Question about Motorola Mobility RAZR V3
Pink razr v3m
My "mno6" key won't work and neither will my right arrow key. i haven't dropped it or got it wet. i read somewhere to do a "master reset"...how do you do this?
    Brigadier General:
  • 7,752 Answers
A master reset will not help that problem that you are having , take the phone to a mobile service center and have them replaced the flexcable and that will correct the issue.
Posted on Feb 15, 2008
SOURCE:
Motorola Razr flip phone stuck on contacts, right arrow key won't work. I turned phone off & removed battery & still won't work
Hi Anne,
In that case you will need to perform an FDR (Factory Data Reset), How do reset my DROID RAZR here you will find the steps to do that.
Regards,
Maya
Motorola Support
Jul 17, 2016 | Motorola Mobility Lot Of 3 Razr V3c V3m...
My V3m was dropped yesterday on concrete. It now
I think that the headset pin/port is shorted inside. And your headset is inserted. So it produces now sound.
Or
the ear speaker is damaged for sure.
I hope this helped...
Jan 06, 2010 | Motorola Mobility RAZR V3m Cellular Phone
Master Reset
the OPCODe can master reset the phone. I screwed up my phone by trying to change the theme and evry time i pressed menu the phone restarted. However, i found a post on another site that read...
For me, Motokit, PTS, and the reset of the tools could not reset my phone. Here's how I reset my phone with just the phone keboard.
This will reset all your menus. On my Verizon Razr V3m phone, my contact and my picture gallery were not affected. (Make sure you key the command in exactly. 18*1 is Master Clear, and you don't want do to that.
From your phone, enter this sequence to go into OPCODE mode fairly quickly:
Press CLR then
048263*
This puts you in OPCODE mode, where you can enter special commands. Be CAREFUL here.
Enter a the code for a Master Reset command:
18*0
Press the middle navigation button.
Wait. The screen should show "SUCCESS" after a few seconds.
Push the LEFT soft key (back). You'll be back at the OPCODE screen.
Push the RIGHT soft key (options). Push this button again to select Cancel Entry (the only option).
This gets you out of OPCODE and back to where you started. You might have to push CLR a few times to clear the number you entered to get into OPCODE mode.
It was really helpful
Aug 16, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Removal of sim card from Motorola RAZR V3m Cellular
The RAZR v3m doesn't have a sim card. The arrow is showing how to insert a micro SD memory card.
Jul 24, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Motorola V3m Razr
this is an failure or corruption of core software...u might just keep it on charging for a while...then remove the batteries for an hour...then again switch it on with sim...if that works then again do same thin wit sim....if stil then master clear the phone...or take to an moto assist dey'l clear ur phone...
ne other prob's do tell me..N plz do rate me
cya
Apr 09, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Razr v3m not lighting up
ok, there is nothing you can do but having to go out and buy a new phone from verizon, your phone is pretty much shot.
Feb 05, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Memory full error
If this is for a Verizon phone:
Menu -> Messaging -> Settings -> All Msg -> Auto Erase
Set it to on and select OK.
If you go back in and set it back to off, you should now be able to send text messages!
Jan 22, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Dropped in water
the water probably caused a short in the screen conector.
sorry but liquid and electronics just don't mix
Nov 07, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
