Question about Hitachi 43GX01B 43" Rear Projection Television
Samsung HCL 5515W
How do you clean the lens and screen?
  • 790 Answers
Get 100% cotton then slightly rub your screen!
Posted on Oct 02, 2007
I have no sound in my tv samnsung 55 hcl 5515w
go into settings and check audio if set on TV sound or Audio system also there can be issues with HD channels and regulars channels I hope this helps
Aug 22, 2014 | Samsung HCL5515W 55" Rear Projection...
I have a Samsung 61"
Sir the lens of your lamp is just dusty try to clean it with microfiber cloth but remove ac plug to the main, then wait for the lamp to cool down before cleaning the lens or try to check user manual. Good day and best regards.
Sep 06, 2011 | Samsung HL-T6156WX 61 in. TV
How do i safely clean my samsung epic screen?
you can simply use glass wipes as you would for your glasses, buy either using some lens cleaning wipes or spray on a cloth first. then purchase some screen protectors like below for example
http://www.amazon.com/Three-Screen-Guards-Protectors-Samsung/dp/B0044NV3VY/ref=sr_1_1?ie=UTF8&qid=1305134276&sr=8-1
May 11, 2011 | Cell Phones
Someone sat on my es-55 samsung camera, when i put it on an ink blot picture appears on the screen, this might be the lcd screen , the lens is okay as it still slides out.How do i fix it?
Hi
Does the 'ink blot' appear on any pictures you are taking or just on the Samsung ES55 LCD screen?
If it just appears on the LCD screen it's probably been damaged when it was sat on, and the only option would be to replace the LCD screen by contacting a Samsung service agent in your region.
If the 'ink-blot' image is appearing on the pictures you are taking then check the lens is clean - be careful not to extert to much pressure on the lens when it is retracted.
if the lens seems clean, as a last suggestion change memory card, or totally reformat the card that is in the camera - if the card has become corrupt the images may not be displaying correctly.
I hope one of these few suggestions sorts your problem.
Regards
David
Jan 17, 2011 | Samsung Cameras
Hcl crt color 15" digital monitor.red color is
Unfortunately, this is not a fixable problem. Samsung CRT monitors are well known for losing color; they have defective cathode ray tubes. I recommend that you buy an lcd screen. sorry if that wasn't what you wanted to hear! don't forget to rate
Jan 13, 2011 | Samsung SyncMaster 753 DFX 17" CRT Monitor
My Samsung SL202 isnt working the back screen stays black when i try to turn it on and it makes a sizzling noise then then lens comes out but dosent pop back in
that is a lens error in the alignement of the lens;
its may due to some dust in motor lens block ***'y and probly needs to be clean ...
hope that will help
regards Alan..
May 14, 2010 | Samsung SL202 Digital Camera
SecurDisc HL-DT-ST DVD -RAM GSA-H55N ATA DeviceDevice not recogni
Your dvd lens needs to be clean from dust. Clean the lens of the drive by using a cd/dvd lens cleaner. You can buy it at any computer stores. Reconnect the drive from your computer.
Dec 19, 2009 | Computers & Internet
Bug in screen
It is unlikely the bug got between the inner Fresnel lens and the outer cylindrical disperser lens of this DLP as the separation is minimal and blocked off all around. Much more likely is that is inside the Fresnel lens and may be cleared off with a clean microfiber cloth through a port to be found on each side (guessing) of the set. Try not to add dust. You can also go to avsforum <http://www.avsforum.com/> and search for Samsung HL-P6163 or similar 5-year old. -Ken
Jul 30, 2009 | Samsung HL-P6163W 61" TV
Monitor not working
You will need to change the display settings for the type of lcd monitor you have, it is a wide screen I am assuming, you can change this by right clicking on the desktop select properties then settings the screen resolution should be on the middle left side and change this until you get a screen that you like There is also an advanced setting then select monitor at the top tab and change to refresh rate to the lowest setting (60 hz) this should get the HCL monitor up then change the setting until they dont work the operating system will revert to the previous settings if you cant see anything after a change. you may also need to use the automated setup on the lcd monitor select auto from the menu (osd). Now if you can not do this on the HCL lcd you may need to use that other Samsung monitor and then set up on that at the lowest resolution so that the lcd can be changed with a working screen. Lastly you may need to uninstall the samsung monitor drivers if you installed those, and leave the generic drivers in for the monitor (plug and play monitor).
I am making some guesses here as you did not tell me if the 1st Samsung monitor was a lcd also , and if the second HCL monitor is a wide screen etc what type of operating system are you running is also important 98 is fussy and 2000 is much more simplified as is XP , vista would be garbage (if you could get it to run on a pIII),
As for reasons for resolution problems, way too many variables to discuss in a short answer forum like this, sufficed to say that the resolution is different because in the past there were lower resolution (less pixels) on monitors, the refresh rates were different by manufacturers and the way the lines were scanned could be different, so setup of the monitor with the video card was also very important interlacing etc was also handled differently until that industry decided on a common standard.
I hope this helps you to get the monitor up and running.
Jul 17, 2008 | Computers & Internet
Kodak service station in hyderabad
hey its near satyam/shoper stop, begumpet. (better search in google map for "hcl, begumpet".
the address is:
hcl infosystems pvt.ltd.
Hcl Tower, Chikoti Gardens, Dwarkadas Colony, Plot No 44 Chikoti Gardens, Begumpet, Hyderabad, Andhra pradesh 500016,
040 27765411 hclinfosystems.in
Jun 18, 2008 | Cameras
Hitachi 43GX01B 43" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
