2210 all in one. Cartidge 56 causes error. "Remove and check cartridge". Other cartriges fine. Using refills. HP doesn't suppport problem. Usually gives me problems but usually works after fiddling with it. Would like an absolute solution. done it all, tried downloading old and new software,formward, turn on and off, cleaned cartrdges, etc
Checkitright sorry but been there did that. Using refills. Put backup cartridge in working now. Went back to store. Owner said the new conventional wisdom is cartridge has a set # of drop or releases in it. Once that # is reached the cartridge is done. Had a gizmo he bought and confirmed the limit is right. Seems the #56 is baffling everyone. If you get a refill get the latest date on the cartridge possible. it is printed there
Usually, the error is because it's not recognizing the cartridge. Check the contacts on the printer and clean w/ alcohol. Are you using recycled cartridges or filling it yourself?
getting a message remove & check cartridge,after changing colour hp57 cartridge getting the same message.Then after putting a previously defective hp56 cartridge the massage cahanges to remove & check right cartridge.even changing another ok 56 doesn't work.what do i need to do.
K.K.Madan
the message remove & check cartridge seems to be wrong,even after changing both of these same message is appearing.how can i solve the problem.if nessesory i can open the unit & check up the mechanical as well as electronic section under you guidence.
krishn kumar
