Back to:
Tags:
Bissell 1699 ProHeat Clear View Upright Steam Vacuum
Smart mix plunger bissell 1699 (by 2 users)
posted by jimmy41 on Oct 02, 2007
Unit would not dispense water or cleaner. After taking the unit apart twice I found the heater was blocked. In doing this the plunger fell off. I was able to put it back in place but I must be positioning the plunger wrong. I get water but no matter what position I turn the know no cleaner will dispense.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by cruisemaster, posted on Aug 14, 2008
I have the same problem with 2 bissells. Even bought a new pump and that did not fix problem. Seems as if the water from tank is not getting to pump and the lines are open. I ready to throught these two in the trash and buy a Hoover.
Best Solution
posted on Dec 14, 2007
Helpful (85)
hotsam
Rank:Apprentice Apprentice
Rating: 92%, 18 votes
Check your wiring. I have a photo of the correct wiring if you'd like it for reference,
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on smart mix plunger bissell 1699:
I don't want to Accept this solution
Solution #2
posted on Sep 03, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
This is what happened to me. The heater had to be cleaned. Easy fix.
Thank You!
Can you Help with these Vacuums problems?
Vacuums
bosch ergomaxx model bsg82000gb/01 bagged vacuum cleaner...
Vacuums
I am trying to connect a sansui 5000x receiver to my home...
Vacuums
Miele white star vacum cleaner - electrical cord not...
Bissell 1699 ProHeat Clear View Upright...
The water will not come out for cleaning purposes...
lynn andrews andfam@centurytel.net
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
