When no music is on the subwoofer makes low rumble sound
It's passing "engine noise" at 80hz and below. If you turn off the crossover on the amp, it will be unbelieveably loud. Check your RCA connections at the deck and at the amp. Then make sure your ground wire to the amp is solid and not oxidized. Check your battery terminal as well. Make sure your ground wire is the same gague as the power, and that it's grounded to the floor, not a seat bolt or side panel, as they are very poor grounds. Hope this helps. If you still have an issue, post a comment and I can help some more.
