SOURCE: I have a 10KW SIEMENS
Most of those chargers have a fuse in line between the battery and the charger which you should check. They are two stage chargers meaning when there is a large voltage drop, they go to a high rate charge until battery voltage reads about 14.3 - 14.6 VDC then drops to a float volatge and normal float voltage should be about 13.33 VDC. When they go to a high rate the light turns red, when they go to float the light turns green. When the fuse blows the light stays green because it doesn't see any voltage but the charger isn't doing any work.
