PC Laptops
Problem for PC Laptops
Generic problem for all PC Laptops
Windows Vista will not start up
By Jerrytaff on Apr 29, 2009
After starting the computer, I keep getting a blue screen flashing up saying:
''A problem has been detected and Windows has been shut down to prevent damage to your computer.
If this is the first time you have seen this screen restart your computer. If this screen appears again, follow these steps:
Disable or uninstall any anti-virus, disk defragmentation or back-up utilities, check your hard drive configuration and check for any updated drivers. Run CHKDSK/F to check for hard drive corruption and then restart your computer.
Technical information ***STOP: 0x00000024 (0x00190444,0x870B9ee8,0xC0000102,0x00000000)
Any ideas what I can do? I have done all the F8 options - it just shuts down after the same blue screen.
Comments:
Apr 29, 2009
- Yes, I have a recovery disc, but the disc drive will not function. It stops after 2 seconds. I should tell you this problem occured when automatic updates were being made to the computer. It froze on update one and after one hour I switched it off manually. Then this problem came.
Apr 29, 2009
Apr 29, 2009
- Toshiba Qasmio G40-12c is thee make and model.
Apr 29, 2009
- I have tried that - I just get the same blue screen. In fact, I get it for all the Boot options listed.
Apr 30, 2009
- many thanks for all your advice - I will study all the links you gave me. I want to try and learn more about computers and I think that problem solving is a good way to start. I am in no hurry.
May 06, 2009
- Thanks for all your advice.
Clarification Request
Posted by kimbessent on May 04, 2009
You might possibly have a bad hard drive. When you turn on the computer, does it go directly to the blue screen, or do you get the splash screen first?
Posted by OnlyOneN on Apr 29, 2009
What is the make/model of your laptop? Occasionally there is a combination of keys that must be pressed in order for it to boot off of the CD drive.
Do you have the original disks that came with the laptop? If so, there's probably a system restore disk included. Insert that disk, and turn on the computer. It'll walk you through the process of restoring your system back to factory defaults.
Best Solution
posted on Apr 29, 2009
Helpful)
efs_perpends
Rank: Guru
Rating: 89%, 730 votes
Please have a look at this link to see MS's recommendations for startup problems in vista.
And since you can't even get it booted at the moment, see here for an explanation of that 0x...24 error code, which indicates a problem with the file system driver or the drive itself. You will need to run the chkdsk utility from a recovery disk or recovery console to determine this.
It's possible that since your optical drive is not functioning, that the driver for that drive is causing the problem, but if you don't have the recovery console installed and can't run a recovery disk, you may have to take it to a shop just to get it booted on another hard drive. (see similar discussion here)
There is a hotfix available for systems that receive this error code, see here
Because there is a hotfix available, you might be able to get Microsoft support for this problem by following the hotfix link in that last link.
Good luck.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Helpful)
OnlyOneN
Rank: Guru
Rating: 92%, 67 votes
Here's to to restore your laptop. Keep in mind that this will most likely delete everything off your hard drive and restore it to factory defaults.
If you choose not to restore your system, I would recommend taking it to a local computer repair shop.
The procedure is as follows.
1. Turn off the computer.
2. While holding the F8 key, turn on the computer.
3. The Advanced Boot Options menu will be displayed. Use the arrow keys to select Repair Your Computer and press ENTER. 4. Follow the on-screen instructions.
Comments:
Apr 29, 2009
- Sorry I can't be of more assistance. I recommend calling Toshiba or taking it to a local repair shop.
Best of luck to you.
Was this helpful?
Yes
No
Solution #3
posted on May 10, 2009
Somewhat Helpful)
ketanvasu50
Rank: Master
Rating: 79%, 17 votes
u find one option after automatically restart launch startup & repair do that thing
Was this helpful?
Yes
No
Popular Solutions for PC Laptops
Questions and Unsolved Problems for PC Laptops
Answer
what are the best upgrades for acer travelmate 4200
Answer
How to apply this layout on my account?
Answer
my facebook website been blocked by the administrator
Describe your PC Laptops problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptop Experts
Top Computer & Laptop Repairmen
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
