Question about Samsung YP-K3 MP3 Player
It says filename,directory name or volume label syntax is incorect
After i install all the needed software the wizard prompt me saying that the MPT Device won't be instaled because there's an error: filename,directory name or volume label syntax is incorect... Can you please help me,i'm getting nut's about this
Try reformatting the device using the software you use with it. This should fix any naming errors. you will need to put all the songs back though
Posted on Feb 15, 2008
Try formatting the device using the software - either rhapsody, Samsung Media Player or normal windows Media Player. That shoudl fix any naming errors. Then re-install the software.
SOURCE:
My Dane-elec 8GB files are not working. When click the error message: The filename, directory name, or volume label syntax is incorrect. How do I recover my files?
Hi Ayanna S, I want to help you with your question, but I need more information from you. Can you Call +1(518)348-9393
Nov 12, 2016 | Computers & Internet
This is problem in my laptop -- Windows Script Host -- Loading script "C:\WINDOWS\:Microsoft Office Update for Windows XP.sys" failed (The filename, directory name, or volume label syntax is incorrect. ).
please anyone help us to how to resolve this . This is problem in my laptop -- Windows Script Host -- Loading script "C:\WINDOWS\:Microsoft Office Update for Windows XP.sys" failed (The filename, directory name, or volume label syntax is incorrect. ).
Apr 04, 2013 | Microsoft Windows XP Professional With...
I have samsung hdd of 60 GB. I use it from last 6 years. Now i am not able to format and check disk my hdd It gives error. I used Hutil disk diagnosis software it gives 'write verification test failed'. I...
Seems like the disk is gone. 6 years IDE hard disk is somewhat old.
Now, Samsung hard disks support SMART monitoring.
Get some tool for SMART monitoring
http://sourceforge.net/projects/smartmontools/
If it shows problem for the hard disk, then nothing can be done.
If there is important data you need, you can try file recovery softwares. But I cannot say if it will work or not.
Aug 13, 2010 | Computers & Internet
How to install package manager in ubuntu?
A package manager is a program that installs and uninstalls software, and keeps track of all the components each piece of software needs.
Dpkg is the Ubuntu package manager dpkg is a medium-level tool to install, build, remove and manage Ubuntu packages. The primary and more user-friendly front-end for dpkg is dselect.dpkg itself is controlled entirely via command line parameters,which consist of exactly one action and zero or more options. The action-parameter tells dpkg what to do and options control the behavior of the action in some way.
Now we will see all the available commands for dpkg with examples
1) Install a package
Syntax
dpkg -i <.deb file name>
Example
dpkg -i avg71flm_r28-1_i386.deb
2) Install all packages recursively from a directory
Syntax
dpkg -R
Example
dpkg -R /usr/local/src
3) Unpack the package, but don’t configure it.
Syntax
dpkg --unpack package_file
If you use -R option is specified, package_file must refer to a directory instead.
Example
dpkg --unpack avg71flm_r28-1_i386.deb
4) Reconfigure an unpacked package
Syntax
dpkg --configure package
If -a is given instead of package, all unpacked but uncon-figured packages are configured.
Example
dpkg --configure avg71flm_r28-1_i386.deb
5) Remove an installed package except configuration files
Syntax
dpkg -r
Example
dpkg -r avg71flm_r28-1_i386.deb
6) Remove an installed package including configuration files
Syntax
dpkg -P
If you use -a is given instead of a package name, then all packages unpacked, but marked to be removed or purged in file /var/lib/dpkg/status, are removed or purged, respectively.
Example
dpkg -P avg71flm
7) Replace available packages info
Syntax
dpkg --update-avail <Packages-file>
With this option old information is replaced with the information in the Packages-file.
icon_cool.gif Merge with info from file
Syntax
dpkg --merge-avail <Packages-file>
With this option old informa-tion is combined with information from Packages-file.
The Packages-file distributed with Debian is simply named Packages.dpkg keeps its record of available packages in /var/lib/dpkg/available.
9) Update dpkg and dselect’s idea of which packages are available with information from the package pack-age_file.
Syntax
dpkg -A package_file
10) Forget about uninstalled unavailable packages.
Syntax
dpkg --forget-old-unavail
11) Erase the existing information about what packages are available.
Syntax
dpkg --clear-avail
12) Searches for packages that have been installed only partially on your system.
Syntax
dpkg -C
13) Compare Package versions version numbers
Syntax
dpkg --compare-versions ver1 op ver2
14) Display a brief help message.
Syntax
dpkg --help
15) Display dpkg licence.
Syntax
dpkg --licence (or) dpkg --license
16) Display dpkg version information.
Syntax
dpkg --version
17) Build a deb package.
Syntax
dpkg -b directory [filename]
18) List contents of a deb package.
Syntax
dpkg -c filename
19) Show information about a package.
Syntax
dpkg -I filename [control-file]
20) List packages matching given pattern.
Syntax
dpkg -l package-name-pattern
Example
dpkg -l vim
21) List all installed packages, along with package version and short description
Syntax
dpkg -l
22) Report status of specified package.
Syntax
dpkg -s package-name
Example
dpkg -s ssh
23) List files installed to your system from package.
Syntax
dpkg -L package-Name
Example
dpkg -L nagios2
24) Search for a filename from installed packages.
Syntax
dpkg -S filename-search-pattern
Example
dpkg -S /sbin/ifconfig
25) Display details about package
Syntax
dpkg -p package-name
Example
dpkg -p nagios2
Please check if this is any help for you.
Regards.
May 26, 2010 | Computers & Internet
Error the filename directory name or volume label syntax is incorrect when i connect my mp3 player
u shuld probably purge it, right lick, and format, but save that as a last resort, try right clicking, and renaming it
Sep 29, 2009 | SanDisk Sansa c200 MP3 Player
Cant finish installing mfc 490 cw printer install on my computer
Sounds like you may ahve the 32 bit version of the driver. Try uninstalling all brother software, then reinstalling the 64bit version from:
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/dlf/000000/003600/dlf003657.html?reg=us&c=us&lang=en&prod=mfc490cw_all&type2=1&os=84&flang=8&dlid=dlf003657
Jul 11, 2009 | Brother MultiFunction Center MFC-440CN...
Cannot delete my bad files...
Could be a process issue stopping you deleting the files. Try downloading unlocker (http://ccollomb.free.fr/unlocker/) and see if this helps.
If not it might be an 8.3 naming convention issue. Go to DOS prompt to a "dir /x /a". Rename the file to less than 8 characters using the SHORT name only. Then try deleting the file.
Apr 01, 2009 | Microsoft Windows XP Professional
Problem with opening ini files...
from each computer:
right click on a .ini file,
select 'open with...'
choose notepad and select the box that says 'always use the selected program to ope this kind of file'
click 'ok'
Apr 07, 2008 | Microsoft Windows XP Professional
Samsung YP-K3 MP3 Player Logo
255 people viewed this question
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
