Question about Mag Innovision LT982s 19" Flat Panel LCD Monitor
Mag Monitor LT982s model900p
Issue need to purchase power supply inverter board, where can i buy or go to find one? Thanks
  • mugg Oct 02, 2007
    this is a MAG computer model LT982s 900p
  • chesebrob Mar 02, 2008
    issue need to purchase power supply inverter board, where can i buy or go to find one also what is the part #?
    Thanks
    Brigadier General:
  • 6,966 Answers
Hi, Try this link http://www.pchub.com/uph/category/43/LCD-Inverter.html In some instances inverters for other brand/model will also work for your Mag. You just have to match the part number. Good luck and kind regards.
Posted on Oct 02, 2007
SOURCE:
I have a mag innovation flat screen computer monitor but I need the power cord for the monitor it is a LT717S model # 700P made in 2006
The power lead you need for this monitor is a standard EU 3 pin. you can purchase these from any good electrical or computer store.
The look like the old Kettle plugs if its of any help
Jul 24, 2010 | Mag Innovision LT982s 19" Flat Panel LCD...
I don't have the origional plug but I have an identical one, but my monitor won't turn on.
You more likely to thave power supply problem.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 09, 2010 | Mag Innovision LT982s 19" Flat Panel LCD...
Screen goes blank after being on several seconds
Is the green light on (still indicationg power? Ist put your ear to it and switch on - hear any buzzing? Most like the HV Fluro Inverter for the lamps has an issue. For some the 2SC5707 may have gone - common.
May 29, 2009 | Mag Innovision LT776s 17" LCD Monitor
Monitor only power's on NO sound and No Picture
check your cable to speaker of your monitor and to the audio output of your pc.
May 20, 2009 | Mag Innovision LT982s 19" Flat Panel LCD...
Mag lt982s no green light no power at all
try testing it in another outlet a known good outlet if it powers on then your outlets bad if it doesnt means a bad cord or bad monitor
Feb 10, 2009 | Mag Innovision LT982s 19" Flat Panel LCD...
Screen went black/won't power on
This is a common problem
The first step is to check the fuse on the power supply board. Next, disconnect the inverter board to eliminate the possibility of it shorting down the main and or power boards. Be careful as the inverter board supplies high voltage to the cold cathode tubes (backlights) and it bites HARD. If you disconnect the inverter and the power led comes up then replace the inverter board. (The screen will appear blank because you have no backlighting). If the power indicator still fails to light you need to suspect the main board first before the powwer supply board. The main board tells the power supply board to come on. You need to check the trigger from the main board to the relays on the power supply board. Also check the power connector to the main board because you should see +12V and/or +5V on at least some of the pins. If no power on the relay triggers then replace logic board. Then replace Power supply board last. Or buy a new monitor!!
Oct 26, 2008 | Mag Innovision M572TVs LCD Television
Mag Innovision LT982s 19 in
yes the power supply or capacitors are shot. the part u want is from proview technology inc
attn: parts dept.
7373 hunt ave
garden grove,CA 92841
it is the lcd power supply, P/N 860-ALZ-M713W-f
F0742683G
1-800-776-8439 follow prompts....ed
Jul 20, 2008 | Mag Innovision LT982s 19" Flat Panel LCD...
Mag Innovision LT982s screen problem
Based on your post/description, I will initially suspect the inverter and/or the CCF Lamps since as you posted "dim screen picture" indicating that there is ** backlight(s) and/or it is **t receiving power from the inverter.
If the unit is relatively new and under warranty, it may be to your advantage to have it replaced or seek the services of their Service Center. Should you want to do a DIY, it would be required that you be familiar with electronic circuitry and components, use of a DVM and a soldering iron and access to a service manual or at least a schematic diagram.
Incidentally, there are k**wn cases where similar issues could be resolved if you try lowering your display properties (resolution and refresh rates) but that would also include the powerlight changing colors.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Thank you for using FixYa.
Mar 09, 2008 | Mag Innovision LT982s 19" Flat Panel LCD...
MAG Lt982s
Hi all,
Below is a re-post of my response to similar issues.
...Based on your post/description, I will initially suspect the inverter and/or the CCF Lamps since as you posted "dim screen picture" indicating that the backlight(s) are defective and/or the inverter is not supplying (sufficient) powere to the lamps.
Incidentally, there are known cases where similar issues could be resolved if you try lowering your display properties (resolution and refresh rates) but that would also include the powerlight changing colors.
Dec 11, 2007 | Mag Innovision LT982s 19" Flat Panel LCD...
Mag Innovision LT776s Model 780
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Nov 23, 2007 | Mag Innovision LT776s 17" LCD Monitor
Mag Innovision LT982s 19" Flat Panel LCD Monitor Logo
565 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Steve Allison
Steve Allison
Damen Wong
Damen Wong
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
