Question about Canon PowerShot A95 Digital Camera
Failed shutter release
Pressing the shutter button will provide auto exposure and auto focus, but no matter how hard I press it, the shutter won't fire.
  • Canon Master
  • 4,738 Answers
If you decide to open your camera, here's a pictorial disassembly. Don't go any further than popping the top off to examine components in the vicinity of the shutter button. Look for anyhting different than what's showing in the picture. Remember that you can be creative with a little bit of glue, and a small piece of scrap plastic:
http://qman.fotokala.ee/Kaamerad/PowerShotA95/index.html
And keep in mind there's a potential for electrical shock. Read this first before you turn any screws:
http://camerarepair.blogspot.com/2007/11/important-warning-camera-flash.html
Posted on Dec 08, 2007
SOURCE:
Canon 60D
If the problem is exposure delay (2 seconds delay timer) check drive mode setting, set to single shot.
Jul 22, 2013 | Cameras
Olympus E-300 Evolt when you press the shutter button to take a picture, the shutter rapidly repets for about 9 times
Solution 1 • Unlock focus area selector. • Auto-area AF selected for Custom Setting 2 (AFarea mode): choose another mode. • Press shutter-release button halfway to turn monitor o?¬? or activate exposure meter • Memory card is full, locked, or not inserted. • Flash is charging. • Camera is not in focus. • CPU lens with aperture ring attached without locking aperture at highest f/-number. • Non-CPU lens is attached: rotate camera mode dial to M. • Mode dial rotated to S after shutter speed of bulb selected in mode M: choose new shutter speed • P, S, A, and M modes: lower ?¬? ash. • Digital Vari-Program modes: turn ?¬? ash o?¬? Turn long exposure noise reduction o?¬? Turn long exposure noise reduction o?¬? Press multi selector up or down or rotate sub-command dial to choose photo information displayed Select All for Playback folder. Note that Current will automatically be selected when next photo is taken • Select On for Rotate tall. • Photo was taken with O?¬? selected for Auto image rotation. • Camera orientation was changed while shutter-release button was pressed in continuous shooting mode. • Camera was pointed up or down when photo was taken Use Nikon-approved card. • Card may be damaged. Contact retailer or Nikonauthorized service representative. • Delete unwanted ?¬ les or insert new memory car
Jan 27, 2011 | Olympus Cameras
There is too much delay when I try to take a picture.
This is a common situation with most compact point&shoot cameras. The camera has to do a lot of work when you press the shutter release button: it must focus on the subject, meter the light for proper exposure, and switch the electronics from displaying on the LCD to recording the image to memory. Larger (and more expensive) cameras have additional hardware to deal with most of this, eliminating the "shutter lag."
You can reduce the lag by pressing the shutter release button halfway to focus and meter the exposure. Keep the button halfway down until the right moment and then press it the rest of the way down.
Nov 08, 2010 | Pentax Optio S7 Digital Camera
I have turned camera on and set up to take a photo and the shutter release button will not press in to take the photo. I used the camera yesterday and it worked fine!
Turn the camera on and look into the view finder while you try to press the shutter button. Check the information in the view finder to see whether you are getting an error message. If you see an error message in the view finder, remove the lens cap and proceed to take a photograph but, instead of pressing the shutter button this time, press the button near the top of the camera on the back which says "AF/AE. If the camera takes the photo it means you have somehow initiated the auto focus/auto exposure lock which the camera will not override when attempting to take a photo using the shutter button. When you use the AF/AE button, you override this system. To remedy this issue, when you get the error message try pressing the shutter button again. Also, remove the lens to see if the shutter inside has frozen in the "locked" position. If you find this to be the case you will need to contact Nikon Customer Support. The link for Nikon Support is below. The numbers are half-way down the page.
http://support.nikonusa.com/app/answers/detail/a_id/238
Oct 31, 2010 | Nikon D40x Digital Camera
Is there a timer on this camera?
Yes there is .......page 47 of the manual shows you how .... its an option on the drive mode in the startup menus.
http://safemanuals.com/user-guide-instructions-owner-manual/KONICA%20MINOLTA/DIMAGE%20Z1-_E
Self-timer
Used for self-portraits, the self-timer will delay the release of the shutter for approximately ten seconds after the shutter-release button is pressed. The self-timer is set on section 1 of the recording menus (p. 44).
With the camera on a tripod, compose the picture so the subject is within the focus frames. Press the shutter-release button partway down to lock the exposure and focus (1). Press the shutter-release button all the way down to begin the countdown (2).
Because focus and exposure are determined when the shutter-release button is pressed, do not stand in front of the camera when taking a self-timer image. Always confirm the focus with the focus signals before beginning the countdown
(p. 25).
The self-timer is counted down on the monitor. During the countdown, the self-timer lamp on the front of the camera (3) will start to blink and is accompanied by an audio signal. A few seconds before the exposure, the self-timer lamp will blink rapidly. The lamp will glow steadily just before the shutter fires.
To stop the countdown, slide the zoom lever to the left or right. The self-timer drive mode is reset to single-frame advance after the exposure. The audio signal can be turned off in section 2 of the setup
menu (p. 83).
Mar 03, 2010 | Konica Minolta DiMAGE Z1 Digital Camera
How do I change the shutter speed?
This is "shutter lag," the delay between pressing the shutter release button and the camera actually taking a picture. This is a common situation with many compact cameras. The camera has to focus on the subject, meter the exposure, and switch the circuitry from displaying on the screen to recording the image and saving it in memory. More sophisticated (and expensive) DSLRs eliminate this shutter lag by having more dedicated hardware for this.
With a compact camera, you can reduce the shutter lag by anticipating the shot. Press the shutter release button halfway to focus and meter the exposure. Continue to hold the shutter release button halfway until the right time, then press it the rest of the way.
Jan 17, 2010 | Canon PowerShot SX100 IS Digital Camera
How to get manual focus on Olympus Camedia C-750 ultra zoom digital camera
TTTTTTTTTTTTTTTTTTTTTTTTITf correct focus cannot be obtained
When the subject to be focused is not on the AF target mark (not positioned
in the center of the composition), you can use the following steps to obtain the
correct focus on the subject. This operation is referred to as "focus lock".
Determine the position of the subject after focusing (Focus Lock)
1 Press the power switch.
• The camera turns on in the shooting
mode.
• The lens extends and the monitor turns
on.
• The orange lamp lights.
2 Turn the mode dial and select a
shooting mode.
"Shooting mode" (P.36)
3 Position the AF target mark on
the subject you want to focus on.
• When shooting a hard-to-focus
subject, point the camera at an object
about the same distance away as the
subject.
Press the shutter button halfway
until the green lamp lights.
• When the green lamp lights steadily,
the focus and the exposure are locked.
• When the green lamp blinks, the focus
and exposure are not locked. Release
your finger from the shutter button, reposition
your subject and press the
shutter button halfway again.
5 Keeping the shutter button
pressed halfway, recompose
your shot.
6 Press the shutter button fully.
Try the above, info from D-535, C-370 and X-450.
I can email you the complete manual if this works.
Regards
Phillip
Sep 12, 2009 | Cameras
Shutter takes to long to take pic and subject has moved.
This is a common problem with compact point&shoot cameras.
You can reduce the delay by anticipating the shot. Pressing the shutter release button halfway focuses and meters the exposure. Keep holding it there until the right moment, then press it the rest of the way.
Jan 04, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
The camera takes too long to take a photo. What should I do?
Press the shutter button halfway and hold it to set the focus, then press it the rest of the way down to take a photo. If you press the shutter button down all the way at once, it takes time to focus and set the exposure before the shutter releases. It may take longer than when pressing the shutter button in two steps.
Sep 12, 2005 | Epson PhotoPC L500V Digital Camera
Canon PowerShot A95 Digital Camera Logo
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
