Question about JVC Dla X3 3d Projector
Jvc x3 projector orange lamp light flashes wont power up
Jvc x3 projector orange lamp flashes wont power up have replaced lamp and checked lamp cover
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 729 Answers
1,Check the fans ,if the fan is running
2,Inductor (Sensing element),near the Color Wheel. Use a cotton swab moistened with alcohol to wipe the Inductor.
Have a good day!
We supply original projector parts: lamp, bulb, Lcd, Lens, DMD,
motherboard, powersupply ... with high quality and competitive price.
Jerry China
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Posted on Nov 05, 2013
Warning and standby indicator of JVC D-ILA Projector model DLA-X70RBE flashing simultaneously.
Johan, Below are links to your model where you can access,manual,instructions and get support.
Press the helpful button and follow me on fixya for more tips and info.
4K shift ILA Projector DLA X70R Introduction
Replacing lamp on JVC Series Projectors
JVC DLA X3 Warning light issues
Feb 11, 2016 | JVC Televison & Video
My JVC DLA-X3-BU will not power on, 2 lights are red, lamp light is flashing orange, how do i get it to work?
I have a JVC DLA-X9-B projector which I think is the almost the same as the X7 and X3 the manual is the same.Its about 2 years old.It stopped working suddenly while I was watching a movie. Indicator lights were both on red and lamp light flashing orange. Replaced the lamp and it did not change the status,did cleaning filter bit , did lamp reset from the remote , did reboot and plugged it at a different ac outlet all that did not work . The lens cover is stuck at opened and the only thing you get when plugged in is the red light on and after 30 seconds the lamp light comes on orange .No fan came on no moving lens cover only flashing orange light.
From this conclusion was the power supply was working and software was a question mark either it was corrupt ,but the power cycle and lamp test start was normal and it checked the lamp and reported orange .So all the more it pointed to either the ballast or the power feeding the ballast.
I opened the projector up started with the screws at the bottom removed the the adjustable screw in legs. Removed the left and the right plastic cover ,then bottom cover, lamp cover, top cover plastic and then top metal plate cover, back cover until parts were all visible ,then put back the screw in legs a placed projector in an upright position. All this was in suspect that the ballast is the problem.
jvc-dla-x3-bu-will-not-power-2-lights-zogl1yh0b34d0jvl0ocjipaz-3-6.jpgThis is the top view photo.
On the right black plastic cover is the lamp fan and air duct.
At the center is the lens assembly and motors for focus lens shift etc.
on the left are stacks of electronics that are stacked board on board of about 4 or 5 layers.
jvc-dla-x3-bu-will-not-power-2-lights-zogl1yh0b34d0jvl0ocjipaz-3-11.jpgthis is the side view of the stacks of boards, to get to the ballast these have to be removed.NOTE LABLE ALL CABLES AFTER REMOVING THEM AS THERE ARE MANY OF THEM.Remove the side plate
Remove hdmi and land board,carefully there are connectors on bottom and all sides of this board.
jvc-dla-x3-bu-will-not-power-2-lights-zogl1yh0b34d0jvl0ocjipaz-3-27.jpg jvc-dla-x3-bu-will-not-power-2-lights-zogl1yh0b34d0jvl0ocjipaz-3-38.jpgthen remove the next board ,remember to lable all the cables.
jvc-dla-x3-bu-will-not-power-2-lights-zogl1yh0b34d0jvl0ocjipaz-3-51.jpgthen the next board bellow ,carefull this one has 2 side connectors on pictures top side
jvc-dla-x3-bu-will-not-power-2-lights-zogl1yh0b34d0jvl0ocjipaz-3-66.jpgthis will be what it looks like.Note the bottom most is the power supply.,This feeds the ballast as well as other low voltage Dc components.THE CONNECTOR WITH THE WHITE END AND BLACK AND RED CABELS IS THE BALLAST FEED(picture above) .The ballast is located in a black plastic box above the power supply.The only way to remove it is to continue dismantling further. jvc-dla-x3-bu-will-not-power-2-lights-zogl1yh0b34d0jvl0ocjipaz-3-83.jpgthis is the top view and the yellow tags you are seeing is cable labelson the wires.
jvc-dla-x3-bu-will-not-power-2-lights-zogl1yh0b34d0jvl0ocjipaz-3-102.jpgthis picture is with all boards removed to check for physical burn outs on components
mainly on power supply ballast feed and ballast itself.
jvc-dla-x3-bu-will-not-power-2-lights-zogl1yh0b34d0jvl0ocjipaz-3-123.jpgall boards out
jvc-dla-x3-bu-will-not-power-2-lights-zogl1yh0b34d0jvl0ocjipaz-3-146.jpgthis is the power supply board it has both low and high voltage output .Low for logic boards high output for ballast.Ballast feed from power supply should put out about 380 volts dc during projector boot up and zero during orange blinking light,(you can skip this removal of power supply if you read the 380 volts output on multimeter at boot up.Do this before taking all the boards apart but remove the side plate to access the output and check the output at boot up ,warning do not short this while reading output.
jvc-dla-x3-bu-will-not-power-2-lights-zogl1yh0b34d0jvl0ocjipaz-3-171.jpgpower board made by sumida and so is the ballast
jvc-dla-x3-bu-will-not-power-2-lights-zogl1yh0b34d0jvl0ocjipaz-3-198.jpgfinally the ballast is out this is what it looks like,do you see the dark grey wires they lead to the optocouplers (little led light sensing switch looks like a square little box all 3 are side by side)
jvc-dla-x3-bu-will-not-power-2-lights-zogl1yh0b34d0jvl0ocjipaz-3-227.jpg this resistor came out of the ballast ,notice physical damage like a hole in the center of it,tested it out of the board and yes its dead replaced this.
.Did all the checking one by one of the components then found one of the optocouplers had gone dead.The one located in the center of the 3 replaced that ,put it all back and got it working again.
The ballast cost 300 usd I bought one too and kept it handy just incase.
But for the meanwhile the old one is back and working just fine.
Aug 07, 2014 | JVC DLA-X3 Procision Projector
The projector turns on but won't project any light through the lens.
If this is a NEC VT series projector, Change the lamp. When if it continues to blink amber and not project and image after installing a new lamp check the lamp cover to see if the micro switch tab on the lamp cover broke off. Some models have a built in lens cover. If the cover is not slid over to open completely the light may not turn on.
May 19, 2014 | NEC VT800 LCD Projector
Red lamp/ orange/lamp After a "break" of about
test this steps and fix it. God bless you
  • Secure the lamp cover and the air filter cover of the projector body if the projector does not power on. Ensure that the power cable is firmly connected to the projector and an active power plug. If the projector was turned off and then on quickly--let it sit for 90 seconds before trying to turn it on.
  • 2
    Replace the projection lamp if the projector will not power on or if the lamp indicator is flashing. Turn off the projector and let it sit for at least 30 minutes. Locate the lamp cover and remove or loosen the lamp cover with a screwdriver. Carefully remove the projection lamp from the projector housing using the handle, if available.
  • 3
    Place the new projection lamp into the projector housing and secure it to the projector. Replace the lamp cover and reset the lamp timer. Power on the projector to ensure the new lamp is working correctly.
  • 4
    Remove the projector from the enclosed area to allow air circulation if it constantly overheats. Place the projector into an open area and make sure there is no blockage for the ventilation holes. Unplug the projector for at least 45 minutes to allow it to soft reset.
  • 5
    Clean the air filter to allow the projector better air circulation. Turn off the projector and unplug it from the outlet. Remove the air filter cover and use a vacuum to remove dust from the area. If the filter is unable to be cleaned correctly or is damaged, then replace it. Pull the air filter from the projector and place the new one in the now empty slot. Close and secure the air filter cover.
Oct 28, 2013 | BenQ PB6110 Multimedia Projector
Jvc dlax30bu
when i plug in power x30 jvc dila is red light on and lamp light on and the waning light r 6 time flash again and again
Feb 25, 2013 | JVC "DLA-X30 D-ILA 3D Projector"
Sony VPL-EX3 projector on/off switch flashes green then turns red and the lamp/cover light is orange. Does this mean the lamp needs replacing or could it be caused by some other factors?
Possible that the lamp is faulty -if the hours have elapsed- check the lamp holder, the fitments.
check also the filters, clean and reset.
Make sure the power supply Unit is not having any poor soldering or faulty components to reduce the voltage output to the lamp thus making it shut down..
Jan 17, 2011 | Sony VPL-EX1 Multimedia Projector
After changing the bulb image will not come on and solid orange light appears
Other then POWER BUTTON light there are three lights more
1. lamp indicator
2. temperature indicator
3. computer input
witch one light is flashing RED or illuminated RED with POWER BUTTON orange light.
If LAMP INDICATOR light is illuminated RED than lamp runtime has reached 1800 hours. but projector still working.
If LAMP INDICATOR light flashing RED than lamp circuit failure, or abnormal function or lamp unit is damaged. In this case projector doing the same behave just like your projector.
if TEMPERATURE indicator illuminating RED the projector still projecting and if flashing RED than turned of itself
Jan 11, 2011 | Panasonic PT-LB50U Multimedia Projector
BenQ MP612c projector has three orange flashing lights
you can go to the BenQ website and download a manual for your particular projector. It should tell you what the lights indicate.
Feb 01, 2009 | BenQ (200NSH-LAMP) Projector Lamp for...
Power light flashin orange, status light flashing red on WT610 NEC
if the status light is flashing .5 seconds on and 2.5 seconds off - you need to replace the lamp cover correctly.
if the status light is flashing .5 seconds on and .5 seconds off in 2 - 6 cycles the error is: 2 cycles - the projector is overheated. Move the projector to a cooler location, or/and remove dust in the light path. 3 cycles - the power unit is not working correctly. 4 cycles - the fans are not working correctly 5 cycles - lamp fails to light. Wait a full minute and then turn on again.
Jan 25, 2009 | NEC WT610 DLP Projector
Dell 2300MP Projector Lamp - "Orange Light"
I've heard it could be the ballast, check with Dell for replacements
-- Deft
Aug 21, 2008 | Dell 3200MP Multimedia Projector
JVC Dla X3 3d Projector Logo
656 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
