Question about Pioneer VSX-D412 Receiver
Amp error when i turn it on it says amp err.and then shuts itself off.please help miss my surround sound.thank you
  • madfigaz Dec 12, 2007
    I have the same problem with my reciever also. When I turn on the reciever it say's "AMP ERROR" and then it turns off. I've paid proffesionals fix this problem....worked a couple of days then it went back to amp error. I really miss having surround sound when watching movies.
  • Anonymous Mar 12, 2008
    amp erra
The only solution I, personally, can help any of you with is to buy a good working model. i.e. Mine! I am upgrading to a 7.1 Onkyo and do not need mine any longer. Send me an email and I will gladly sell it to you! $75 (no remote) But you already have one so... (passme23@hotmail.com)
Posted on Mar 17, 2008
My Gaithers Radio is flashing DC Error on the screen.What is the solution
what does dc error mean and after that comes i get no sound... what does dc error mean and after that comes i get no sound from stereo
Share this conversation
Answered in 16 minutes by:
7/13/2012
Car Electronics Technician: bluextc89
Thanks for stopping by:
DC error indicates the radio has detected a GROUND on an AC output IC leg, and shuts down to prevent further damage.
This is typically caused by a blown speaker, cracked or worn wire contacting chassis metal, or a failed IC.
Disconnect and test all speakers to ensure the voicecoils are good.
Visually inspect the speaker's surrounds to make sure there are no tears or missing pieces. They need to surround for the voicecoil to stay linear to the polepiece.
Try out the radio with all speakers disconnected - if it still happens - the radio requires repair/replacement.
If you have additional - Just Ask.
Thanks!
what does dc error mean and after that comes get no sound
Feb 22, 2018 | Televison & Video
Problem for Pioneer VSX-818V-K 5.1 Channels Receiver Surround sound doesn't work, display reads 2CH IN,surround speakers are enabled,automatic test will find surrand speakers
Test with an surround sound media ie. Blu-ray or DVD)_. Disconnect the front and all other speakers that are working to see if sound from the missing speakers are heard. If this doesn't work then start by tracing and checking all the wires from the receiver to the speakers for bad/shorted/open connections.
PLEASE VOTE IF THIS WAS HELPFUL. THANKS & GOOD LUCK.
Oct 23, 2009 | Pioneer VSX-818V-K Receiver
GLEQ2152ES the error "PF"
My dryer keeps beeping all by itself. I had to turn the breaker off. Now I tried to use it it it tumbled for a minute but kept flashing err & beeping then flashed E68 & shut off.
May 25, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Amp err
Same problem here VSX-916 AMP ERR
Jan 28, 2009 | Pioneer VSX-D912 Receiver
Jonny Rafael Every time i turn on my amp it stops and says Amp Err and shuts down and wont let me turn on like in about 20 min.I dont know wats wrong but i need help please.
Says amp error on the amp? what kind of amp? Have you checked the fuses and are you properly installed ie. remote wire to a remote power source. Properly grounded? Power wire to a constant power source? Please be more specific?
Aug 31, 2008 | Pioneer Audio Players & Recorders
Amp Err
please check all speakers cables for short circuit-disconnect all speaker-put volume low-wait and observe it if no shut down -go to next step-connect your speaker one by one until you find the bad one,start with speaker cable(try another good cable) and then speaker.if shut down happened again while you connect nothing to your system you will have inside problem and ask for service center to fix it.
Jul 07, 2008 | Audio Players & Recorders
Samsung 5-Disc 1200-Watt Home Theater Surround Sound System My Home Theatre System is keeps shutting down by its self. before it shuts down the screen says protection mode and then shuts down. i have...
If the unit shuts down almost immediately without sound, you have an electronic failure of the audio amplifier.
However if you must play the unit up above quiet background levels, you likely have a shorted speaker wire. With home theater systems, you have the luxury of trying different surround modes and speaker level settings. It's not unusual, for example, to have a loose wire strand going to the center speaker. In stereo, the system works fine. As soon as you switch to a surround mode, the amplifier senses the short and shuts down to protect itself.
Check those wires really close - I bet you'll find it there.
May 15, 2008 | Audio Players & Recorders
Stand by button flashes but receiver wont turn on
I have vsx-d812 that has an AMP ERR in error menu. the troubleshooting was found to be Q696 and Q697 in the DC prot. area on "C" board, up near front toward diplay in center of c board. You can get access to error codes on VSX pioneer unit by pressing "enter" and "adv. surr." simultaneously for 2 sec. The display should show what error code you are experiencing. I believe there are three diff. error codes. 1) AMP ERR 2) OVERLOAD 3) BOAD ERR (not mistyped) I hope this helps pinpoint error code for ya.
Oct 07, 2007 | Pioneer VSX-816-K/S Receiver
Blinking Standby
regarding the Pioneer VSX-912 blinking standby light. This is how you reset it; press the "advanced surround" and the " enter" at the same time for about 3 seconds. Make sure you press the ENTER on the reciever (its the one on top next to the small dial) If you press the "ON" instead of "ENTER" it will not work. If an error message comes on and shuts the unit down, just reset it again. This should save you some $$$$. To bad Pioneer did't put this info in the manual.
May 22, 2007 | Pioneer VSX-D912 Receiver
Pioneer VSX-D412 Receiver Logo
424 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
