Question about LaCie 301103U 500 GB USB 2.0 Hard Drive
Bought a new LaCie drive; isn't recognized by mac or pc
I've tried multiple usb cables in addition to the one that came with the unit. I've tried my macbook pro and my ibm thinkpad with xp professional. neither even recognizes the drive is there. Tried using disk utilities on osx, but it doesn't recognize the lacie drive is plugged in, so can't do anything.
    Novelist:
    Champion:
  • 382 Answers
Lacie Porsche drives in my experience or infamous for not having the most durable bridge boards. The bridge board is a chip that has a chipset on it which take the SATA or PATA connection and send it to the USB and or Firewire ports on the enclosure. If the drive is powered up, you should get a small red or orange light on the front. When connected to either mac or pc ( porsches are MS_DOS formatted out the box ), if it does not mount or does not appear in DISK UTILTY, then it is a high probability that the enclosure/bridge board has failed and the drive ( if not making grinding, buzzing, clicking or beeping sounds) will have to be extracted and placed into a more stable enclosure. Hope this helps.
Posted on Oct 02, 2007
SOURCE:
Lacie d2 Quadra Ejects Itself
I've had issues with the lacie mini power supply before. I can cause some wierd issues. Unfortunately, it isn't the cheapest thing to replace but that's probably the best place to look first.
Oct 16, 2012 | LaCie 1TB D2 Quadra eSATA/USB 2.0/FireWire...
Usb cable is causing a short circuit
the first cable (throw it away), the secound use that one or a new one. then you will need to locate the drivers on the internet, download them and install.
Jul 20, 2012 | LaCie 500GB Rikiki USB 3.0 Portable Hard...
Good afternoon Customer Support, My 1TB USB 2.2 External Hard Drive has disappeared from my Desktop (Mac OS X). I installed my Lacie two years ago and it always appeared on the Desktop every time I...
Hi John
This situational you have to do only one thing change you USB cable and try, if your drive is appeared its mean you solve the issue. otherwise take the drive and go to the lacie nearest service center because the drive have internal problem (may be Capistrano fault).
Cheer
Sep 02, 2011 | Computers & Internet
I just bought my LaCie 301888KUA 1TB Starck Desktop USB2.0. I was following set up directions in the manual until I realized that my Mac OS X (version 10.5.8) is not recognizing the hard drive . It's not...
the problem is that your lacie drive operates using the NTFS (New Technology File System) under USB which is the standard file system of Windows. Apple mac is not interopable with native NTFS therefore you need to install a read-write NTFS file-system driver on your mac if you wish to use it via the USB connection.
an excellent free mac NTFS driver can be found here-
http://mac.softpedia.com/get/System-Utilities/NTFS-3G.shtml
download and install the software then restart your mac.
//javaftper
Jul 31, 2010 | LaCie 301888KUA 1TB Starck Desktop 1 TB...
I have a LaCie Rugged Drive, with multiple interfaces (USB, Firewire 400/800). Firewire interface works fine. When I plug the drive in the USB port, it won't mount (MacBook Pro OS X), and a faint beeping...
//javaftper
Jul 31, 2010 | LaCie (300951U) 500 GB Hard Drive
Running a lacie hard drive with mac mini - after 2 years will not show up on desktop or in utility disk window
There are several possible reasons for this.
The most common is a short or failure in the Lacie enclosure caused by mixing up power/AC adapters. If your two Lacie drives are different models and you accidentally used the wrong adapter you may have damaged the circuitry.
The second possiblilty is that your power adapter or USB/Firewire cables could be damaged. Try switching USB/Firewire Cables First. If this fails to work then check if you have a smae sized adapter with the exact same Output Voltage and Amps on both adapters. Only if they are identical try switching adpaters from the working unit. If they are not proceed to the below solution.
Finally if the unit was dropped, bumped or unplugged while it was running it is quite possible that you may have damaged either the drive or the file structure on it, either of which would cause it to stop showing up.
Solution:
Try the cable swaps if able, if they work, replace the USB cable or replace the entire enclosure if the power adapter is the issue.
If neither works then you have either a failed hard drive or failed enclosure. Go to your local PC store (not a big box and yes PC, they tend to have more experience and parts to work with in this type of situation), have the techs there remove the drive from the Lacie enclosure and place it in a new enclosure for testing. They may not be able to see your files but they will be able to tell if the drive is working. If it is, buy the enclosure, then connect the drive back to your Mac. If it works you're done.
If the drive works but the Mac still doesn't recognize it(doesn't show up on the screen), then comment back and I will get you the link to a program you can use to retrieve the lost files.
If the drive simply fails to show up at the store in the new enclosure you will need the help of a pro to recover any important files. If that is the case reply with your location, Country, State and City and I will recomend an appropriate facility for you.
Hope this helps FixYa,
Chris
Jan 30, 2010 | LaCie Computers & Internet
Lacie 300790 that my Mac won't recognize
the Mac may not recognize it if it is formatted with NTFS. I believ most Macs can read FAT32 and other formats but not NTFS. You could hook the drive up to a modern PC, transfer the files there for a while, format the external drive to FAT32 and copy the files back to the drive. The Mac shold read them now,
Sep 21, 2009 | LaCie d2 Extreme (300790U) 250 GB Hard...
Lacie RUGGED 250GB not recognized by my PC
I think the migration assistant (in the utilities file in your application folder) can transfer files direct via USB.
Jan 23, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
My Porsche Lacie 160GB disk no longer mounts on my Mac OS X. OS is fully up to date at 10.5.6. I've tried it with different firewire cables and on multiple Macs. One is a dual G4 desktop, the other is a...
You need to back up data from the drive and then connect your drive on MAC you need to use mac utility to format the hard disk in Mac as some times it wont recognize a windows operating system...
Jan 08, 2009 | Computers & Internet
Mounting an external hard drive onto my I Mac
Hi, I have just checked the LACIE website, So Google LACIE, click the second result [Lacie's own site] you will get a page up with a choice box, select Australia/go click the desktop HDD. click the 500Gb usb, this will give you a page with a support and a download link. click download, here you will find a manual and drivers. Goodluck mistyman
Sep 03, 2007 | Computers & Internet
Open Questions:
MALWAREBYTES tEcH SuPpOrT PhOnE /@\{18OO8O3/@\1O69} NuMbEr .U.S.A AsIf This MALWAREBYTES USA phone number is ranked #2 out of 2 because 7,728 MALWAREBYTES USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach the MALWAREBYTES USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, MALWAREBYTES USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. MALWAREBYTES USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact MALWAREBYTES USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling MALWAREBYTES USA Calling MALWAREBYTES USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from MALWAREBYTES USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with MALWAREBYTES USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare MALWAREBYTES USA's phone numbers against each other. Contacting MALWAREBYTES USA in General While I8OO8O31O69 is MALWAREBYTES USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach MALWAREBYTES USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact MALWAREBYTES USA.
Oct 16, 2019 | Best Computers & Internet
Comcast Technical Support Phone Number # I:8OO-828-O294 .U.S.A This Comcast USA phone number is ranked #2 out of 2 because 7,728 Comcast USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:828O294 is to reach the Comcast USA Technical Support department for problems like Where to buy, Complaint, Technical support, Repairs, Returns. As far as we can tell, Comcast USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. Comcast USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O30294 and ways to call or contact Comcast USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling Comcast USA Calling Comcast USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from Comcast USA Technical Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with Comcast USA's Technical Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare Comcast USA's phone numbers against each other. Contacting Comcast USA in General While I8OO8280294 is Comcast USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8280294 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach Comcast USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact Comcast USA.
BITDEFENDER tEcH SuPpOrT PhOnE /@\{18OO8O3/@\1O69} NuMbEr .U.S.A AsIf This BITDEFENDER USA phone number is ranked #2 out of 2 because 7,728 BITDEFENDER USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach the BITDEFENDER USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, BITDEFENDER USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. BITDEFENDER USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact BITDEFENDER USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling BITDEFENDER USA Calling BITDEFENDER USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from BITDEFENDER USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with BITDEFENDER USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare BITDEFENDER USA's phone numbers against each other. Contacting BITDEFENDER USA in General While I8OO8O31O69 is BITDEFENDER USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach BITDEFENDER USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact BITDEFENDER USA.
Oct 16, 2019 | BitDefender Computers & Internet
BULLGUARD tEcH SuPpOrT PhOnE /@\{18OO8O3/@\1O69} NuMbEr .U.S.A AsIf This BULLGUARD USA phone number is ranked #2 out of 2 because 7,728 BULLGUARD USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach the BULLGUARD USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, BULLGUARD USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. BULLGUARD USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact BULLGUARD USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling BULLGUARD USA Calling BULLGUARD USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from BULLGUARD USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with BULLGUARD USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare BULLGUARD USA's phone numbers against each other. Contacting BULLGUARD USA in General While I8OO8O31O69 is BULLGUARD USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach BULLGUARD USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact BULLGUARD USA.
See all LaCie 301103U 500 GB USB 2.0 Hard Drive Questions
LaCie 301103U 500 GB USB 2.0 Hard Drive Logo
453 people viewed this question
Top LaCie Computers & Internet Experts
Ekse
Marvin
Marvin
Alun Cox
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
