Question about Dell 922 All-In-One InkJet Printer
Dell 922 AIO printer~~ does not power on when press power button all cords are connected ~~ is there a power supply in the power cord that fails ??
  • 2 more comments
  • iroman71 Nov 30, 2007
    My Dell 922 AIO printer doesn't power on and the power button light is flashing. The ink carrier doesn't move when I open the printer.
    Is this a power supply problem, too?
  • whathcock Feb 01, 2008
    I have the same problem. We had a power outage today. Afterward, the printer will not power on. I've looked at the power adapter & it looks OK, but it could be the problem
  • watson36092 Mar 29, 2009
    printer will not power up. I replaced the power adapter and checked the current. Everything is right but printer still won't come on when the power button is pressed.
  • Anonymous Apr 26, 2009
    I hooked all cords to proper outlets and pressed power
    button -- but nothing happens so frustrated!@*& ARGHHHHHHHHHH!!!!!!!!!!
    PLEASE HELP!!!!!!!!!
I had a simalar problem. On the back of the printer where the power cord plugs in it is connected to a power adapter. The adapter was burnt out. the power adapter slides out. Mine was melted easy to see. I ordered one from dell. If you do order one from dell make sure they send you the correct part. They sent me the wrong part the first time. There customer service dept. ha gone way downhill.. Regards Frank
Posted on Oct 04, 2007
Where can I find replacement power cord and adpater?
what country you need to state voltage that come out of power point - is it 120 volt or 240 volt because it has to match with power supply check with seller before buying anything and definately before plugging it into a power point .
. Try amazon see http://www.amazon.com/Adapter-Supply-Charger-Dell-Printer/dp/B00L1WTFCA/ref=sr_1_fkmr3_2?ie=UTF8&qid=1404525964&sr=8-2-fkmr3&keywords=DELL+AIO+V313+ac+power+supply or search in google with Dell AIO V313 ac power supply
Jul 04, 2014 | Dell V313w AllInOne InkJet Printer
When pressing the power button on my Dell AIO 962 printer to turn the printer on, nothing happens. What could be the problem?
Please try to check your power cord if it is not defective or make sure that your printer is plug into the power source. You can try to used other power cord to test if your power cord is the problem.
Thanks
Aug 18, 2009 | Dell 962 Photo All-In-One InkJet Printer
I can't print in color on dell photo 964
try to uninstall ur driver and install it again
Jun 07, 2009 | Dell Photo 964 All-In-One InkJet Printer
Print head problem
Do a reset:
Dell Printer reset
1. With the power on,unplug the power cord from the wall socket.
2. Disconnect the power supply from the back of the printer.
3. Wait 15 seconds.
4. Reconnect the power supply to the back of the printer.
Plug the power cord back into the wall socket.
Dell Printers
To run a nozzle clean, perform the following steps:
1. Verify the All-In-One Printer 922 is powered on and connected to a computer.
2. Verify that the paper support (input tray) has clean, plain white paper loaded.
3. Press the Menu button.
4. Press the Down button until Mode: Maintenance appears on the LCD screen.
5. Press the Menu button.
The Dell 922 Maintenance Menu appears on the LCD screen.
6. Press the Down button until Clean Cartridges appears on the LCD screen.
7. Press the Start button.
The AIO 922 prints the cleaning page. This process cleans the ink cartridges and resolves many print quality issues.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 02, 2009 | Dell 922 All-In-One InkJet Printer
Skipping while printing
STEP: Disconnect and Reconnect the Printer Power Supply
Additional Information
1.
Unplug the power cord from the wall socket.
2.
3.
Wait 15 seconds.
4.
5.
STEP: Perform a nozzle clean on the printer.
The following steps will guide you through running a nozzle clean on the 922 printer:
1. Press the Scan Button and the Up Button at the same time to enter diagnostic mode.
2. Use the Up Button or Down Button to navigate to Clean on the LCD and press Menu to begin the nozzle clean.
3. Check the nozzle clean printout and make sure that it is clear of defects and that all expected color bars exist on the page.
STEP: Clear NVRAM on the 922 Printer
1.
2.
Use the Up Button or the Down Button to navigate to the option for Clear NVRAM on the LCD and press Menu to confirm.
3.
Press Menu again when asked if you are sure.
4.
Press Menu again when asked if you are really sure.
Ink Cartridge and Print Quality Issues on Inkjet Printer
STEP: Verify the Paper Settings and Change the Quality Level
1. Click the Start button, point to Control Panel, and then click the Printers and Other Hardware menu item.
2. Click the Printers and Faxes menu item.
3. Right-click the Dell AIO Printer Model Number icon, where Model Number is the model of the printer to troubleshoot.
4. Click the Properties menu and the Printing Preferences menu option.
5. Click the Quality/Copies tab.
6. Click the Paper Setup button.
7. Choose the appropriate paper type based on what is being used in the printer.
STEP: Verify the Printer Ink Levels
Quality problems are most often caused by low ink levels or one or more colors in the color cartridge being completely depleted. Perform the following steps to determine the current ink levels and to check for missing colors.
1. Click the Start button, point to All Programs, and then click Dell Printers.
2. Click the model number of your Dell printer.
3. Click Dell Printer Solution Center.
4. On the main window of the solution center you will see two ink tanks in the lower right hand corner. Verify that the ink cartridges are not empty
To ensure that the quality problem is not caused by one color missing print a test page and verify that the colors in the CMYK boxes appear correct. To do so, perform the following actions from the solution center window:
1. Click the Maintenance button on the left-hand side of the window.
2. Click Print Test Page.
3. Verify that the Cyan, Magenta, Yellow, and blacK colors are printing without streaks.
Apr 22, 2009 | Dell 922 All-In-One InkJet Printer
Dell printer aio 922
press the continue button and it will print.
Sep 27, 2008 | Dell 922 All-In-One InkJet Printer
922 power supply cord is missing from my classroom
Standard cord any printer repair centre will have heaps, one type of cord which i think your printer uses is looks like and we call it a figure 8 cord, the other standard has 3 holes and I refer to as a kettle cord.
Pinch one from lamps, radio's, stereo's etc
Oct 20, 2007 | Dell 922 All-In-One InkJet Printer
Scaning . . . Scanning. . .. not scanned
Not sure if this is the correct way around, but it worked.  Go to Start --> All programs --> Dell Printers --> Dell Photo AIO Printer 922 --> Dell All-in-one center
From here, you can determine and change your scan settings as needed;  then click "scan now" (thus by-passing the button on the actual AIO machine).  This scanned photos into my picture program so I could email to all the grandparents!
Nov 14, 2006 | Dell 922 All-In-One InkJet Printer
Scanner issues
driver problem reinsatll software drivers
Oct 03, 2006 | Dell 922 All-In-One InkJet Printer
Dell 922 All-In-One InkJet Printer Logo
405 people viewed this question
Top Dell Office Equipment & Supplies Experts
David Patricia James
Marvin
Marvin
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
