Question about Logitech WingMan Warrior Joystick
Warrior Compatibility I connected the 9 pin connector to a Dell computer but there is no response in running FS2004. Not sure of where to get a driver or if I need one---don't have a load CD for the logitech Wingman warrior.
  • Anonymous Mar 18, 2014
    I calibrate it with windows control panel, it registers there but... when i move it or hit the fire button... no response. maybe it is just broke? I'd be willing/able to fix it if i knew anything about them
Buy a connection from a "9 pin" to a USB output
Posted on Nov 10, 2007
What is the third external connector besides the power and SATA connectors ?
In some cases an IDE connector is added to RAID Hard Drives or Industrial grade desktop computer drivers.. it's a backwards compatibility measure in case of failure.
Other driver may also include an IDE power source too..
Those IDE connections are also known as (PATA) or Parallel.
Nov 17, 2014 | Western Digital Caviar Computers &...
Dell.com
The Windows Vista/7 driver may work. Others have managed to get the 9 to work but Dell doesn't have a Win8 driver. First are you installing the printer for the first time to the computer or did you upgrade the OS and are reinstalling the driver? If you have done an upgrade or attempted to install once before, you will need to delete any jobs in the printer queue.(Win+X > Control Panel > Hardware and Sound > View Printers and Devices. Select your printer and then see what's printing. Cancel all jobs.) If you can't delete the jobs, press the Windows key and type in Command Prompt. Right click on the appropriate program and at the bottom of the screen, select Run As Administrator. Type in "net stop spooler" followed by enter (without the quotes). Follow that line with "net start spooler" again followed by pressing enter. After you see the responses, restart the computer. Then unplug the printer from the computer. Then uninstall the printer driver. (Win+X > Device Manager. Expand the Printers section. Right-click on the printer and then select uninstall driver.) Manually remove the printer from the Devices and Printers list. (Win+X > Control Panel > Hardware and Sound > View Printers and Devices. Select your printer and then click Remove Device.)
The driver itself is available here: http://www.dell.com/support/drivers/us/en/19/Product/dell-966 . Make sure that you select the x64 version if you have a 64-bit version of the OS. Most desktops and laptops currently sold have the 64-bit version of Windows 8. An older computer that was upgraded may have the 32-bit version of the OS.
Find the install file that you downloaded from the Dell site. Right click on the file and select Properties. Under the Compatibility tab, choose Always Run in Compatibility Mode for Windows 7 (use the drop-down menu to select the OS version). Click Apply and then OK to save the setting. Now double-click on the installer to run it. You will need to acknowledge the UAC to allow the program to run. You will need to repeat this Compatibility step on the Setup file after extracting the files from the downloaded file. Keep track of where the extraction places the files; my computer showed the default location of C:\dell\drivers\R165704 .
Tablets with Windows RT probably can't use the driver since it isn't offered through the Windows Store.
I hope this helps.
Jun 25, 2013 | Computers & Internet
Is there any possibility of making this printer compatible with windows 7
With Windows 7, I found that installing the Vista software/drivers in the compatibility mode works well.
Right click on the setup.exe file, left click properties, left click compatibility. Change the compatibility to Vista(Try Vista SP2). Then install the proper drivers. You'll be prompted when to connect the printer(powered on).
***To install drivers, sometimes the file unzips and does nothing. You have to look for the setup.exe file, right click on it, then left click run as administrator***
As for scanning, if you have the disk that came with the printer, then insert the Printer disk and stop it from running. Go to My Computer and double click on it. Look for the drive with the Dell disk in it. Right click on it, left click explore. Look for the OCR Folder. In the OCR Folder, there is an Abbyy Folder. right click on setup.exe, that's in the Abbyy Folder and left click run as administrator. This will install the OCR program.
Scanning
Scanning using USB connection, open the Dell All-In-One Center, click on scanning and copying and scan from there.
Scanning wirelessly, use the scan buttons on the printer.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jul 01, 2011 | Dell A940 All-In-One InkJet Printer
Princes of persia Warrior within if you can help me to change the settings on Prince of persia warrior within to windows 7 i can't play in windows 7 can you hellp me Plizz ^_^
Have you tried changing the properties of the shortcut to run in WinXP SP2 compatibility mode?
Right click the shortcut, goto properties/compatibility tab, choose "WinXP SP2 compatibility mode" in the dropdown box, then click apply.
This should solve your problem. If not, come back with a bit more detail, and it can go forward from there.
Hope that helps.
Cheers from NZ
May 09, 2011 | Ubi Soft Prince of Persia: Warrior Within...
I have a Veratec desktop computer and am having all kinds of problems with it. It is one year old. Will not communicate with my dell printer A920 and is difficult to operate otherwise. Please help.
Well what operating system do you have on it? Windows7 doesnt like some printers. check online for print drivers and update them. Follow this link to help you with that... http://support.dell.com/support/topics/global.aspx/support/kcs/document?c=us&l=en&s=gen&docid=DSN_FA36C542525D975EE030030ABD621881&isLegacy=true
you can also try this approach... First, let's make sure your computer has the latest Windows Updates, especially .net framework, needed to run many applications and the latest Java.
Disconnect your printer.
Download and run this patch (***WARNING*** The patch for this printer also removes other Dell applications, like Dell Dock, Dell QuickSet and other Dell applications)(These applications can be downloaded at Drivers & Downloads and can be reinstalled) to completely remove the printer from your computer. Run the patch(A MUST on Vista Machines) until it prompts you to restart your computer.
If using Windows 7 also try...Manual Printer Driver Removal
Restart your computer.
Download the proper drivers.
XP Drivers
Vista 32-bit Drivers
Vista 64-bit drivers
All other drivers
Install the proper drivers. You'll be prompted when to connect your printer(powered on)
If using Windows 7, use the Vista drivers in the compatibility mode.
Scanning
Mar 04, 2011 | Computers & Internet
Dell Inspiron 1525 - Firewire not working
It may be the communication setup.
You might need to set within the Camera PTP protocol.
The WD drive specs out a 6 pin connector, not a 4 pin.
Nov 17, 2008 | Computers & Internet
Want to connect to my computer
What connector/interface does your PC has
9-pin or 25-pin connector
If it has 9-pin connector: use the following:
DB-9 RS-232 Serial Connection
or
DB-25 RS-232 Serial Connection
If it has 25-pin connector: use the following:
DB-25 Serial Connection
or
If you are configuring the computer to use an RS-422A serial port, you need a special cable. Contact the computer or printer network manufacturer to see if an RS-422A cable is available. If no cable is available, contact your computer manufacturer for your computer pin assignments and have a cable constructed.
The default configuration for the serial port on the printer is for RS-232C serial communication. To set the printer to use RS-422A serial communication, change the control panel Serial Menu’s SERIAL setting to SERIAL=RS-422.
Oct 29, 2008 | HP LaserJet 4 plus Printer
Fitting an internal card reader
hello weave!m just curios if that 9 pin is a serial type connection?then if it is..you shoud find an adaptor for a serial port or any port that fits ur 9 pin connector.if u can find a PCI card that has a 9 pin port..then you can connect..just feed me back for your more details.
Jun 19, 2008 | Dell Dimension PIII Tower Computer XPST500...
No 9 pin video socket
Most video cards use a 15 pin VGA connector.
There is also a 9 pin VGA connector, but they are a lot less common - I'm guessing this is what you have.
Is the video cable hard-wired into your monitor or is it connected via a plug? If it's a plug, is that a 15 or 9 pin? If it's a 15 pin, then all you need to do is buy a new 15-15pin VGA cable.
If it's hard-wired, you'll need to buy some sort of adapter. These are available and don't cost much either, but you might need to try a more specialist computer store to find one.
Hope this helps!
Matt
Feb 29, 2008 | Dell Dim.9150 Pentium D 820 Dual...
Logitech WingMan Warrior Joystick Logo
283 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Alun Cox
Argospete
Argospete
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
