Question about Power Acoustik LT-980/2 Car Audio Amplifier
Red light my amp when all hooked up the red light comes on, i checked fusses and there where fine, im running two 12" duals is it to much?.. i dont no waht to do help
  • 631 Answers
It sounds like the output transistors have failed. Disconnect everything from the amp except for the B+, ground and remote and turn the amp on. If it goes into protect, the amp is in need of repair. If you want to repair it yourself, email power acoustic for the schematic.
Posted on Oct 02, 2007
I have my amp hooked up right to two 12 inch subs but the red protect light comes on wht does this mean?
Check all your cable work.
Power is connected tight? Ground is attached tight - on both ends (my guess is it is the ground) Remote cable?
Is the ground a proper ground?
Mar 01, 2011 | Dual XPA2100 2/1 Channel 300 Watt...
Need help.. I have two 12 inch dual voice coil kicker comp vrs.. they are 4 ohm subs..how do i wire them to get a final ohm load between 1.5 to 4ohms in a dual enclosed box...Im hooking them up to a jl 500...
To do this they MUST be wired in parallel, IE: Plus to Plus, Negative to Negative. 2 4 OHMS in parallel is about 2 OHMS in series it would be 8 OHMS... series is positive to negative. Are you using a crossover network?
Mar 05, 2010 | Kicker CVR12 Car Subwoofer
My dual speaker box has lights but they dont turn on i have tried hooking the power to the amp but still no luck
they should need power and ground! if they do not come on might be burnt out! Lights in and on boxes burn out fast cause of all the vibrations!
Oct 22, 2009 | Dual BANDPASS 12 " SUB BOX ENCLOSURE...
Kenwood KAC-8401 light goes from blue to red when turned on
Either the amp is ad or the sub got shorted? You can check itby disconnecting the Sub and seeing if the amp comes on blue then. If yes, then the sub is shorted. If no, then the amp is shorted. Also chck the voltage AT THE AMP. Make sure that it is above 12 Volts.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Dec 29, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Is this ok?
yes 2ohm should be fine for that amp no problem
But dont bridge it any lower than 2 ohms.
Nov 26, 2008 | Rockford Fosgate Punch P4004 Car Audio...
Cd player
The yellow wire goes to + (hot) 12 volt constant, red wire goes to ignition switch, Hook up your amp together with the red wire
(switched) and the amp will come on with the ignition switch.
Blue and white wire is for the power antenna.
Leadispenser
May 28, 2008 | Kenwood KDC-2011S CD Player
Power Acoustik LT-980/2 Car Audio Amplifier Logo
212 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Marvin
Marvin
Jose Velazquez
Jose Velazquez
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
