on top of your touchpad and it wont work aaah no one more step take a standard duster the yellow ones and cut out the same shape of the card with the gap then place the cloth and the card and stick them down with clear sellotape, you have now insulated the sensor and have a small gap in the middle so the touchpad is TINY but still works and this solutions was typed without the cursor flying all over the place like it did before IT WORKS .. tell the others who are going potty.
Can't shut off touch pad for typing, Dell N5050
Make sure the Alps Pointing Device Driver (for the touch pad) is loading at startup so you get the option to toggle this on/off with the Fn/F3 key combination.
Start->Search msconfig should get you the program you need to run to check- look under startup tab and ensure the Alps Pointing Device driver is checked.so it's loading at startup.
Hope this helps.
Jun 11, 2014 | Dell Inspiron 15 (N5050)
Dell Inspiron 1700 laptop
Reinstall touchpad drivers and / or decrease the sensitivity of touchpad from mouse/ touchpad settings in control panel. It will work.
Nov 08, 2012 | Dell Inspiron 1501 Notebook
Dell xps m1330 vista home curser jumps when typing
Have you loaded your touchpad drivers? The only time I've ever seen than happen is when the touchpad drivers aren't loaded. The touch is extra sensitive if your palm(s) just barely touch the pad.
By loading the touchpad drivers, you should be all set
Oct 27, 2012 | Dell XPS M1330 Notebook
I have a Dell Inspiron 1545 which has three problems, the battery discharges faster than when used by another computer of the same make, the screen lighting often blinks severally before it completely goes...
http://download.cnet.com/ccleaner/
run crude cleaner to get the flicker and speed the laptop up
get a new battery... if discharges too fast.. like less than 45 minutes
cursor jumping around.. watch your touchpad..
commonly you are touching the mouse pad during some keystrokes
you can set the mouse pad sensitivity downward under control panel--> mouse---> synaptics mouse pad sensitivity also
Jan 21, 2011 | Computers & Internet
My curser sonstantly skips around. how do i fix it?
If there is grease from fingers on the touch pad, that can cause spurious movement of the mouse pointer.
Clean the touch pad with an almost dry cloth and clean washing up water.
Jan 19, 2011 | Dell Inspiron 1525 Notebook
My Dell Inspiron 6000 notebook computer curser "jumps around"
I frequently have the same thing when using a Dell laptop. The problem MAY be with the touch pad. Without noticing it, my thumb touches the pad and away goes the cursor!
So try this: Open the control panel and go to mouse. Look at the top for Touchpad. There is a setting in there for sensitivity. Reduce the setting so that you need to apply more pressure on the touch pad to move the cursor. Test it a few times to make sure it is still functional before closing the control panel. Then try typing something in a word processor and see if it is any better.
Good luck, and please let me know if this helps.
~ Spoem
Mar 30, 2009 | Dell Inspiron 6000 Notebook
I have trouble when typing. The letters skip all over text.
Do you have a small button on the top side of the touch pad that will allow you to turn off the mouse? I bet that you are accidently touching the mouse pad with your thumb while you are typing, and this is causing your problem. I have the same problem if I do not turn off the touch pad on my laptop.
Good luck, and please rate me, OK?
Mar 16, 2009 | Dell Inspiron 6000 Notebook
Dell Inspiron B130
Hello, this normally happens on laptops. I think that it is from the sensitivity of the touch pad. You would have to check the position of your hands when typing since when your finger happens to touch the pad unexpectedly, the cursor quickly jumps to where ever the mouse pointer is: As a result, whatever you type next will rather go there instead of your current position.
Hope that helps
Thanks
Nov 08, 2008 | Dell Inspiron B130 Notebook
How can I stop my curser from jumping around whilst typing ?
Hello
Most probably because your 'Touch Pad Mouse' is touched by your palm (hand or something) while you are typing. Avoid contact with the mouse touch pad while typing.
Option 2:
If you have a centre moveable mouse on your laptop, start using it and disable the 'Touch pad mouse'
Best of luck!
Jul 23, 2008 | Acer Aspire 5100 Notebook
Keyboard curser bounces around
Are you bumping the touch pad while you type? This may be causing the curser to move around. This laptop is known for its sensitive touch pad.
Apr 19, 2008 | Computers & Internet
Computers & Internet Logo
14,673 people viewed this question
Alun Cox
