Question about Frigidaire FRS-26DR7D Side by Side Refrigerator
How to remove smudge proof coating from Frigidaire appliance
2 Suggested Answers
SOURCE:
SOURCE: exterior finish on stainless steel model peeling
Just a thought. Our frigidaire stainless steel refrigerator came with a temorary protective film on the steel parts that we peeled off after it was installed. Is it possible you never removed your film when you got your refrigerator? That may be what is starting to peel off now. Again, just a thought, I could be wrong.
Posted on Sep 02, 2008
Is there a way to completely remove the clear coat protective finish for on Stainless Steel appliances?
try a small amount of acetone and rub with a piece of scotchbright in the directions of the grain of the stainless.should work.Good Luck
Apr 10, 2016 | Frigidaire Ovens
Tip
Makeup Remover
Do you have the right makeup remover to remove your waterproof make-up at then end of the day?Wearing water proof, smudge proof or sweat proof cosmetics means that you'll look great all day or all night. But you still have to remove your makeup to let your skin breathe! Before you go to bed, take the time you need to carefully remove every bit of makeup from your face-foundation, concealer, blush, eyeliner and shadow, lip color. Take it all off with your favorite waterproof makeup remover and follow it up with toner or moisturizer, depending on your skin type. Leaving makeup on overnight can cause clogged pores, breakouts and grubby pillow cases, so stay up three minutes longer and get your face clean before going to bed.<br /><br />
on Nov 22, 2010 | Health & Beauty
Tip
How To Clean Stainless Steel Appliances
First do a quick wipe of the appliance with a gentle liquid dish detergent & water mix, dry with a clean towel. After washing you’ll likely see the smudges and marks still hanging in there. You can buff out each smudge with a lint-free towel and some pressure, but try one of these items instead to bring back the shine and quickly remove those pesky fingerprints and smudges:
  • Olive Oil (just a dab will do)
  • Mineral Oil (Baby Oil)–Just a dab will do
  • Club Soda (especially good for removing streaks and heat stains)
  • Rubbing Alcohol
  • Vinegar (great for polishing too)
Apply directly to a lint-free cloth and wipe down surface, follow up with a clean dry cloth to bring appliance to a mark-free shine.
  • Avoid using cleaners or cleaning tools that are abrasive since they can mar the surface (even some soft-scrubbing creams can cause damage).
  • When cleaning the surface, wipe down the appliances along the grain of the stainless steel for best results.
  • Don’t clean stainless steel with bleach (diluted or otherwise), this can damage the finish.
  • Don’t forget to open the refrigerator or oven door, you’ll likely see a mess of smudges along the edge of the door.
on Mar 15, 2010 | Refrigerators
My frigidaire gallery french door with ice maker is making a knocking noise every 5 seconds. Sounds like from the ice maker. How do I fix or stop the noise.
I have a different type. I rubber banded the little ARM in the UP position ( to fool the unit that I have enough ice). NO MORE SOUND>>
Jun 03, 2015 | Frigidaire FGHB2866PF3PCKIT Gallery...
I have a dark spot on my lens. Can I remove the lens and clean it? if so, how?
Cleaning of a camera lens is only allowed with special less fluid, because the coating on the lens can easily be damaged. The coating is essential, for correct working of the lens. It corrects aberration, flairs and adds to the sharpness of the lens. fluids like alcohol must not be used. You also can buy a lens pen to remove smudges, but first read how to use it.
They come in different sizes, so choose the correct one for your lens, if you want one.
When the dark spot is on the inside of the lens you can't remove it. It could be molt and will eat its way through. Where the molt is, the coating is gone, so removing it, will change the characteristics if the lens forever.
May 03, 2015 | Cameras
Finger print proof coating on outside bubbling up, any way to fix?
Hey friend, thank you for your post!
You are able to purchase parts with the coating already applied for your Electrolux refrigerator, E23CS75DSS. To answer your question, there is no way to fix the bubbling issue on your appliance you would have to purchase new parts for your refrigerator. I have included the parts manual link so you can look over parts needed. Once you have those parts numbers needed you can reach out to the manufacture to order them. I hope this is helpful. -Matt
Frigidaire Manual Search Results
Aug 13, 2014 | Electrolux E23CS75DSS Stainless Steel
Frigidaire Gallery Stainless Steel Appliance finish defect. The Smudge-Proof finish on my Frigidaire refrigerator began peeling off after I owned the product for 14 months. It appears to be a clearcoat...
Frigidaire Gallery & Professional appliances put a micro-coating over their brushed stainless to help prevent smudges and fingerprinting. However, if this coating has begun to peel off there isn't much you can do about it. You can order a new door for it for around $250-$400 depending on the door. Very rare for this to happen. If was a common problem, they wouldn't make it like this.
Oct 17, 2013 | Refrigerators
Leaving brown/black smudges
This is most likely caused by laundry getting stuck in the front seal of the washer.
Jul 08, 2009 | Frigidaire ATF6000ES Front Load Washer
Moisture developing between the glass on the ovendoor
when the oven comes new ,,you must burn the coating of for about an hour..a form of food grade rust proofing..let unit bake at 400 for 55 to 65 minutes empty
Dec 24, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Exterior finish on stainless steel model peeling
Aug 21, 2008 | Frigidaire FRS-26DR7D Side by Side...
Frigidaire FRS-26DR7D Side by Side Refrigerator Logo
284 people viewed this question
Top Frigidaire Refrigerators Experts
Steve Allison
Steve Allison
Thomas F. Schneider
jasbo
jasbo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
