Question about Memorex (32025618) 25 Pack 16x DVD+R Storage Media
Backup computer i have windows vista tried back up of computer 3times and failure came up have16xdvd+r disks what do i need to do to solve this prob.
    Novelist:
    Champion:
  • 382 Answers
Compact disks are too smalll to back up a computer, as your computers hard drive contains gigabytes of info and a cd is only 800mb at best. DVDs are more suited. First, you want to make a disk image of your hard drive, then back that up to another drive, ideally an external drive solely intended for back up with nothing more on it than the application used to execute the back up. Backing up to optical disks has never been considered a valid form of back up. Hope this helps.
Posted on Oct 02, 2007
6ya staff
SOURCE:
Windows vista recovery cd I created won't install on new hard drive
Which software did you use to create the recovery disk? Is the recovery disk a CD or DVD?
Just to recover a vista system from recovery DVDs would require at least two DVDs. Your files would be in addition to this so I would be very surprised if you have only a single disk containing both the operating system and all of your files.
A simple recovery disk would only be useful for restoring lost operating system files to a hard disk that had corrupted or deleted files. It would let you restore to a new blank disk.
If the disk only contains a backup of your data then you would need to first install an operating system (Vista or Windows 7) and then install the backup software you used to create the disk and then you could recover your data from the disk.
Jan 05, 2013 | HP Computers & Internet
When i start my computer a message came that 'disk
No your operating sytem or boot files have a problem. Something is missing or corrupt in the operating system or boot files.
Try the steps below.
You will need a operating system disk or a repair disk to fix it. Insert it in the drive then boot from it. You want to get to a dos command prompt (black screen with white lettering) and type the following commands. Press ENTER after each command.
bootrec.exe /fixmbr
bootrec.exe /fixboot
bootrec.exe /rebuildbcd
Reboot and see if the problem is solved. If not get back to the dos command prompt and run the check disk utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
May 11, 2012 | Compaq Computers & Internet
Dark Messiash disk for -window xp- igot window vista 32bit
try to run the disk on compatibility mode. right click the application file, usually the file with the .exe extension then choose to run in compatibility mode running windows vista. if this doesn't solve then time to change to disk for windows vista version
Apr 06, 2012 | Video Game Consoles & Games
Hi I posted a problem last night about my asus eee pc 1005ha... kept rebooting at windows load screen. so I brought a dvd burner to run windows disk & do repar. it would go through everything fine...
Hi.
Solving your problem is just as easy as 2 hour work. not more..
By the time you were having the restarting problems.. all you had to do was to boot from usb cd-rom using Hirenes boot cd 10.
It starts a small intergrated windows. then you would have to go to a menu to stop some un-named startup bugs that cause the restart when Explorer.exe is being executed by windows.
so now, if you have your backups safe, get instruction on the internet on how to make a bootable usb windows vista or 7 Setup. windows seven comes with many drivers for new laptops.
Boot your computer from USB flash disk, run the windows 7 setup and enjoy..
hope this information helps you because it helped me with Acer One netbook..
good luck
Nov 23, 2010 | Computers & Internet
Windows vista restarts
its prob with your vista version, which is not compatible with your pc, install another version of Vista using different disk. (please read the requirements of windown Vista)
good luck
shafky
Jun 22, 2009 | Sony VAIO FX220 Notebook
81003004 problem
this is prob in yahoo apps. pls uninstall your yahoo and install again this will solve your prob, somehow there is a software issue on the latest version of yahoo
cheers
Nov 26, 2008 | Microsoft Windows Vista Home Premium with...
Continues rebooting
OK it is going to be difficult to solve this one with so many different errors. Given that this is windows Vista it is probably a bad driver. Possibly the graphics card driver. Also vista is quite punishing on hard disks so we'll start there.
First off take a backup of all your documents photos videos etc. because the check disk can cause havoc if it finds a lot of errors and can take down windows altogether. Also you must be prepared to re-install windows so make sure you have a recovery method (recovery CD's or a hidden partition on the Hard Disk) If the hard disk is truly borked though it might take the hidden partition with it. Proceed with caution and make sure you can get the PC back up and running if the worst happens.
First run a check disk. In My Computer, right click on the c drive, click on properties - tools - check drive for errors, then restart your computer and let the chkdsk run.
Post back here with the outcome.
Sep 10, 2008 | Microsoft Windows Vista Home Premium with...
Acer Scaner Pria 640P Flatbe -Driver needed for Vista home
Dear Sir
I have recently changed my windows vista operating system and my scanner which model number is 640P not working properly. the previous software under windows xp is not working. Please solve my prob. and a bundle of thanks for solving my prob. immediately.
zaheer babar
from lahore pakistan.
Aug 27, 2008 | Acer ScanPrisa 640P Flatbed Scanner
Windows vista unable to install my canon pixma mp500
First download and install the latest drivers for Windows Vista. Then try connecting the printer. The latest drivers can be obtained from: www.download.com/BJ-Printer-Driver-Canon-Pixma-iP1500/3000-2116_4-10555901.html
Sep 27, 2007 | Canon Pixma MP500 All-In-One InkJet...
Memorex (32025618) 25 Pack 16x DVD+R Storage Media Logo
Top Memorex Electronics - Others Experts
David Ellis Rhea
JonSnell Electronic
JonSnell Electronic
Are you a Memorex Electronics - Other Expert? Answer questions, earn points and help others
